ผู้เขียน หัวข้อ: DTC Reference  (อ่าน 3417 ครั้ง)
  • กระทู้: 42370
DTC Reference
« เมื่อ: 22 พฤศจิกายน 2566, 08:38:02 »
  •    DTC Reference
    Table 1: DTC Descriptions.
    Trouble Code  Description
    P0001 Fuel Volume Regulator Control
    P0002 Fuel Volume Regulator control circuit Range/Performance
    P0003 Fuel Volume Regulator control circuit low
    P0004 Fuel Volume Regulator control circuit high
    P0005 Fuel Shutoff Valve control circuit/Open
    P0006 Fuel Shutoff Valve control circuit low
    P0007 Fuel Shutoff Valve control circuit high
    P0008 Engine Position System Performance (Bank 1)
    P0009 Engine Position System Performance (Bank 2)
    P0010 A Camshaft Position Actuator Circuit (Bank 1)
    P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0012 A Camshaft Position - Timing Over-Retarded (Bank 1)
    P0013 B Camshaft Position - Actuator Circuit (Bank 1)
    P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    P0015 B Camshaft Position - Timing Over-Retarded (Bank 1)
    P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
    P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
    P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
    P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
    P0020 A Camshaft Position Actuator Circuit (Bank 2)
    P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0022 A Camshaft Position - Timing Over-Retarded (Bank 2)
    P0023 B Camshaft Position - Actuator Circuit (Bank 2)
    P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
    P0025 B Camshaft Position - Timing Over-Retarded (Bank 2)
    P0026 Intake Valve Control Solenoid CircuitRange/Performance (Bank 1)
    P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
    P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
    P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
    P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
    P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
    P0033 Turbo Charger Bypass Valve Control Circuit
    P0034 Turbo Charger Bypass Valve Control Circuit Low
    P0035 Turbo Charger Bypass Valve Control Circuit High
    P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
    P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
    P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
    P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
    P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
    P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
    P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
    P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
    P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
    P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
    P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
    P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
    P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
    P0049 Turbo/Super Charger Turbine Overspeed
    P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
    P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
    P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
    P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
    P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
    P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
    P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
    P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
    P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
    P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
    P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
    P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
    P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
    P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
    P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
    P0065 Air Assisted Injector Control Range/Performance
    P0066 Air Assisted Injector Control Circuit or Circuit Low
    P0067 Air Assisted Injector Control Circuit High
    P0068 MAP/MAF Throttle Position Correlation
    P0069 Manifold Absolute Pressure Barometric Pressure Correlation
    P0070 Ambient Air Temperature Sensor Circuit
    P0071 Ambient Air Temperature Sensor Range/Performance
    P0072 Ambient Air Temperature Sensor Circuit Low
    P0073 Ambient Air Temperature Sensor Circuit High
    P0074 Ambient Air Temperature Sensor Circuit Intermittent
    P0075 Intake Valve Control Solenoid Circuit (Bank 1)
    P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
    P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
    P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
    P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
    P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
    P0081 Intake Valve Control Solenoid Circuit (Bank 2)
    P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
    P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
    P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
    P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
    P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
    P0087 Fuel Rail/System Pressure - Too Low
    P0088 Fuel Rail/System Pressure - Too High
    P0089 Fuel Pressure Regulator 1 Performance
    P0090 Fuel Pressure Regulator 1 Control Circuit
    P0091 Fuel Pressure Regulator 1 Control Circuit Low
    P0092 Fuel Pressure Regulator 1 Control Circuit High
    P0093 Fuel System Leak Detected Large Leak
    P0094 Fuel System Leak Detected Small Leak
    P0095 Intake Air Temperature Sensor 2 Circuit
    P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
    P0097 Intake Air Temperature Sensor 2 Circuit Low
    P0098 Intake Air Temperature Sensor 2 Circuit High
    P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
    P0100 Mass or Volume Air Flow Circuit
    P0101 Mass or Volume Air Flow Circuit Range/Performance
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0110 Intake Air Temperature Sensor 1 Circuit
    P0111 Intake Air Temperature Sensor 1 Circuit Range/Performance
    P0112 Intake Air Temperature Sensor 1 Circuit Low
    P0113 Intake Air Temperature Sensor 1 Circuit High
    P0114 Intake Air Temperature Sensor 1 Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit
    P0116 Engine Coolant Temperature Circuit Range/Performance
    P0117 Engine Coolant Temperature Circuit Low
    P0118 Engine Coolant Temperature Circuit High
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Pedal Position Sensor/Switch A Circuit
    P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance
    P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low
    P0123 Throttle/Pedal Position Sensor/Switch A Circuit High
    P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0127 Intake Air Temperature Too High
    P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
    P0129 Barometric Pressure Too Low
    P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3)
    P0148 Fuel Delivery Error
    P0149 Fuel Timing Error
    P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3)
    P0168 Fuel Temperature Too High
    P0169 Incorrect Fuel Composition
    P0170 Fuel Trim (Bank 1)
    P0171 System Too Lean (Bank 1)
    P0172 System Too Rich (Bank 1)
    P0173 Fuel Trim (Bank 2)
    P0174 System Too Lean (Bank 2)
    P0175 System Too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low
    P0179 Fuel Composition Sensor Circuit High
    P0180 Fuel Temperature Sensor A Circuit
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low
    P0183 Fuel Temperature Sensor A Circuit High
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low
    P0188 Fuel Temperature Sensor B Circuit High
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low
    P0193 Fuel Rail Pressure Sensor Circuit High
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #1 เมื่อ: 22 พฤศจิกายน 2566, 08:38:34 »
  • P0200 Injector Circuit/Open
    P0201 Injector Circuit/Open Cylinder 1
    P0202 Injector Circuit/Open Cylinder 2
    P0203 Injector Circuit/Open Cylinder 3
    P0204 Injector Circuit/Open Cylinder 4
    P0205 Injector Circuit/Open Cylinder 5
    P0206 Injector Circuit/Open Cylinder 6
    P0207 Injector Circuit/Open Cylinder 7
    P0208 Injector Circuit/Open Cylinder 8
    P0209 Injector Circuit/Open Cylinder 9
    P0210 Injector Circuit/Open Cylinder 10
    P0211 Injector Circuit/Open Cylinder 11
    P0212 Injector Circuit/Open Cylinder 12
    P0213 Cold Start Injector 1
    P0214 Cold Start Injector 2
    P0215 Engine Shutoff Solenoid
    P0216 Injector/Injection Timing Control Circuit
    P0217 Engine Coolant Over Temperature Condition
    P0218 Transmission Fluid Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Pedal Position Sensor/Switch B Circuit
    P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
    P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low
    P0223 Throttle/Pedal Position Sensor/Switch B Circuit High
    P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Pedal Position Sensor/Switch C Circuit
    P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance
    P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low
    P0228 Throttle/Pedal Position Sensor/Switch C Circuit High
    P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Turbo/Super Charger Overboost Condition
    P0235 Turbo/Super Charger Boost Sensor A Circuit
    P0236 Turbo/Super Charger Boost Sensor A Circuit Range/Performance
    P0237 Turbo/Super Charger Boost Sensor A Circuit Low
    P0238 Turbo/Super Charger Boost Sensor A Circuit High
    P0239 Turbo/Super Charger Boost Sensor B Circuit
    P0240 Turbo/Super Charger Boost Sensor B Circuit Range/Performance
    P0241 Turbo/Super Charger Boost Sensor B Circuit Low
    P0242 Turbo/Super Charger Boost Sensor B Circuit High
    P0243 Turbo/Super Charger Wastegate Solenoid A
    P0244 Turbo/Super Charger Wastegate Solenoid A Range/Performance
    P0245 Turbo/Super Charger Wastegate Solenoid A Low
    P0246 Turbo/Super Charger Wastegate Solenoid A High
    P0247 Turbo/Super Charger Wastegate Solenoid B
    P0248 Turbo/Super Charger Wastegate Solenoid B Range/Performance
    P0249 Turbo/Super Charger Wastegate Solenoid B Low
    P0250 Turbo/Super Charger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control A (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control A Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control A Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control A High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control A Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control B (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control B Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control B Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control B High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control B Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Balance
    P0297 Vehicle Overspeed Condition
    P0298 Engine Oil Over Temperature
    P0299 Turbo/Super Charger Underboost
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0310 Cylinder 10 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0313 Misfire Detected with Low Fuel
    P0314 Single Cylinder Misfire (Cylinder not Specified)
    P0315 Crankshaft Position System Variation Not Learned
    P0316 Engine Misfire Detected on Startup (First 1000 Revolutions)
    P0317 Rough Road Hardware Not Present
    P0318 Rough Road Sensor A Signal Circuit
    P0319 Rough Road Sensor B
    P0320 Ignition/Distributor Engine Speed Input Circuit
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0324 Knock Control System Error
    P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low (Bank 2)
    P0333 Knock Sensor 2 Circuit High (Bank 2)
    P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low
    P0338 Crankshaft Position Sensor A Circuit High
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor A Circuit (Bank 1 or Single Sensor)
    P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or Single Sensor)
    P0342 Camshaft Position Sensor A Circuit Low (Bank 1 or Single Sensor)
    P0343 Camshaft Position Sensor A Circuit High (Bank 1 or Single Sensor)
    P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or Single Sensor)
    P0345 Camshaft Position Sensor A Circuit (Bank 2)
    P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
    P0347 Camshaft Position Sensor A Circuit Low (Bank 2)
    P0348 Camshaft Position Sensor A Circuit High (Bank 2)
    P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
    P0350 Ignition Coil Primary/Secondary Circuit
    P0351 Ignition Coil A Primary/Secondary Circuit
    P0352 Ignition Coil B Primary/Secondary Circuit
    P0353 Ignition Coil C Primary/Secondary Circuit
    P0354 Ignition Coil D Primary/Secondary Circuit
    P0355 Ignition Coil E Primary/Secondary Circuit
    P0356 Ignition Coil F Primary/Secondary Circuit
    P0357 Ignition Coil G Primary/Secondary Circuit
    P0358 Ignition Coil H Primary/Secondary Circuit
    P0359 Ignition Coil I Primary/Secondary Circuit
    P0360 Ignition Coil J Primary/Secondary Circuit
    P0361 Ignition Coil K Primary/Secondary Circuit
    P0362 Ignition Coil L Primary/Secondary Circuit
    P0363 Misfire Detected Fuelling Disabled
    P0364 Reserved by SAE
    P0365 Camshaft Position Sensor B Circuit (Bank 1)
    P0366 Camshaft Position Sensor B Circuit Range/Performance (Bank 1)
    P0367 Camshaft Position Sensor B Circuit Low (Bank 1)
    P0368 Camshaft Position Sensor B Circuit High (Bank 1)
    P0369 Camshaft Position Sensor B Circuit Intermittent (Bank 1)
    P0370 Timing Reference High Resolution Signal A
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulse
    P0375 Timing Reference High Resolution Signal B
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit A
    P0381 Glow Plug/Heater Indicator Circuit
    P0382 Glow Plug/Heater Circuit B
    P0383 Reserved by SAE
    P0384 Reserved by SAE
    P0385 Crankshaft Position Sensor B Circuit
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low
    P0388 Crankshaft Position Sensor B Circuit High
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0390 Camshaft Position Sensor B Circuit (Bank 2)
    P0391 Camshaft Position Sensor B Circuit Range/Performance (Bank 2)
    P0392 Camshaft Position Sensor B Circuit Low (Bank 2)
    P0393 Camshaft Position Sensor B Circuit High (Bank 2)
    P0394 Camshaft Position Sensor B Circuit Intermittent (Bank 2)
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #2 เมื่อ: 22 พฤศจิกายน 2566, 08:38:49 »
  • P0400 Exhaust Gas Recirculation Flow
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Control Circuit
    P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0409 Exhaust Gas Recirculation Sensor A Circuit
    P0410 Secondary Air Injection System
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Control A Circuit
    P0419 Secondary Air Injection System Control B Circuit
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0425 Catalyst Temperature Sensor (Bank 1)
    P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
    P0427 Catalyst Temperature Sensor Low (Bank 1)
    P0428 Catalyst Temperature Sensor High (Bank 1)
    P0429 Catalyst Heater Control Circuit (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0435 Catalyst Temperature Sensor (Bank 2)
    P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
    P0437 Catalyst Temperature Sensor Low (Bank 2)
    P0438 Catalyst Temperature Sensor High (Bank 2)
    P0439 Catalyst Heater Control Circuit (Bank 2)
    P0440 Evaporative Emission System
    P0441 Evaporative Emission System Incorrect Purge Flow
    P0442 Evaporative Emission System Leak Detected (small leak)
    P0443 Evaporative Emission System Purge Control Valve Circuit
    P0444 Evaporative Emission System Purge Control Valve Circuit Open
    P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission System Vent Control Circuit
    P0447 Evaporative Emission System Vent Control Circuit Open
    P0448 Evaporative Emission System Vent Control Circuit Shorted
    P0449 Evaporative Emission System Vent Valve/Solenoid Circuit
    P0450 Evaporative Emission System Pressure Sensor/Switch
    P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
    P0452 Evaporative Emission System Pressure Sensor/Switch Low
    P0453 Evaporative Emission System Pressure Sensor/Switch High
    P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
    P0455 Evaporative Emission System Leak Detected (large leak)
    P0456 Evaporative Emission System Leak Detected (very small leak)
    P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
    P0458 Evaporative Emission System Purge Control Valve Circuit Low
    P0459 Evaporative Emission System Purge Control Valve Circuit High
    P0460 Fuel Level Sensor A Circuit
    P0461 Fuel Level Sensor A Circuit Range/Performance
    P0462 Fuel Level Sensor A Circuit Low
    P0463 Fuel Level Sensor A Circuit High
    P0464 Fuel Level Sensor A Circuit Intermittent
    P0465 EVAP Purge Flow Sensor Circuit
    P0466 EVAP Purge Flow Sensor Circuit Range/Performance
    P0467 EVAP Purge Flow Sensor Circuit Low
    P0468 EVAP Purge Flow Sensor Circuit High
    P0469 EVAP Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Fan 1 Control Circuit
    P0481 Fan 2 Control Circuit
    P0482 Fan 3 Control Circuit
    P0483 Fan Rationality Check
    P0484 Fan Circuit Over Current
    P0485 Fan Power/Ground Circuit
    P0486 Exhaust Gas Recirculation Sensor B Circuit
    P0487 Exhaust Gas Recirculation Throttle Position Control Circuit
    P0488 Exhaust Gas Recirculation Throttle Position Control Range/Performance
    P0489 Exhaust Gas Recirculation Control Circuit Low
    P0490 Exhaust Gas Recirculation Control Circuit High
    P0491 Secondary Air Injection System (Bank 1)
    P0492 Secondary Air Injection System (Bank 2)
    P0493 Fan Overspeed
    P0494 Fan Speed Low
    P0495 Fan Speed High
    P0496 Evaporative Emission System High Purge Flow
    P0497 Evaporative Emission System Low Purge Flow
    P0498 Evaporative Emission System Vent Valve Control Circuit Low
    P0499 Evaporative Emission System Vent Valve Control Circuit High
    P0500 Vehicle Speed Sensor A
    P0501 Vehicle Speed Sensor A Range/Performance
    P0502 Vehicle Speed Sensor A Circuit Low Input
    P0503 Vehicle Speed Sensor A Intermittent/Erratic/High
    P0504 Brake Switch A/B Correlation
    P0505 Idle Air Control System
    P0506 Idle Air Control System RPM Lower Than Expected
    P0507 Idle Air Control System RPM Higher Than Expected
    P0508 Idle Air Control System Circuit Low
    P0509 Idle Air Control System Circuit High
    P0510 Closed Throttle Position Switch
    P0511 Idle Air Control Circuit
    P0512 Starter Request Circuit
    P0513 Incorrect Immobilizer Key
    P0514 Battery Temperature Sensor Circuit Range/Performance
    P0515 Battery Temperature Sensor Circuit
    P0516 Battery Temperature Sensor Circuit Low
    P0517 Battery Temperature Sensor Circuit High
    P0518 Idle Air Control Circuit Intermittent
    P0519 Idle Air Control System Performance
    P0520 Engine Oil Pressure Sensor/Switch Circuit
    P0521 Engine Oil Pressure Sensor/Switch Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch High Voltage
    P0524 Engine Oil Pressure Too Low
    P0525 Cruise Control Servo Control Circuit Range/Performance
    P0526 Fan Speed Sensor Circuit
    P0527 Fan Speed Sensor Circuit Range/Performance
    P0528 Fan Speed Sensor Circuit No Signal
    P0529 Fan Speed Sensor Circuit Intermittent
    P0530 A/C Refrigerant Pressure Sensor A Circuit
    P0531 A/C Refrigerant Pressure Sensor A Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor A Circuit Low
    P0533 A/C Refrigerant Pressure Sensor A Circuit High
    P0534 Air Conditioner Refrigerant Charge Loss
    P0535 A/C Evaporator Temperature Sensor Circuit
    P0536 A/C Evaporator Temperature Sensor Circuit Range/Performance
    P0537 A/C Evaporator Temperature Sensor Circuit Low
    P0538 A/C Evaporator Temperature Sensor Circuit High
    P0539 A/C Evaporator Temperature Sensor Circuit Intermittent
    P0540 Intake Air Heater A Circuit
    P0541 Intake Air Heater A Circuit Low
    P0542 Intake Air Heater A Circuit High
    P0543 Intake Air Heater A Circuit Open
    P0544 Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 1)
    P0545 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 1)
    P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 1)
    P0547 Exhaust Gas Temperature Sensor Circuit (Bank 2 Sensor 1)
    P0548 Exhaust Gas Temperature Sensor Circuit Low (Bank 2 Sensor 1)
    P0549 Exhaust Gas Temperature Sensor Circuit High (Bank 2 Sensor 1)
    P0550 Power Steering Pressure Sensor/Switch Circuit
    P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
    P0552 Power Steering Pressure Sensor/Switch Circuit Low Input
    P0553 Power Steering Pressure Sensor/Switch Circuit High Input
    P0554 Power Steering Pressure Sensor/Switch Circuit Intermittent
    P0555 Brake Booster Pressure Sensor Circuit
    P0556 Brake Booster Pressure Sensor Circuit Range/Performance
    P0557 Brake Booster Pressure Sensor Circuit Low Input
    P0558 Brake Booster Pressure Sensor Circuit High Input
    P0559 Brake Booster Pressure Sensor Circuit Intermittent
    P0560 System Voltage
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0564 Cruise Control Multi-Function Input A Circuit
    P0565 Cruise Control On Signal
    P0566 Cruise Control Off Signal
    P0567 Cruise Control Resume Signal
    P0568 Cruise Control Set Signal
    P0569 Cruise Control Coast Signal
    P0570 Cruise Control Accelerate Signal
    P0571 Brake Switch A Circuit
    P0572 Brake Switch A Circuit Low
    P0573 Brake Switch A Circuit High
    P0574 Cruise Control System - Vehicle Speed Too High
    P0575 Cruise Control Input Circuit
    P0576 Cruise Control Input Circuit Low
    P0577 Cruise Control Input Circuit High
    P0578 Cruise Control Multi-Function Input A Circuit Stuck
    P0579 Cruise Control Multi-Function Input A Circuit Range/Performance
    P0580 Cruise Control Multi-Function Input A Circuit Low
    P0581 Cruise Control Multi-Function Input A Circuit High
    P0582 Cruise Control Vacuum Control Circuit/Open
    P0583 Cruise Control Vacuum Control Circuit Low
    P0584 Cruise Control Vacuum Control Circuit High
    P0585 Cruise Control Multi-Function Input A/B Correlation
    P0586 Cruise Control Vent Control Circuit/Open
    P0587 Cruise Control Vent Control Circuit Low
    P0588 Cruise Control Vent Control Circuit High
    P0589 Cruise Control Multi-Function Input B Circuit
    P0590 Cruise Control Multi-Function Input B Circuit Stuck
    P0591 Cruise Control Multi-Function Input B Circuit Range/Performance
    P0592 Cruise Control Multi-Function Input B Circuit Low
    P0593 Cruise Control Multi-Function Input B Circuit High
    P0594 Cruise Control Servo Control Circuit/Open
    P0595 Cruise Control Servo Control Circuit Low
    P0596 Cruise Control Servo Control Circuit High
    P0597 Thermostat Heater Control Circuit/Open
    P0598 Thermostat Heater Control Circuit Low
    P0599 Thermostat Heater Control Circuit High
    DTC Reference
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #3 เมื่อ: 22 พฤศจิกายน 2566, 08:39:36 »
  • P0600 Serial Communication Link
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Contro6Only Memory (ROM) Error (Module Identification Defined by ISO/15031-2/SAE J1930)
    P0606 ECM/PCM Processor
    P0607 Control Module Performance
    P0608 Control Module VSS Output A
    P0609 Control Module VSS Output B
    P0610 Control Module Vehicle Options Error
    P0611 Fuel Injector Control Module Performance
    P0612 Fuel Injector Control Module Relay Control
    P0613 TCM Processor
    P0614 ECM / TCM Incompatible
    P0615 Starter Relay Circuit
    P0616 Starter Relay Circuit Low
    P0617 Starter Relay Circuit High
    P0618 Alternative Fuel Control Module KAM Error
    P0619 Alternative Fuel Control Module RAM/ROM Error
    P0620 Generator Control Circuit
    P0621 Generator Lamp/L Terminal Circuit
    P0622 Generator Field/F Terminal Circuit
    P0623 Generator Lamp Control Circuit
    P0624 Fuel Cap Lamp Control Circuit
    P0625 Generator Field/F Terminal Circuit Low
    P0626 Generator Field/F Terminal Circuit High
    P0627 Fuel Pump A Control Circuit /Open
    P0628 Fuel Pump A Control Circuit Low
    P0629 Fuel Pump A Control Circuit High
    P0630 VIN Not Programmed or Incompatible ECM/PCM
    P0631 VIN Not Programmed or Incompatible TCM
    P0632 Odometer Not Programmed ECM/PCM
    P0633 Immobilizer Key Not Programmed ECM/PCM
    P0634 PCM/ECM/TCM Internal Temperature Too High
    P0635 Power Steering Control Circuit
    P0636 Power Steering Control Circuit Low
    P0637 Power Steering Control Circuit High
    P0638 Throttle Actuator Control Range/Performance (Bank 1)
    P0639 Throttle Actuator Control Range/Performance (Bank 2)
    P0640 Intake Air Heater Control Circuit
    P0641 Sensor Reference Voltage A Circuit/Open
    P0642 Sensor Reference Voltage A Circuit Low
    P0643 Sensor Reference Voltage A Circuit High
    P0644 Driver Display Serial Communication Circuit
    P0645 A/C Clutch Relay Control Circuit
    P0646 A/C Clutch Relay Control Circuit Low
    P0647 A/C Clutch Relay Control Circuit High
    P0648 Immobilizer Lamp Control Circuit
    P0649 Speed Control Lamp Control Circuit
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit
    P0651 Sensor Reference Voltage B Circuit/Open
    P0652 Sensor Reference Voltage B Circuit Low
    P0653 Sensor Reference Voltage B Circuit High
    P0654 Engine RPM Output Circuit
    P0655 Engine Hot Lamp Output Control Circuit
    P0656 Fuel Level Output Circuit
    P0657 Actuator Supply Voltage Circuit/Open
    P0658 Actuator Supply Voltage Circuit Low
    P0659 Actuator Supply Voltage Circuit High
    P0660 Intake Manifold Tuning Valve Control Circuit/Open (Bank 1)
    P0661 Intake Manifold Tuning Valve Control Circuit Low (Bank 1)
    P0662 Intake Manifold Tuning Valve Control Circuit High (Bank 1)
    P0663 Intake Manifold Tuning Valve Control Circuit/Open (Bank 2)
    P0664 Intake Manifold Tuning Valve Control Circuit Low (Bank 2)
    P0665 Intake Manifold Tuning Valve Control Circuit High (Bank 2)
    P0666 PCM/ECM/TCM Internal Temperature Sensor Circuit
    P0667 PCM/ECM/TCM Internal Temperature Sensor Range/Performance
    P0668 PCM/ECM/TCM Internal Temperature Sensor Circuit Low
    P0669 PCM/ECM/TCM Internal Temperature Sensor Circuit High
    P0670 Glow Plug Module Control Circuit
    P0671 Cylinder 1 Glow Plug Circuit
    P0672 Cylinder 2 Glow Plug Circuit
    P0673 Cylinder 3 Glow Plug Circuit
    P0674 Cylinder 4 Glow Plug Circuit
    P0675 Cylinder 5 Glow Plug Circuit
    P0676 Cylinder 6 Glow Plug Circuit
    P0677 Cylinder 7 Glow Plug Circuit
    P0678 Cylinder 8 Glow Plug Circuit
    P0679 Reserved by SAE for future glow plug 9
    P0680 Reserved by SAE for future glow plug 10
    P0681 Reserved by SAE for future glow plug 11
    P0682 Reserved by SAE for future glow plug 12
    P0683 Glow Plug Control Module to PCM Communication Circuit
    P0684 Glow Plug Control Module to PCM Communication Circuit Range/Performance
    P0685 ECM/PCM Power Relay Control Circuit /Open
    P0686 ECM/PCM Power Relay Control Circuit Low
    P0687 ECM/PCM Power Relay Control Circuit High
    P0688 ECM/PCM Power Relay Sense Circuit /Open
    P0689 ECM/PCM Power Relay Sense Circuit Low
    P0690 ECM/PCM Power Relay Sense Circuit High
    P0691 Fan 1 Control Circuit Low
    P0692 Fan 1 Control Circuit High
    P0693 Fan 2 Control Circuit Low
    P0694 Fan 2 Control Circuit High
    P0695 Fan 3 Control Circuit Low
    P0696 Fan 3 Control Circuit High
    P0697 Sensor Reference Voltage C Circuit/Open
    P0698 Sensor Reference Voltage C Circuit Low
    P0699 Sensor Reference Voltage C Circuit High
    P0700 Transmission Control System (MIL Request)
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Brake Switch B Circuit
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low
    P0708 Transmission Range Sensor Circuit High
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor A Circuit
    P0711 Transmission Fluid Temperature Sensor A Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor A Circuit Low
    P0713 Transmission Fluid Temperature Sensor A Circuit High
    P0714 Transmission Fluid Temperature Sensor A Circuit Intermittent
    P0715 Input/Turbine Speed Sensor A Circuit
    P0716 Input/Turbine Speed Sensor A Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor A Circuit No Signal
    P0718 Input/Turbine Speed Sensor A Circuit Intermittent
    P0719 Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit
    P0721 Output Speed Sensor Circuit Range/Performance
    P0722 Output Speed Sensor Circuit No Signal
    P0723 Output Speed Sensor Circuit Intermittent
    P0724 Brake Switch B Circuit High
    P0725 Engine Speed Input Circuit
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0729 Gear 6 Incorrect Ratio
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect Ratio
    P0732 Gear 2 Incorrect Ratio
    P0733 Gear 3 Incorrect Ratio
    P0734 Gear 4 Incorrect Ratio
    P0735 Gear 5 Incorrect Ratio
    P0736 Reverse Incorrect Ratio
    P0737 TCM Engine Speed Output Circuit
    P0738 TCM Engine Speed Output Circuit Low
    P0739 TCM Engine Speed Output Circuit High
    P0740 Torque Converter Clutch Circuit/Open
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid A
    P0746 Pressure Control Solenoid A Performance or Stuck Off
    P0747 Pressure Control Solenoid A Stuck On
    P0748 Pressure Control Solenoid A Electrical
    P0749 Pressure Control Solenoid A Intermittent
    P0750 Shift Solenoid A
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0775 Pressure Control Solenoid B
    P0776 Pressure Control Solenoid B Performance or Stuck off
    P0777 Pressure Control Solenoid B Stuck On
    P0778 Pressure Control Solenoid B Electrical
    P0779 Pressure Control Solenoid B Intermittent
    P0780 Shift Error
    P0781 1-2 Shift
    P0782 2-3 Shift
    P0783 3-4 Shift
    P0784 4-5 Shift
    P0785 Shift/Timing Solenoid
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit
    P0791 Intermediate Shaft Speed Sensor A Circuit
    P0792 Intermediate Shaft Speed Sensor A Circuit Range/Performance
    P0793 Intermediate Shaft Speed Sensor A Circuit No Signal
    P0794 Intermediate Shaft Speed Sensor A Circuit Intermittent
    P0795 Pressure Control Solenoid C
    P0796 Pressure Control Solenoid C Performance or Stuck off
    P0797 Pressure Control Solenoid C Stuck On
    P0798 Pressure Control Solenoid C Electrical
    P0799 Pressure Control Solenoid C Intermittent
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #4 เมื่อ: 22 พฤศจิกายน 2566, 08:40:14 »
  • P0800 Transfer Case Control System (MIL Request)
    P0801 Reverse Inhibit Control Circuit
    P0802 Transmission Control System MIL Request Circuit/Open
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit
    P0805 Clutch Position Sensor Circuit
    P0806 Clutch Position Sensor Circuit Range/Performance
    P0807 Clutch Position Sensor Circuit Low
    P0808 Clutch Position Sensor Circuit High
    P0809 Clutch Position Sensor Circuit Intermittent
    P0810 Clutch Position Control Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circuit
    P0813 Reverse Output Circuit
    P0814 Transmission Range Display Circuit
    P0815 Upshift Switch Circuit
    P0816 Downshift Switch Circuit
    P0817 Starter Disable Circuit
    P0818 Driveline Disconnect Switch Input Circuit
    P0819 Up and Down Shift Switch to Transmission Range Correlation
    P0820 Gear Lever X-Y Position Sensor Circuit
    P0821 Gear Lever X Position Circuit
    P0822 Gear Lever Y Position Circuit
    P0823 Gear Lever X Position Circuit Intermittent
    P0824 Gear Lever Y Position Circuit Intermittent
    P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
    P0826 Up and Down Shift Switch Circuit
    P0827 Up and Down Shift Switch Circuit Low
    P0828 Up and Down Shift Switch Circuit High
    P0829 5-6 Shift
    P0830 Clutch Pedal Switch A Circuit
    P0831 Clutch Pedal Switch A Circuit Low
    P0832 Clutch Pedal Switch A Circuit High
    P0833 Clutch Pedal Switch B Circuit
    P0834 Clutch Pedal Switch B Circuit Low
    P0835 Clutch Pedal Switch B Circuit High
    P0836 Four Wheel Drive (4WD) Switch Circuit
    P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
    P0838 Four Wheel Drive (4WD) Switch Circuit Low
    P0839 Four Wheel Drive (4WD) Switch Circuit High
    P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
    P0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
    P0842 Transmission Fluid Pressure Sensor/Switch A Circuit Low
    P0843 Transmission Fluid Pressure Sensor/Switch A Circuit High
    P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
    P0845 Transmission Fluid Pressure Sensor/Switch B Circuit
    P0846 Transmission Fluid Pressure Sensor/Switch B Circuit Range/Performance
    P0847 Transmission Fluid Pressure Sensor/Switch B Circuit Low
    P0848 Transmission Fluid Pressure Sensor/Switch B Circuit High
    P0849 Transmission Fluid Pressure Sensor/Switch B Circuit Intermittent
    P0850 Park/Neutral Switch Input Circuit
    P0851 Park/Neutral Switch Input Circuit Low
    P0852 Park/Neutral Switch Input Circuit High
    P0853 Drive Switch Input Circuit
    P0854 Drive Switch Input Circuit Low
    P0855 Drive Switch Input Circuit High
    P0856 Traction Control Input Signal
    P0857 Traction Control Input Signal Range/Performance
    P0858 Traction Control Input Signal Low
    P0859 Traction Control Input Signal High
    P0860 Gear Shift Module Communication Circuit
    P0861 Gear Shift Module Communication Circuit Low
    P0862 Gear Shift Module Communication Circuit High
    P0863 TCM Communication Circuit
    P0864 TCM Communication Circuit Range/Performance
    P0865 TCM Communication Circuit Low
    P0866 TCM Communication Circuit High
    P0867 Transmission Fluid Pressure
    P0868 Transmission Fluid Pressure Low
    P0869 Transmission Fluid Pressure High
    P0870 Transmission Fluid Pressure Sensor/Switch C Circuit
    P0871 Transmission Fluid Pressure Sensor/Switch C Circuit Range/Performance
    P0872 Transmission Fluid Pressure Sensor/Switch C Circuit Low
    P0873 Transmission Fluid Pressure Sensor/Switch C Circuit High
    P0874 Transmission Fluid Pressure Sensor/Switch C Circuit Intermittent
    P0875 Transmission Fluid Pressure Sensor/Switch D Circuit
    P0876 Transmission Fluid Pressure Sensor/Switch D Circuit Range/Performance
    P0877 Transmission Fluid Pressure Sensor/Switch D Circuit Low
    P0878 Transmission Fluid Pressure Sensor/Switch D Circuit High
    P0879 Transmission Fluid Pressure Sensor/Switch D Circuit Intermittent
    P0880 TCM Power Input Signal
    P0881 TCM Power Input Signal Range/Performance
    P0882 TCM Power Input Signal Low
    P0883 TCM Power Input Signal High
    P0884 TCM Power Input Signal Intermittent
    P0885 TCM Power Relay Control Circuit/Open
    P0886 TCM Power Relay Control Circuit Low
    P0887 TCM Power Relay Control Circuit High
    P0888 TCM Power Relay Sense Circuit
    P0889 TCM Power Relay Sense Circuit Range/Performance
    P0890 TCM Power Relay Sense Circuit Low
    P0891 TCM Power Relay Sense Circuit High
    P0892 TCM Power Relay Sense Circuit Intermittent
    P0893 Multiple Gears Engaged
    P0894 Transmission Component Slipping
    P0895 Shift Time Too Short
    P0896 Shift Time Too Long
    P0897 Transmission Fluid Deteriorated
    P0898 Transmission Control System MIL Request Circuit Low
    P0899 Transmission Control System MIL Request Circuit High
    P0900 Clutch Actuator Circuit/Open
    P0901 Clutch Actuator Circuit Range/Performance
    P0902 Clutch Actuator Circuit Low
    P0903 Clutch Actuator Circuit High
    P0904 Gate Select Position Circuit
    P0905 Gate Select Position Circuit Range/Performance
    P0906 Gate Select Position Circuit Low
    P0907 Gate Select Position Circuit High
    P0908 Gate Select Position Circuit Intermittent
    P0909 Gate Select Control Error
    P0910 Gate Select Actuator Circuit/Open
    P0911 Gate Select Actuator Circuit Range/Performance
    P0912 Gate Select Actuator Circuit Low
    P0913 Gate Select Actuator Circuit High
    P0914 Gear Shift Position Circuit
    P0915 Gear Shift Position Circuit Range/Performance
    P0916 Gear Shift Position Circuit Low
    P0917 Gear Shift Position Circuit High
    P0918 Gear Shift Position Circuit Intermittent
    P0919 Gear Shift Position Control Error
    P0920 Gear Shift Forward Actuator Circuit/Open
    P0921 Gear Shift Forward Actuator Circuit Range/Performance
    P0922 Gear Shift Forward Actuator Circuit Low
    P0923 Gear Shift Forward Actuator Circuit High
    P0924 Gear Shift Reverse Actuator Circuit/Open
    P0925 Gear Shift Reverse Actuator Circuit Range/Performance
    P0926 Gear Shift Reverse Actuator Circuit Low
    P0927 Gear Shift Reverse Actuator Circuit High
    P0928 Gear Shift Lock Solenoid Control Circuit/Open
    P0929 Gear Shift Lock Solenoid Control Circuit Range/Performance
    P0930 Gear Shift Lock Solenoid Control Circuit Low
    P0931 Gear Shift Lock Solenoid Control Circuit High
    P0932 Hydraulic Pressure Sensor Circuit
    P0933 Hydraulic Pressure Sensor Range/Performance
    P0934 Hydraulic Pressure Sensor Circuit Low
    P0935 Hydraulic Pressure Sensor Circuit High
    P0936 Hydraulic Pressure Sensor Circuit Intermittent
    P0937 Hydraulic Oil Temperature Sensor Circuit
    P0938 Hydraulic Oil Temperature Sensor Range/Performance
    P0939 Hydraulic Oil Temperature Sensor Circuit Low
    P0940 Hydraulic Oil Temperature Sensor Circuit High
    P0941 Hydraulic Oil Temperature Sensor Circuit Intermittent
    P0942 Hydraulic Pressure Unit
    P0943 Hydraulic Pressure Unit Cycling Period Too Short
    P0944 Hydraulic Pressure Unit Loss of Pressure
    P0945 Hydraulic Pump Relay Circuit/Open
    P0946 Hydraulic Pump Relay Circuit Range/Performance
    P0947 Hydraulic Pump Relay Circuit Low
    P0948 Hydraulic Pump Relay Circuit High
    P0949 Auto Shift Manual Adaptive Learning Not Complete
    P0950 Auto Shift Manual Control Circuit
    P0951 Auto Shift Manual Control Circuit Range/Performance
    P0952 Auto Shift Manual Control Circuit Low
    P0953 Auto Shift Manual Control Circuit High
    P0954 Auto Shift Manual Control Circuit Intermittent
    P0955 Auto Shift Manual Mode Circuit
    P0956 Auto Shift Manual Mode Circuit Range/Performance
    P0957 Auto Shift Manual Mode Circuit Low
    P0958 Auto Shift Manual Mode Circuit High
    P0959 Auto Shift Manual Mode Circuit Intermittent
    P0960 Pressure Control Solenoid A Control Circuit/Open
    P0961 Pressure Control Solenoid A Control Circuit Range/Performance
    P0962 Pressure Control Solenoid A Control Circuit Low
    P0963 Pressure Control Solenoid A Control Circuit High
    P0964 Pressure Control Solenoid B Control Circuit/Open
    P0965 Pressure Control Solenoid B Control Circuit Range/Performance
    P0966 Pressure Control Solenoid B Control Circuit Low
    P0967 Pressure Control Solenoid B Control Circuit High
    P0968 Pressure Control Solenoid C Control Circuit/Open
    P0969 Pressure Control Solenoid C Control Circuit Range/Performance
    P0970 Pressure Control Solenoid C Control Circuit Low
    P0971 Pressure Control Solenoid C Control Circuit High
    P0972 Shift Solenoid A Control Circuit Range/Performance
    P0973 Shift Solenoid A Control Circuit Low
    P0974 Shift Solenoid A Control Circuit High
    P0975 Shift Solenoid B Control Circuit Range/Performance
    P0976 Shift Solenoid B Control Circuit Low
    P0977 Shift Solenoid B Control Circuit High
    P0978 Shift Solenoid C Control Circuit Range/Performance
    P0979 Shift Solenoid C Control Circuit Low
    P0980 Shift Solenoid C Control Circuit High
    P0981 Shift Solenoid D Control Circuit Range/Performance
    P0982 Shift Solenoid D Control Circuit Low
    P0983 Shift Solenoid D Control Circuit High
    P0984 Shift Solenoid E Control Circuit Range/Performance
    P0985 Shift Solenoid E Control Circuit Low
    P0986 Shift Solenoid E Control Circuit High
    P0987 Transmission Fluid Pressure Sensor/Switch E Circuit
    P0988 Transmission Fluid Pressure Sensor/Switch E Circuit Range/Performance
    P0989 Transmission Fluid Pressure Sensor/Switch E Circuit Low
    P0990 Transmission Fluid Pressure Sensor/Switch E Circuit High
    P0991 Transmission Fluid Pressure Sensor/Switch E Circuit Intermittent
    P0992 Transmission Fluid Pressure Sensor/Switch F Circuit
    P0993 Transmission Fluid Pressure Sensor/Switch F Circuit Range/Performance
    P0994 Transmission Fluid Pressure Sensor/Switch F Circuit Low
    P0995 Transmission Fluid Pressure Sensor/Switch F Circuit High
    P0996 Transmission Fluid Pressure Sensor/Switch F Circuit Intermittent
    P0997 Shift Solenoid F Control Circuit Range/Performance
    P0998 Shift Solenoid F Control Circuit Low
    P0999 Shift Solenoid F Control Circuit High
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #5 เมื่อ: 22 พฤศจิกายน 2566, 08:40:58 »
  • P0A00 Motor Electronics Coolant Temperature Sensor Circuit
    P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance
    P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low
    P0A03 Motor Electronics Coolant Temperature Sensor Circuit High
    P0A04 Motor Electronics Coolant Temperature Sensor Circuit Intermittent
    P0A05 Motor Electronics Coolant Pump Control Circuit/Open
    P0A06 Motor Electronics Coolant Pump Control Circuit Low
    P0A07 Motor Electronics Coolant Pump Control Circuit High
    P0A08 DC/DC Converter Status Circuit
    P0A09 DC/DC Converter Status Circuit Low Input
    P0A10 DC/DC Converter Status Circuit High Input
    P0A11 DC/DC Converter Enable Circuit/Open
    P0A12 DC/DC Converter Enable Circuit Low
    P0A13 DC/DC Converter Enable Circuit High
    P0A14 Engine Mount Control Circuit/Open
    P0A15 Engine Mount Control Circuit Low
    P0A16 Engine Mount Control Circuit High
    P0A17 Motor Torque Sensor Circuit
    P0A18 Motor Torque Sensor Circuit Range/Performance
    P0A19 Motor Torque Sensor Circuit Low
    P0A20 Motor Torque Sensor Circuit High
    P0A21 Motor Torque Sensor Circuit Intermittent
    P0A22 Generator Torque Sensor Circuit
    P0A23 Generator Torque Sensor Circuit Range/Performance
    P0A24 Generator Torque Sensor Circuit Low
    P0A25 Generator Torque Sensor Circuit High
    P0A26 Generator Torque Sensor Circuit Intermittent
    P0A27 Battery Power Off Circuit
    P0A28 Battery Power Off Circuit Low
    P0A29 Battery Power Off Circuit High
    P2000 NOx Trap Efficiency Below Threshold (Bank 1)
    P2001 NOx Trap Efficiency Below Threshold (Bank 2)
    P2002 Particulate Trap Efficiency Below Threshold (Bank 1)
    P2003 Particulate Trap Efficiency Below Threshold (Bank 2)
    P2004 Intake Manifold Runner Control Stuck Open (Bank 1)
    P2005 Intake Manifold Runner Control Stuck Open (Bank 2)
    P2006 Intake Manifold Runner Control Stuck Closed (Bank 1)
    P2007 Intake Manifold Runner Control Stuck Closed (Bank 2)
    P2008 Intake Manifold Runner Control Circuit/Open (Bank 1)
    P2009 Intake Manifold Runner Control Circuit Low (Bank 1)
    P2010 Intake Manifold Runner Control Circuit High (Bank 1)
    P2011 Intake Manifold Runner Control Circuit/Open (Bank 2)
    P2012 Intake Manifold Runner Control Circuit Low (Bank 2)
    P2013 Intake Manifold Runner Control Circuit High (Bank 2)
    P2014 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
    P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 1)
    P2016 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 1)
    P2017 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 1)
    P2018 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 1)
    P2019 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
    P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 2)
    P2021 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 2)
    P2022 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 2)
    P2023 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 2)
    P2024 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit
    P2025 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Performance
    P2026 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit Low Voltage
    P2027 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit High Voltage
    P2028 Evaporative Emissions (EVAP) Fuel Vapor Temperature Sensor Circuit Intermittent
    P2029 Fuel Fired Heater Disabled
    P2030 Fuel Fired Heater Performance
    P2031 Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 2)
    P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2)
    P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
    P2034 Exhaust Gas Temperature Sensor Circuit (Bank 2 Sensor 2)
    P2035 Exhaust Gas Temperature Sensor Circuit Low (Bank 2 Sensor 2)
    P2036 Exhaust Gas Temperature Sensor Circuit High (Bank 2 Sensor 2)
    P2037 Reductant Injection Air Pressure Sensor Circuit
    P2038 Reductant Injection Air Pressure Sensor Circuit Range/Performance
    P2039 Reductant Injection Air Pressure Sensor Circuit Low Input
    P2040 Reductant Injection Air Pressure Sensor Circuit High Input
    P2041 Reductant Injection Air Pressure Sensor Circuit Intermittent
    P2042 Reductant Temperature Sensor Circuit
    P2043 Reductant Temperature Sensor Circuit Range/Performance
    P2044 Reductant Temperature Sensor Circuit Low Input
    P2045 Reductant Temperature Sensor Circuit High Input
    P2046 Reductant Temperature Sensor Circuit Intermittent
    P2047 Reductant Injector Circuit/Open (Bank 1 Unit 1)
    P2048 Reductant Injector Circuit Low (Bank 1 Unit 1)
    P2049 Reductant Injector Circuit High (Bank 1 Unit 1)
    P2050 Reductant Injector Circuit/Open (Bank 2 Unit 1)
    P2051 Reductant Injector Circuit Low (Bank 2 Unit 1)
    P2052 Reductant Injector Circuit High (Bank 2 Unit 1)
    P2053 Reductant Injector Circuit/Open (Bank 1 Unit 2)
    P2054 Reductant Injector Circuit Low (Bank 1 Unit 2)
    P2055 Reductant Injector Circuit High (Bank 1 Unit 2)
    P2056 Reductant Injector Circuit/Open (Bank 2 Unit 2)
    P2057 Reductant Injector Circuit Low (Bank 2 Unit 2
    P2058 Reductant Injector Circuit High (Bank 2 Unit 2)
    P2059 Reductant Injection Air Pump Control Circuit/Open
    P2060 Reductant Injection Air Pump Control Circuit Low
    P2061 Reductant Injection Air Pump Control Circuit High
    P2062 Reductant Supply Control Circuit/Open
    P2063 Reductant Supply Control Circuit Low
    P2064 Reductant Supply Control Circuit High
    P2065 Fuel Level Sensor B Circuit
    P2066 Fuel Level Sensor B Performance
    P2067 Fuel Level Sensor B Circuit Low
    P2068 Fuel Level Sensor B Circuit High
    P2069 Fuel Level Sensor B Circuit Intermittent
    P2070 Intake Manifold Tuning (IMT) Valve Stuck Open
    P2071 Intake Manifold Tuning (IMT) Valve Stuck Closed
    P2075 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit
    P2076 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Range/Performance
    P2077 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Low
    P2078 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit High
    P2079 Intake Manifold Tuning (IMT) Valve Position Sensor/Switch Circuit Intermittent
    P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    P2081 Exhaust Gas Temperature Sensor Circuit Intermittent (Bank 1 Sensor 1)
    P2082 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 2 Sensor 1)
    P2083 Exhaust Gas Temperature Sensor Circuit Intermittent (Bank 2 Sensor 1)
    P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 1 Sensor 2)
    P2085 Exhaust Gas Temperature Sensor Circuit Intermittent (Bank 1 Sensor 2)
    P2086 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 2 Sensor 2)
    P2087 Exhaust Gas Temperature Sensor Circuit Intermittent (Bank 2 Sensor 2)
    P2088 A Camshaft Position Actuator Control Circuit Low (Bank 1)
    P2089 A Camshaft Position Actuator Control Circuit High (Bank 1)
    P2090 B Camshaft Position Actuator Control Circuit Low (Bank 1)
    P2091 B Camshaft Position Actuator Control Circuit High (Bank 1)
    P2092 A Camshaft Position Actuator Control Circuit Low (Bank 2)
    P2093 A Camshaft Position Actuator Control Circuit High (Bank 2)
    P2094 B Camshaft Position Actuator Control Circuit Low (Bank 2)
    P2095 B Camshaft Position Actuator Control Circuit High (Bank 2)
    P2096 Post Catalyst Fuel Trim System Too Lean (Bank 1)
    P2097 Post Catalyst Fuel Trim System Too Rich (Bank 1)
    P2098 Post Catalyst Fuel Trim System Too Lean (Bank 2)
    P2099 Post Catalyst Fuel Trim System Too Rich (Bank 2)
    P2100 Throttle Actuator Control Motor Circuit/Open
    P2101 Throttle Actuator Control Motor Circuit Range/Performance
    P2102 Throttle Actuator Control Motor Circuit Low
    P2103 Throttle Actuator Control Motor Circuit High
    P2104 Throttle Actuator Control System - Forced Idle
    P2105 Throttle Actuator Control System - Forced Engine Shutdown
    P2106 Throttle Actuator Control System - Forced Limited Power
    P2107 Throttle Actuator Control Module Processor
    P2108 Throttle Actuator Control Module Performance
    P2109 Throttle/Pedal Position Sensor A Minimum Stop Performance
    P2110 Throttle Actuator Control System - Forced Limited RPM
    P2111 Throttle Actuator Control System - Stuck Open
    P2112 Throttle Actuator Control System - Stuck Closed
    P2113 Throttle/Pedal Position Sensor B Minimum Stop Performance
    P2114 Throttle/Pedal Position Sensor C Minimum Stop Performance
    P2115 Throttle/Pedal Position Sensor D Minimum Stop Performance
    P2116 Throttle/Pedal Position Sensor E Minimum Stop Performance
    P2117 Throttle/Pedal Position Sensor F Minimum Stop Performance
    P2118 Throttle Actuator Control Motor Current Range/Performance
    P2119 Throttle Actuator Control Throttle Body Range/Performance
    P2120 Throttle/Pedal Position Sensor/Switch D Circuit
    P2121 Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance
    P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
    P2123 Throttle/Pedal Position Sensor/Switch D Circuit High Input
    P2124 Throttle/Pedal Position Sensor/Switch D Circuit Intermittent
    P2125 Throttle/Pedal Position Sensor/Switch E Circuit
    P2126 Throttle/Pedal Position Sensor/Switch E Circuit Range/Performance
    P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
    P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
    P2129 Throttle/Pedal Position Sensor/Switch E Circuit Intermittent
    P2130 Throttle/Pedal Position Sensor/Switch F Circuit
    P2131 Throttle/Pedal Position Sensor/Switch F Circuit Range Performance
    P2132 Throttle/Pedal Position Sensor/Switch F Circuit Low Input
    P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
    P2134 Throttle/Pedal Position Sensor/Switch F Circuit Intermittent
    P2135 Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation
    P2136 Throttle/Pedal Position Sensor/Switch A / C Voltage Correlation
    P2137 Throttle/Pedal Position Sensor/Switch B / C Voltage Correlation
    P2138 Throttle/Pedal Position Sensor/Switch D / E Voltage Correlation
    P2139 Throttle/Pedal Position Sensor/Switch D / F Voltage Correlation
    P2140 Throttle/Pedal Position Sensor/Switch E / F Voltage Correlation
    P2141 Exhaust Gas Recirculation Throttle Control Circuit Low
    P2142 Exhaust Gas Recirculation Throttle Control Circuit High
    P2143 Exhaust Gas Recirculation Vent Control Circuit/Open
    P2144 Exhaust Gas Recirculation Vent Control Circuit Low
    P2145 Exhaust Gas Recirculation Vent Control Circuit High
    P2146 Fuel Injector Group A Supply Voltage Circuit/Open
    P2147 Fuel Injector Group A Supply Voltage Circuit Low
    P2148 Fuel Injector Group A Supply Voltage Circuit High
    P2149 Fuel Injector Group B Supply Voltage Circuit/Open
    P2150 Fuel Injector Group B Supply Voltage Circuit Low
    P2151 Fuel Injector Group B Supply Voltage Circuit High
    P2152 Fuel Injector Group C Supply Voltage Circuit/Open
    P2153 Fuel Injector Group C Supply Voltage Circuit Low
    P2154 Fuel Injector Group C Supply Voltage Circuit High
    P2155 Fuel Injector Group D Supply Voltage Circuit/Open
    P2156 Fuel Injector Group D Supply Voltage Circuit Low
    P2157 Fuel Injector Group D Supply Voltage Circuit High
    P2158 Vehicle Speed Sensor B
    P2159 Vehicle Speed Sensor B Range/Performance
    P2160 Vehicle Speed Sensor B Circuit Low
    P2161 Vehicle Speed Sensor B Intermittent/Erratic
    P2162 Vehicle Speed Sensor A / B Correlation
    P2163 Throttle/Pedal Position Sensor A Maximum Stop Performance
    P2164 Throttle/Pedal Position Sensor B Maximum Stop Performance
    P2165 Throttle/Pedal Position Sensor C Maximum Stop Performance
    P2166 Throttle/Pedal Position Sensor D Maximum Stop Performance
    P2167 Throttle/Pedal Position Sensor E Maximum Stop Performance
    P2168 Throttle/Pedal Position Sensor F Maximum Stop Performance
    P2169 Exhaust Pressure Regulator Vent Solenoid Control Circuit/Open
    P2170 Exhaust Pressure Regulator Vent Solenoid Control Circuit Low
    P2171 Exhaust Pressure Regulator Vent Solenoid Control Circuit High
    P2172 Throttle Actuator Control System Sudden High Airflow Detected
    P2173 Throttle Actuator Control System High Airflow Detected
    P2174 Throttle Actuator Control System Sudden Low Airflow Detected
    P2175 Throttle Actuator Control System Low Airflow Detected
    P2176 Throttle Actuator Control System Idle Position Not Learned
    P2177 System Too Lean Off Idle (Bank 1)
    P2178 System Too Rich Off Idle (Bank 1)
    P2179 System Too Lean Off Idle (Bank 2)
    P2180 System Too Rich Off Idle (Bank 2)
    P2181 Cooling System Performance
    P2182 Engine Coolant Temperature Sensor 2 Circuit
    P2183 Engine Coolant Temperature Sensor 2 Circuit Range/Performance
    P2184 Engine Coolant Temperature Sensor 2 Circuit Low
    P2185 Engine Coolant Temperature Sensor 2 Circuit High
    P2186 Engine Coolant Temperature Sensor 2 Circuit Intermittent/Erratic
    P2187 System Too Lean at Idle (Bank 1)
    P2188 System Too Rich at Idle (Bank 1)
    P2189 System Too Lean at Idle (Bank 2)
    P2190 System Too Rich at Idle (Bank 2)
    P2191 System Too Lean at Higher Load (Bank 1)
    P2192 System Too Rich at Higher Load (Bank 1)
    P2193 System Too Lean at Higher Load (Bank 2)
    P2194 System Too Rich at Higher Load (Bank 2)
    P2195 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 1)
    P2196 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1)
    P2197 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 1)
    P2198 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 1)
    P2199 Intake Air Temperature Sensor 1 / 2 Correlation
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #6 เมื่อ: 22 พฤศจิกายน 2566, 08:42:00 »
  • P2200 NOx Sensor Circuit (Bank 1)
    P2201 NOx Sensor Circuit Range/Performance (Bank 1)
    P2202 NOx Sensor Circuit Low Input (Bank 1)
    P2203 NOx Sensor Circuit High Input (Bank 1)
    P2204 NOx Sensor Circuit Intermittent Input (Bank 1)
    P2205 NOx Sensor Heater Control Circuit/Open (Bank 1)
    P2206 NOx Sensor Heater Control Circuit Low (Bank 1)
    P2207 NOx Sensor Heater Control Circuit High (Bank 1)
    P2208 NOx Sensor Heater Sense Circuit (Bank 1)
    P2209 NOx Sensor Heater Sense Circuit Range/Performance (Bank 1)
    P2210 NOx Sensor Heater Sense Circuit Low Input (Bank 1)
    P2211 NOx Sensor Heater Sense Circuit High Input (Bank 1)
    P2212 NOx Sensor Heater Sense Circuit Intermittent (Bank 1)
    P2213 NOx Sensor Circuit (Bank 2)
    P2214 NOx Sensor Circuit Range/Performance (Bank 2)
    P2215 NOx Sensor Circuit Low Input (Bank 2)
    P2216 NOx Sensor Circuit High Input (Bank 2)
    P2217 NOx Sensor Circuit Intermittent Input (Bank 2)
    P2218 NOx Sensor Heater Control Circuit/Open (Bank 2)
    P2219 NOx Sensor Heater Control Circuit Low (Bank 2)
    P2220 NOx Sensor Heater Control Circuit High (Bank 2)
    P2221 NOx Sensor Heater Sense Circuit (Bank 2)
    P2222 NOx Sensor Heater Sense Circuit Range/Performance (Bank 2)
    P2223 NOx Sensor Heater Sense Circuit Low (Bank 2)
    P2224 NOx Sensor Heater Sense Circuit High (Bank 2)
    P2225 NOx Sensor Heater Sense Circuit Intermittent (Bank 2)
    P2226 Barometric Pressure Circuit
    P2227 Barometric Pressure Circuit Range/Performance
    P2228 Barometric Pressure Circuit Low
    P2229 Barometric Pressure Circuit High
    P2230 Barometric Pressure Circuit Intermittent
    P2231 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 1 Sensor 1)
    P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 1 Sensor 2)
    P2233 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 1 Sensor 3)
    P2234 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 2 Sensor 1)
    P2235 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 2 Sensor 2)
    P2236 O2 Sensor Signal Circuit Shorted to Heater Circuit (Bank 2 Sensor 3)
    P2237 O2 Sensor Pumping Current Circuit/Open (Bank 1 Sensor 1)
    P2238 O2 Sensor Pumping Current Circuit Low (Bank 1 Sensor 1)
    P2239 O2 Sensor Pumping Current Circuit High (Bank 1 Sensor 1)
    P2240 O2 Sensor Pumping Current Circuit/Open (Bank 2 Sensor 1)
    P2241 O2 Sensor Pumping Current Circuit Low (Bank 2 Sensor 1)
    P2242 O2 Sensor Pumping Current Circuit High (Bank 2 Sensor 1)
    P2243 O2 Sensor Reference Voltage Circuit/Open (Bank 1 Sensor 1)
    P2244 O2 Sensor Reference Voltage Performance (Bank 1 Sensor 1)
    P2245 O2 Sensor Reference Voltage Circuit Low (Bank 1 Sensor 1)
    P2246 O2 Sensor Reference Voltage Circuit High (Bank 1 Sensor 1)
    P2247 O2 Sensor Reference Voltage Circuit/Open (Bank 2 Sensor 1)
    P2248 O2 Sensor Reference Voltage Performance (Bank 2 Sensor 1)
    P2249 O2 Sensor Reference Voltage Circuit Low (Bank 2 Sensor 1)
    P2250 O2 Sensor Reference Voltage Circuit High (Bank 2 Sensor 1)
    P2251 O2 Sensor Reference Ground Circuit/Open (Bank 1 Sensor 1)
    P2252 O2 Sensor Reference Ground Circuit Low (Bank 1 Sensor 1)
    P2253 O2 Sensor Reference Ground Circuit High (Bank 1 Sensor 1)
    P2254 O2 Sensor Reference Ground Circuit/Open (Bank 2 Sensor 1)
    P2255 O2 Sensor Reference Ground Circuit Low (Bank 2 Sensor 1)
    P2256 O2 Sensor Reference Ground Circuit High (Bank 2 Sensor 1)
    P2257 Secondary Air Injection System Control A Circuit Low
    P2258 Secondary Air Injection System Control A Circuit High
    P2259 Secondary Air Injection System Control B Circuit Low
    P2260 Secondary Air Injection System Control B Circuit High
    P2261 Turbo/Super Charger Bypass Valve - Mechanical
    P2262 Turbo Boost Pressure Not Detected - Mechanical
    P2263 Turbo/Super Charger Boost System Performance
    P2264 Water in Fuel Sensor Circuit
    P2265 Water in Fuel Sensor Circuit Range/Performance
    P2266 Water in Fuel Sensor Circuit Low
    P2267 Water in Fuel Sensor Circuit High
    P2268 Water in Fuel Sensor Circuit Intermittent
    P2269 Water in Fuel Condition
    P2270 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 2)
    P2271 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 2)
    P2272 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 2)
    P2273 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 2)
    P2274 O2 Sensor Signal Stuck Lean (Bank 1 Sensor 3)
    P2275 O2 Sensor Signal Stuck Rich (Bank 1 Sensor 3)
    P2276 O2 Sensor Signal Stuck Lean (Bank 2 Sensor 3)
    P2277 O2 Sensor Signal Stuck Rich (Bank 2 Sensor 3)
    P2278 O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
    P2279 Intake Air System Leak
    P2280 Air Flow Restriction / Air Leak Between Air Filter and MAF
    P2281 Air Leak Between MAF and Throttle Body
    P2282 Air Leak Between Throttle Body and Intake Valves
    P2283 Injector Control Pressure Sensor Circuit
    P2284 Injector Control Pressure Sensor Circuit Range/Performance
    P2285 Injector Control Pressure Sensor Circuit Low
    P2286 Injector Control Pressure Sensor Circuit High
    P2287 Injector Control Pressure Sensor Circuit Intermittent
    P2288 Injector Control Pressure Too High
    P2289 Injector Control Pressure Too High Engine Off
    P2290 Injector Control Pressure Too Low
    P2291 Injector Control Pressure Too Low Engine Cranking
    P2292 Injector Control Pressure Erratic
    P2293 Fuel Pressure Regulator 2 Performance
    P2294 Fuel Pressure Regulator 2 Control Circuit
    P2295 Fuel Pressure Regulator 2 Control Circuit Low
    P2296 Fuel Pressure Regulator 2 Control Circuit High
    P2297 O2 Sensor Out of Range During Deceleration (Bank 1 Sensor 1)
    P2298 O2 Sensor Out of Range During Deceleration (Bank 2 Sensor 1)
    P2299 Brake Pedal Position / Accelerator Pedal Position Incompatible
    P2300 Ignition Coil A Primary Control Circuit Low
    P2301 Ignition Coil A Primary Control Circuit High
    P2302 Ignition Coil A Secondary Circuit
    P2303 Ignition Coil B Primary Control Circuit Low
    P2304 Ignition Coil B Primary Control Circuit High
    P2305 Ignition Coil B Secondary Circuit
    P2306 Ignition Coil C Primary Control Circuit Low
    P2307 Ignition Coil C Primary Control Circuit High
    P2308 Ignition Coil C Secondary Circuit
    P2309 Ignition Coil D Primary Control Circuit Low
    P2310 Ignition Coil D Primary Control Circuit High
    P2311 Ignition Coil D Secondary Circuit
    P2312 Ignition Coil E Primary Control Circuit Low
    P2313 Ignition Coil E Primary Control Circuit High
    P2314 Ignition Coil E Secondary Circuit
    P2315 Ignition Coil F Primary Control Circuit Low
    P2316 Ignition Coil F Primary Control Circuit High
    P2317 Ignition Coil F Secondary Circuit
    P2318 Ignition Coil G Primary Control Circuit Low
    P2319 Ignition Coil G Primary Control Circuit High
    P2320 Ignition Coil G Secondary Circuit
    P2321 Ignition Coil H Primary Control Circuit Low
    P2322 Ignition Coil H Primary Control Circuit High
    P2323 Ignition Coil H Secondary Circuit
    P2324 Ignition Coil I Primary Control Circuit Low
    P2325 Ignition Coil I Primary Control Circuit High
    P2326 Ignition Coil I Secondary Circuit
    P2327 Ignition Coil J Primary Control Circuit Low
    P2328 Ignition Coil J Primary Control Circuit High
    P2329 Ignition Coil J Secondary Circuit
    P2330 Ignition Coil K Primary Control Circuit Low
    P2331 Ignition Coil K Primary Control Circuit High
    P2332 Ignition Coil K Secondary Circuit
    P2333 Ignition Coil L Primary Control Circuit Low
    P2334 Ignition Coil L Primary Control Circuit High
    P2335 Ignition Coil L Secondary Circuit
    P2336 Cylinder #1 Above Knock Threshold
    P2337 Cylinder #2 Above Knock Threshold
    P2338 Cylinder #3 Above Knock Threshold
    P2339 Cylinder #4 Above Knock Threshold
    P2340 Cylinder #5 Above Knock Threshold
    P2341 Cylinder #6 Above Knock Threshold
    P2342 Cylinder #7 Above Knock Threshold
    P2343 Cylinder #8 Above Knock Threshold
    P2344 Cylinder #9 Above Knock Threshold
    P2345 Cylinder #10 Above Knock Threshold
    P2346 Cylinder #11 Above Knock Threshold
    P2347 Cylinder #12 Above Knock Threshold
    P2400 Evaporative Emission System Leak Detection Pump Control Circuit/Open
    P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low
    P2402 Evaporative Emission System Leak Detection Pump Control Circuit High
    P2403 Evaporative Emission System Leak Detection Pump Sense Circuit/Open
    P2404 Evaporative Emission System Leak Detection Pump Sense Circuit Range/Performance
    P2405 Evaporative Emission System Leak Detection Pump Sense Circuit Low
    P2406 Evaporative Emission System Leak Detection Pump Sense Circuit High
    P2407 Evaporative Emission System Leak Detection Pump Sense Circuit Intermittent/Erratic
    P2408 Fuel Cap Sensor/Switch Circuit
    P2409 Fuel Cap Sensor/Switch Circuit Range/Performance
    P2410 Fuel Cap Sensor/Switch Circuit Low
    P2411 Fuel Cap Sensor/Switch Circuit High
    P2412 Fuel Cap Sensor/Switch Circuit Intermittent/Erratic
    P2413 Exhaust Gas Recirculation System Performance
    P2414 O2 Sensor Exhaust Sample Error (Bank 1 Sensor 1)
    P2415 O2 Sensor Exhaust Sample Error (Bank 2 Sensor 1)
    P2416 O2 Sensor Signals Swapped Bank 1 Sensor 2 / Bank 1 Sensor 3
    P2417 O2 Sensor Signals Swapped Bank 2 Sensor 2 / Bank 2 Sensor 3
    P2418 Evaporative Emission System Switching Valve Control Circuit /Open
    P2419 Evaporative Emission System Switching Valve Control Circuit Low
    P2420 Evaporative Emission System Switching Valve Control Circuit High
    P2421 Evaporative Emission System Vent Valve Stuck Open
    P2422 Evaporative Emission System Vent Valve Stuck Closed
    P2423 HC Adsorption Catalyst Efficiency Below Threshold (Bank 1)
    P2424 HC Adsorption Catalyst Efficiency Below Threshold (Bank 2)
    P2500 Generator Lamp/L-Terminal Circuit Low
    P2501 Generator Lamp/L-Terminal Circuit High
    P2502 Charging System Voltage
    P2503 Charging System Voltage Low
    P2504 Charging System Voltage High
    P2505 ECM/PCM Power Input Signal
    P2506 ECM/PCM Power Input Signal Range/Performance
    P2507 ECM/PCM Power Input Signal Low
    P2508 ECM/PCM Power Input Signal High
    P2509 ECM/PCM Power Input Signal Intermittent
    P2510 ECM/PCM Power Relay Sense Circuit Range/Performance
    P2511 ECM/PCM Power Relay Sense Circuit Intermittent
    P2512 Event Data Recorder Request Circuit/ Open
    P2513 Event Data Recorder Request Circuit Low
    P2514 Event Data Recorder Request Circuit High
    P2515 A/C Refrigerant Pressure Sensor B Circuit
    P2516 A/C Refrigerant Pressure Sensor B Circuit Range/Performance
    P2517 A/C Refrigerant Pressure Sensor B Circuit Low
    P2518 A/C Refrigerant Pressure Sensor B Circuit High
    P2519 A/C Request A Circuit
    P2520 A/C Request A Circuit Low
    P2521 A/C Request A Circuit High
    P2522 A/C Request B Circuit
    P2523 A/C Request B Circuit Low
    P2524 A/C Request B Circuit High
    P2525 Vacuum Reservoir Pressure Sensor Circuit
    P2526 Vacuum Reservoir Pressure Sensor Circuit Range/Performance
    P2527 Vacuum Reservoir Pressure Sensor Circuit Low
    P2528 Vacuum Reservoir Pressure Sensor Circuit High
    P2529 Vacuum Reservoir Pressure Sensor Circuit Intermittent
    P2530 Ignition Switch Run Position Circuit
    P2531 Ignition Switch Run Position Circuit Low
    P2532 Ignition Switch Run Position Circuit High
    P2533 Ignition Switch Run/Start Position Circuit
    P2534 Ignition Switch Run/Start Position Circuit Low
    P2535 Ignition Switch Run/Start Position Circuit High
    P2536 Ignition Switch Accessory Position Circuit
    P2537 Ignition Switch Accessory Position Circuit Low
    P2538 Ignition Switch Accessory Position Circuit High
    P2539 Low Pressure Fuel System Sensor Circuit
    P2540 Low Pressure Fuel System Sensor Circuit Range/Performance
    P2541 Low Pressure Fuel System Sensor Circuit Low
    P2542 Low Pressure Fuel System Sensor Circuit High
    P2543 Low Pressure Fuel System Sensor Circuit Intermittent
    P2544 Torque Management Request Input Signal A
    P2545 Torque Management Request Input Signal A Range/Performance
    P2546 Torque Management Request Input Signal A Low
    P2547 Torque Management Request Input Signal A High
    P2548 Torque Management Request Input Signal B
    P2549 Torque Management Request Input Signal B Range/Performance
    P2550 Torque Management Request Input B Signal Low
    P2551 Torque Management Request Input B Signal High
    P2552 Throttle/Fuel Inhibit Circuit
    P2553 Throttle/Fuel Inhibit Circuit Range/Performance
    P2554 Throttle/Fuel Inhibit Circuit Low
    P2555 Throttle/Fuel Inhibit Circuit High
    P2556 Engine Coolant Level Sensor/Switch Circuit
    P2557 Engine Coolant Level Sensor/Switch Circuit Range/Performance
    P2558 Engine Coolant Level Sensor/Switch Circuit Low
    P2559 Engine Coolant Level Sensor/Switch Circuit High
    P2560 Engine Coolant Level Low
    P2600 Coolant Pump Control Circuit/Open
    P2601 Coolant Pump Control Circuit Range/Performance
    P2602 Coolant Pump Control Circuit Low
    P2603 Coolant Pump Control Circuit High
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #7 เมื่อ: 22 พฤศจิกายน 2566, 08:42:32 »
  • P2604 Intake Air Heater A Circuit Range/Performance
    P2605 Intake Air Heater A Circuit/Open
    P2606 Intake Air Heater B Circuit Range/Performance
    P2607 Intake Air Heater B Circuit Low
    P2608 Intake Air Heater B Circuit High
    P2609 Intake Air Heater System Performance
    P2610 ECM/PCM Internal Engine Off Timer Performance
    P2611 A/C Refrigerant Distribution Valve Control Circuit/Open
    P2612 A/C Refrigerant Distribution Valve Control Circuit Low
    P2613 A/C Refrigerant Distribution Valve Control Circuit High
    P2614 Camshaft Position Signal Output Circuit/Open
    P2615 Camshaft Position Signal Output Circuit Low
    P2616 Camshaft Position Signal Output Circuit High
    P2617 Crankshaft Position Signal Output Circuit/Open
    P2618 Crankshaft Position Signal Output Circuit Low
    P2619 Crankshaft Position Signal Output Circuit High
    P2620 Throttle Position Output Circuit/Open
    P2621 Throttle Position Output Circuit Low
    P2622 Throttle Position Output Circuit High
    P2623 Injector Control Pressure Regulator Circuit/Open
    P2624 Injector Control Pressure Regulator Circuit Low
    P2625 Injector Control Pressure Regulator Circuit High
    P2626 O2 Sensor Pumping Current Trim Circuit/Open (Bank 1 Sensor 1)
    P2627 O2 Sensor Pumping Current Trim Circuit Low (Bank 1 Sensor 1)
    P2628 O2 Sensor Pumping Current Trim Circuit High (Bank 1 Sensor 1)
    P2629 O2 Sensor Pumping Current Trim Circuit/Open (Bank 2 Sensor 1)
    P2630 O2 Sensor Pumping Current Trim Circuit Low (Bank 2 Sensor 1)
    P2631 O2 Sensor Pumping Current Trim Circuit High (Bank 2 Sensor 1)
    P2632 Fuel Pump B Control Circuit /Open
    P2633 Fuel Pump B Control Circuit Low
    P2634 Fuel Pump B Control Circuit High
    P2635 Fuel Pump A Low Flow / Performance
    P2636 Fuel Pump B Low Flow / Performance
    P2637 Torque Management Feedback Signal A
    P2638 Torque Management Feedback Signal A Range/Performance
    P2639 Torque Management Feedback Signal A Low
    P2640 Torque Management Feedback Signal A High
    P2641 Torque Management Feedback Signal B
    P2642 Torque Management Feedback Signal B Range/Performance
    P2643 Torque Management Feedback Signal B Low
    P2644 Torque Management Feedback Signal B High
    P2700 Transmission Friction Element A Apply Time Range/Performance
    P2701 Transmission Friction Element B Apply Time Range/Performance
    P2702 Transmission Friction Element C Apply Time Range/Performance
    P2703 Transmission Friction Element D Apply Time Range/Performance
    P2704 Transmission Friction Element E Apply Time Range/Performance
    P2705 Transmission Friction Element F Apply Time Range/Performance
    P2706 Shift Solenoid F
    P2707 Shift Solenoid F Performance or Stuck Off
    P2708 Shift Solenoid F Stuck On
    P2709 Shift Solenoid F Electrical
    P2710 Shift Solenoid F Intermittent
    P2711 Unexpected Mechanical Gear Disengagement
    P2712 Hydraulic Power Unit Leakage
    P2713 Pressure Control Solenoid D
    P2714 Pressure Control Solenoid D Performance or Stuck Off
    P2715 Pressure Control Solenoid D Stuck On
    P2716 Pressure Control Solenoid D Electrical
    P2717 Pressure Control Solenoid D Intermittent
    P2718 Pressure Control Solenoid D Control Circuit / Open
    P2719 Pressure Control Solenoid D Control Circuit Range/Performance
    P2720 Pressure Control Solenoid D Control Circuit Low
    P2721 Pressure Control Solenoid D Control Circuit High
    P2722 Pressure Control Solenoid E
    P2723 Pressure Control Solenoid E Performance or Stuck Off
    P2724 Pressure Control Solenoid E Stuck On
    P2725 Pressure Control Solenoid E Electrical
    P2726 Pressure Control Solenoid E Intermittent
    P2727 Pressure Control Solenoid E Control Circuit / Open
    P2728 Pressure Control Solenoid E Control Circuit Range/Performance
    P2729 Pressure Control Solenoid E Control Circuit Low
    P2730 Pressure Control Solenoid E Control Circuit High
    P2731 Pressure Control Solenoid F
    P2732 Pressure Control Solenoid F Performance or Stuck Off
    P2733 Pressure Control Solenoid F Stuck On
    P2734 Pressure Control Solenoid F Electrical
    P2735 Pressure Control Solenoid F Intermittent
    P2736 Pressure Control Solenoid F Control Circuit/Open
    P2737 Pressure Control Solenoid F Control Circuit Range/Performance
    P2738 Pressure Control Solenoid F Control Circuit Low
    P2739 Pressure Control Solenoid F Control Circuit High
    P2740 Transmission Fluid Temperature Sensor B Circuit
    P2741 Transmission Fluid Temperature Sensor B Circuit Range Performance
    P2742 Transmission Fluid Temperature Sensor B Circuit Low
    P2743 Transmission Fluid Temperature Sensor B Circuit High
    P2744 Transmission Fluid Temperature Sensor B Circuit Intermittent
    P2745 Intermediate Shaft Speed Sensor B Circuit
    P2746 Intermediate Shaft Speed Sensor B Circuit Range/Performance
    P2747 Intermediate Shaft Speed Sensor B Circuit No Signal
    P2748 Intermediate Shaft Speed Sensor B Circuit Intermittent
    P2749 Intermediate Shaft Speed Sensor C Circuit
    P2750 Intermediate Shaft Speed Sensor C Circuit Range/Performance
    P2751 Intermediate Shaft Speed Sensor C Circuit No Signal
    P2752 Intermediate Shaft Speed Sensor C Circuit Intermittent
    P2753 Transmission Fluid Cooler Control Circuit/Open
    P2754 Transmission Fluid Cooler Control Circuit Low
    P2755 Transmission Fluid Cooler Control Circuit High
    P2756 Torque Converter Clutch Pressure Control Solenoid
    P2757 Torque Converter Clutch Pressure Control Solenoid Control Circuit Performance or Stuck Off
    P2758 Torque Converter Clutch Pressure Control Solenoid Control Circuit Stuck On
    P2759 Torque Converter Clutch Pressure Control Solenoid Control Circuit Electrical
    P2760 Torque Converter Clutch Pressure Control Solenoid Control Circuit Intermittent
    P2761 Torque Converter Clutch Pressure Control Solenoid Control Circuit/Open
    P2762 Torque Converter Clutch Pressure Control Solenoid Control Circuit Range/Performance
    P2763 Torque Converter Clutch Pressure Control Solenoid Control Circuit High
    P2764 Torque Converter Clutch Pressure Control Solenoid Control Circuit Low
    P2765 Input/Turbine Speed Sensor B Circuit
    P2766 Input/Turbine Speed Sensor B Circuit Range/Performance
    P2767 Input/Turbine Speed Sensor B Circuit No Signal
    P2768 Input/Turbine Speed Sensor B Circuit Intermittent
    P2769 Torque Converter Clutch Circuit Low
    P2770 Torque Converter Clutch Circuit High
    P2900 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    P2901 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2)
    P2902 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 3)
    P2903 O2 Sensor Circuit Range/Performance (Bank 2 Sensor 1)
    P2904 O2 Sensor Circuit Range/Performance (Bank 2 Sensor 2)
    P2905 O2 Sensor Circuit Range/Performance (Bank 2 Sensor 3)
    P3400 Cylinder Deactivation System
    P3401 Cylinder 1 Deactivation/Intake Valve Control Circuit/Open
    P3402 Cylinder 1 Deactivation/Intake Valve Control Performance
    P3403 Cylinder 1 Deactivation/Intake Valve Control Circuit Low
    P3404 Cylinder 1 Deactivation/Intake Valve Control Circuit High
    P3405 Cylinder 1 Exhaust Valve Control Circuit/Open
    P3406 Cylinder 1 Exhaust Valve Control Performance
    P3407 Cylinder 1 Exhaust Valve Control Circuit Low
    P3408 Cylinder 1 Exhaust Valve Control Circuit High
    P3409 Cylinder 2 Deactivation/Intake Valve Control Circuit/Open
    P3410 Cylinder 2 Deactivation/Intake Valve Control Performance
    P3411 Cylinder 2 Deactivation/Intake Valve Control Circuit Low
    P3412 Cylinder 2 Deactivation/Intake Valve Control Circuit High
    P3413 Cylinder 2 Exhaust Valve Control Circuit/Open
    P3414 Cylinder 2 Exhaust Valve Control Performance
    P3415 Cylinder 2 Exhaust Valve Control Circuit Low
    P3416 Cylinder 2 Exhaust Valve Control Circuit High
    P3417 Cylinder 3 Deactivation/Intake Valve Control Circuit/Open
    P3418 Cylinder 3 Deactivation/Intake Valve Control Performance
    P3419 Cylinder 3 Deactivation/Intake Valve Control Circuit Low
    P3420 Cylinder 3 Deactivation/Intake Valve Control Circuit High
    P3421 Cylinder 3 Exhaust Valve Control Circuit/Open
    P3422 Cylinder 3 Exhaust Valve Control Performance
    P3423 Cylinder 3 Exhaust Valve Control Circuit Low
    P3424 Cylinder 3 Exhaust Valve Control Circuit High
    P3425 Cylinder 4 Deactivation/Intake Valve Control Circuit/Open
    P3426 Cylinder 4 Deactivation/Intake Valve Control Performance
    P3427 Cylinder 4 Deactivation/Intake Valve Control Circuit Low
    P3428 Cylinder 4 Deactivation/Intake Valve Control Circuit High
    P3429 Cylinder 4 Exhaust Valve Control Circuit/Open
    P3430 Cylinder 4 Exhaust Valve Control Performance
    P3431 Cylinder 4 Exhaust Valve Control Circuit Low
    P3432 Cylinder 4 Exhaust Valve Control Circuit High
    P3433 Cylinder 5 Deactivation/Intake Valve Control Circuit/Open
    P3434 Cylinder 5 Deactivation/Intake Valve Control Performance
    P3435 Cylinder 5 Deactivation/Intake Valve Control Circuit Low
    P3436 Cylinder 5 Deactivation/Intake Valve Control Circuit High
    P3437 Cylinder 5 Exhaust Valve Control Circuit/Open
    P3438 Cylinder 5 Exhaust Valve Control Performance
    P3439 Cylinder 5 Exhaust Valve Control Circuit Low
    P3440 Cylinder 5 Exhaust Valve Control Circuit High
    P3441 Cylinder 6 Deactivation/Intake Valve Control Circuit/Open
    P3442 Cylinder 6 Deactivation/Intake Valve Control Performance
    P3443 Cylinder 6 Deactivation/Intake Valve Control Circuit Low
    P3444 Cylinder 6 Deactivation/Intake Valve Control Circuit High
    P3445 Cylinder 6 Exhaust Valve Control Circuit/Open
    P3446 Cylinder 6 Exhaust Valve Control Performance
    P3447 Cylinder 6 Exhaust Valve Control Circuit Low
    P3448 Cylinder 6 Exhaust Valve Control Circuit High
    P3449 Cylinder 7 Deactivation/Intake Valve Control Circuit/Open
    P3450 Cylinder 7 Deactivation/Intake Valve Control Performance
    P3451 Cylinder 7 Deactivation/Intake Valve Control Circuit Low
    P3452 Cylinder 7 Deactivation/Intake Valve Control Circuit High
    P3453 Cylinder 7 Exhaust Valve Control Circuit/Open
    P3454 Cylinder 7 Exhaust Valve Control Performance
    P3455 Cylinder 7 Exhaust Valve Control Circuit Low
    P3456 Cylinder 7 Exhaust Valve Control Circuit High
    P3457 Cylinder 8 Deactivation/Intake Valve Control Circuit/Open
    P3458 Cylinder 8 Deactivation/Intake Valve Control Performance
    P3459 Cylinder 8 Deactivation/Intake Valve Control Circuit Low
    P3460 Cylinder 8 Deactivation/Intake Valve Control Circuit High
    P3461 Cylinder 8 Exhaust Valve Control Circuit/Open
    P3462 Cylinder 8 Exhaust Valve Control Performance
    P3463 Cylinder 8 Exhaust Valve Control Circuit Low
    P3464 Cylinder 8 Exhaust Valve Control Circuit High
    P3465 Cylinder 9 Deactivation/Intake Valve Control Circuit/Open
    P3466 Cylinder 9 Deactivation/Intake Valve Control Performance
    P3467 Cylinder 9 Deactivation/Intake Valve Control Circuit Low
    P3468 Cylinder 9 Deactivation/Intake Valve Control Circuit High
    P3469 Cylinder 9 Exhaust Valve Control Circuit/Open
    P3470 Cylinder 9 Exhaust Valve Control Performance
    P3471 Cylinder 9 Exhaust Valve Control Circuit Low
    P3472 Cylinder 9 Exhaust Valve Control Circuit High
    P3473 Cylinder 10 Deactivation/Intake Valve Control Circuit/Open
    P3474 Cylinder 10 Deactivation/Intake Valve Control Performance
    P3475 Cylinder 10 Deactivation/Intake Valve Control Circuit Low
    P3476 Cylinder 10 Deactivation/Intake Valve Control Circuit High
    P3477 Cylinder 10 Exhaust Valve Control Circuit/Open
    P3478 Cylinder 10 Exhaust Valve Control Performance
    P3479 Cylinder 10 Exhaust Valve Control Circuit Low
    P3480 Cylinder 10 Exhaust Valve Control Circuit High
    P3481 Cylinder 11 Deactivation/Intake Valve Control Circuit/Open
    P3482 Cylinder 11 Deactivation/Intake Valve Control Performance
    P3483 Cylinder 11 Deactivation/Intake Valve Control Circuit Low
    P3484 Cylinder 11 Deactivation/Intake Valve Control Circuit High
    P3485 Cylinder 11 Exhaust Valve Control Circuit/Open
    P3486 Cylinder 11 Exhaust Valve Control Performance
    P3487 Cylinder 11 Exhaust Valve Control Circuit Low
    P3488 Cylinder 11 Exhaust Valve Control Circuit High
    P3489 Cylinder 12 Deactivation/Intake Valve Control Circuit/Open
    P3490 Cylinder 12 Deactivation/Intake Valve Control Performance
    P3491 Cylinder 12 Deactivation/Intake Valve Control Circuit Low
    P3492 Cylinder 12 Deactivation/Intake Valve Control Circuit High
    P3493 Cylinder 12 Exhaust Valve Control Circuit/Open
    P3494 Cylinder 12 Exhaust Valve Control Performance
    P3495 Cylinder 12 Exhaust Valve Control Circuit Low
    P3496 Cylinder 12 Exhaust Valve Control Circuit High
    • กระทู้: 42370
    DTC Reference
    « ตอบกลับ #8 เมื่อ: 22 พฤศจิกายน 2566, 08:42:57 »
  • U0001 High Speed CAN Communication Bus
    U0002 High Speed CAN Communication Bus Performance
    U0003 High Speed CAN Communication Bus (+) Open
    U0004 High Speed CAN Communication Bus (+) Low
    U0005 High Speed CAN Communication Bus (+) High
    U0006 High Speed CAN Communication Bus () Open
    U0007 High Speed CAN Communication Bus () Low
    U0008 High Speed CAN Communication Bus () High
    U0009 High Speed CAN Communication Bus () shorted to Bus (+)
    U0010 Medium Speed CAN Communication Bus
    U0011 Medium Speed CAN Communication Bus Performance
    U0012 Medium Speed CAN Communication Bus (+) Open
    U0013 Medium Speed CAN Communication Bus (+) Low
    U0014 Medium Speed CAN Communication Bus (+) High
    U0015 Medium Speed CAN Communication Bus () Open
    U0016 Medium Speed CAN Communication Bus () Low
    U0017 Medium Speed CAN Communication Bus () High
    U0018 Medium Speed CAN Communication Bus () shorted to Bus (+)
    U0019 Low Speed CAN Communication Bus
    U0020 Low Speed CAN Communication Bus Performance
    U0021 Low Speed CAN Communication Bus (+) Open
    U0022 Low Speed CAN Communication Bus (+) Low
    U0023 Low Speed CAN Communication Bus (+) High
    U0024 Low Speed CAN Communication Bus () Open
    U0025 Low Speed CAN Communication Bus () Low
    U0026 Low Speed CAN Communication Bus () High
    U0027 Low Speed CAN Communication Bus () shorted to Bus (+)
    U0028 Vehicle Communication Bus A
    U0029 Vehicle Communication Bus A Performance
    U0030 Vehicle Communication Bus A (+) Open
    U0031 Vehicle Communication Bus A (+) Low
    U0032 Vehicle Communication Bus A (+) High
    U0033 Vehicle Communication Bus A () Open
    U0034 Vehicle Communication Bus A () Low
    U0035 Vehicle Communication Bus A () High
    U0036 Vehicle Communication Bus A () shorted to Bus A (+)
    U0037 Vehicle Communication Bus B
    U0038 Vehicle Communication Bus B Performance
    U0039 Vehicle Communication Bus B (+) Open
    U0040 Vehicle Communication Bus B (+) Low
    U0041 Vehicle Communication Bus B (+) High
    U0042 Vehicle Communication Bus B () Open
    U0043 Vehicle Communication Bus B () Low
    U0044 Vehicle Communication Bus B () High
    U0045 Vehicle Communication Bus B () shorted to Bus B (+)
    U0046 Vehicle Communication Bus C
    U0047 Vehicle Communication Bus C Performance
    U0048 Vehicle Communication Bus C (+) Open
    U0049 Vehicle Communication Bus C (+) Low
    U0050 Vehicle Communication Bus C (+) High
    U0051 Vehicle Communication Bus C () Open
    U0052 Vehicle Communication Bus C () Low
    U0053 Vehicle Communication Bus C () High
    U0054 Vehicle Communication Bus C () shorted to Bus C (+)
    U0055 Vehicle Communication Bus D
    U0056 Vehicle Communication Bus D Performance
    U0057 Vehicle Communication Bus D (+) Open
    U0058 Vehicle Communication Bus D (+) Low
    U0059 Vehicle Communication Bus D (+) High
    U0060 Vehicle Communication Bus D () Open
    U0061 Vehicle Communication Bus D () Low
    U0062 Vehicle Communication Bus D () High
    U0063 Vehicle Communication Bus D () shorted to Bus D (+)
    U0064 Vehicle Communication Bus E
    U0065 Vehicle Communication Bus E Performance
    U0066 Vehicle Communication Bus E (+) Open
    U0067 Vehicle Communication Bus E (+) Low
    U0068 Vehicle Communication Bus E (+) High
    U0069 Vehicle Communication Bus E () Open
    U0070 Vehicle Communication Bus E () Low
    U0071 Vehicle Communication Bus E () High
    U0072 Vehicle Communication Bus E () shorted to Bus E (+)
    U0073 Control Module Communication Bus Off
    U0074 Reserved by SAE
    U0075 Reserved by SAE
    U0076 Reserved by SAE
    U0077 Reserved by SAE
    U0078 Reserved by SAE
    U0079 Reserved by SAE
    U0080 Reserved by SAE
    U0081 Reserved by SAE
    U0082 Reserved by SAE
    U0083 Reserved by SAE
    U0084 Reserved by SAE
    U0085 Reserved by SAE
    U0086 Reserved by SAE
    U0087 Reserved by SAE
    U0088 Reserved by SAE
    U0089 Reserved by SAE
    U0090 Reserved by SAE
    U0091 Reserved by SAE
    U0092 Reserved by SAE
    U0093 Reserved by SAE
    U0094 Reserved by SAE
    U0095 Reserved by SAE
    U0096 Reserved by SAE
    U0097 Reserved by SAE
    U0098 Reserved by SAE
    U0099 Reserved by SAE
    U0100 Lost Communication With ECM/PCM A
    U0101 Lost Communication with TCM
    U0102 Lost Communication with Transfer Case Control Module
    U0103 Lost Communication With Gear Shift Module
    U0104 Lost Communication With Cruise Control Module
    U0105 Lost Communication With Fuel Injector Control Module
    U0106 Lost Communication With Glow Plug Control Module
    U0107 Lost Communication With Throttle Actuator Control Module
    U0108 Lost Communication With Alternative Fuel Control Module
    U0109 Lost Communication With Fuel Pump Control Module
    U0110 Lost Communication With Drive Motor Control Module
    U0111 Lost Communication With Battery Energy Control Module A
    U0112 Lost Communication With Battery Energy Control Module B
    U0113 Lost Communication With Emissions Critical Control Information
    U0114 Lost Communication With Four-Wheel Drive Clutch Control Module
    U0115 Lost Communication With ECM/PCM B
    U0116 Reserved by SAE
    U0117 Reserved by SAE
    U0118 Reserved by SAE
    U0119 Reserved by SAE
    U0120 Reserved by SAE
    U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
    U0122 Lost Communication With Vehicle Dynamics Control Module
    U0123 Lost Communication With Yaw Rate Sensor Module
    U0124 Lost Communication With Lateral Acceleration Sensor Module
    U0125 Lost Communication With Multi-axis Acceleration Sensor Module
    U0126 Lost Communication With Steering Angle Sensor Module
    U0127 Lost Communication With Tire Pressure Monitor Module
    U0128 Lost Communication With Park Brake Control Module
    U0129 Lost Communication With Brake System Control Module
    U0130 Lost Communication With Steering Effort Control Module
    U0131 Lost Communication With Power Steering Control Module
    U0132 Lost Communication With Ride Level Control Module
    U0133 Reserved by SAE
    U0134 Reserved by SAE
    U0135 Reserved by SAE
    U0136 Reserved by SAE
    U0137 Reserved by SAE
    U0138 Reserved by SAE
    U0139 Reserved by SAE
    U0140 Lost Communication With Body Control Module
    U0141 Lost Communication With Body Control Module A
    U0142 Lost Communication With Body Control Module B
    U0143 Lost Communication With Body Control Module C
    U0144 Lost Communication With Body Control Module D
    U0145 Lost Communication With Body Control Module E
    U0146 Lost Communication With Gateway A
    U0147 Lost Communication With Gateway B
    U0148 Lost Communication With Gateway C
    U0149 Lost Communication With Gateway D
    U0150 Lost Communication With Gateway E
    U0151 Lost Communication With Restraints Control Module
    U0152 Lost Communication With Side Restraints Control Module (Left)
    U0153 Lost Communication With Side Restraints Control Module (Right)
    U0154 Lost Communication With Restraints Occupant Sensing Control Module
    U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
    U0156 Lost Communication With Information Center A
    U0157 Lost Communication With Information Center B
    U0158 Lost Communication With Head Up Display
    U0159 Lost Communication With Parking Assist Control Module
    U0160 Lost Communication With Audible Alert Control Module
    U0161 Lost Communication With Compass Module
    U0162 Lost Communication With Navigation Display Module
    U0163 Lost Communication With Navigation Control Module
    U0164 Lost Communication With HVAC Control Module
    U0165 Lost Communication With HVAC Control Module (Rear)
    U0166 Lost Communication With Auxiliary Heater Control Module
    U0167 Lost Communication With Vehicle Immobilizer Control Module
    U0168 Lost Communication With Vehicle Security Control Module
    U0169 Lost Communication With Sunroof Control Module
    U0170 Lost Communication With Restraints System Sensor A
    U0171 Lost Communication With Restraints System Sensor B
    U0172 Lost Communication With Restraints System Sensor C
    U0173 Lost Communication With Restraints System Sensor D
    U0174 Lost Communication With Restraints System Sensor E
    U0175 Lost Communication With Restraints System Sensor F
    U0176 Lost Communication With Restraints System Sensor G
    U0177 Lost Communication With Restraints System Sensor H
    U0178 Lost Communication With Restraints System Sensor I
    U0179 Lost Communication With Restraints System Sensor J
    U0180 Lost Communication With Automatic Lighting Control Module
    U0181 Lost Communication With Headlamp Levelling Control Module
    U0182 Lost Communication With Lighting Control Module (Front)
    U0183 Lost Communication With Lighting Control Module (Rear)
    U0184 Lost Communication With Radio
    U0185 Lost Communication With Antenna Control Module
    U0186 Lost Communication With Audio Amplifier
    U0187 Lost Communication With Digital Disc Player/Changer Module A
    U0188 Lost Communication With Digital Disc Player/Changer Module B
    U0189 Lost Communication With Digital Disc Player/Changer Module C
    U0190 Lost Communication With Digital Disc Player/Changer Module D
    U0191 Lost Communication With Television
    U0192 Lost Communication With Personal Computer
    U0193 Lost Communication With Digital Audio Control Module A
    U0194 Lost Communication With Digital Audio Control Module B
    U0195 Lost Communication With Subscription Entertainment Receiver Module
    U0196 Lost Communication With Rear Seat Entertainment Control Module
    U0197 Lost Communication With Telephone Control Module
    U0198 Lost Communication With Telematic Control Module
    U0199 Lost Communication With Door Control Module A
    U0200 Lost Communication With Door Control Module B
    U0201 Lost Communication With Door Control Module C
    U0202 Lost Communication With Door Control Module D
    U0203 Lost Communication With Door Control Module E
    U0204 Lost Communication With Door Control Module F
    U0205 Lost Communication With Door Control Module G
    U0206 Lost Communication With Folding Top Control Module
    U0207 Lost Communication With Moveable Roof Control Module
    U0208 Lost Communication With Seat Control Module A
    U0209 Lost Communication With Seat Control Module B
    U0210 Lost Communication With Seat Control Module C
    U0211 Lost Communication With Seat Control Module D
    U0212 Lost Communication With Steering Column Control Module
    U0213 Lost Communication With Mirror Control Module
    U0214 Lost Communication With Remote Function Actuation
    U0215 Lost Communication With Door Switch A
    U0216 Lost Communication With Door Switch B
    U0217 Lost Communication With Door Switch C
    U0218 Lost Communication With Door Switch D
    U0219 Lost Communication With Door Switch E
    U0220 Lost Communication With Door Switch F
    U0221 Lost Communication With Door Switch G
    U0222 Lost Communication With Door Window Motor A
    U0223 Lost Communication With Door Window Motor B
    U0224 Lost Communication With Door Window Motor C
    U0225 Lost Communication With Door Window Motor D
    U0226 Lost Communication With Door Window Motor E
    U0227 Lost Communication With Door Window Motor F
    U0228 Lost Communication With Door Window Motor G
    U0229 Lost Communication With Heated Steering Wheel Module
    U0230 Lost Communication With Rear Gate Module
    U0231 Lost Communication With Rain Sensing Module
    U0232 Lost Communication With Side Obstacle Detection Control Module (Left)
    U0233 Lost Communication With Side Obstacle Detection Control Module (Right)
    U0234 Lost Communication With Convenience Recall Module
    U0235 Lost Communication With Cruise Control Front Distance Range Sensor
    U0300 Internal Control Module Software Incompatibility
    U0301 Software Incompatibility with ECM/PCM
    U0302 Software Incompatibility with Transmission Control Module
    U0303 Software Incompatibility with Transfer Case Control Module
    U0304 Software Incompatibility with Gear Shift Control Module
    U0305 Software Incompatibility with Cruise Control Module
    U0306 Software Incompatibility with Fuel Injector Control Module
    U0307 Software Incompatibility with Glow Plug Control Module
    U0308 Software Incompatibility with Throttle Actuator Control Module
    U0309 Software Incompatibility with Alternative Fuel Control Module
    U0310 Software Incompatibility with Fuel Pump Control Module
    U0311 Software Incompatibility with Drive Motor Control Module
    U0312 Software Incompatibility with Battery Energy Control Module A
    U0313 Software Incompatibility with Battery Energy Control Module B
    U0314 Software Incompatibility with Four-Wheel Drive Clutch Control Module
    U0315 Software Incompatibility with Anti-Lock Brake System Control Module
    U0316 Software Incompatibility with Vehicle Dynamics Control Module
    U0317 Software Incompatibility with Park Brake Control Module
    U0318 Software Incompatibility with Brake System Control Module
    U0319 Software Incompatibility with Steering Effort Control Module
    U0320 Software Incompatibility with Power Steering Control Module
    U0321 Software Incompatibility with Ride Level Control Module
    U0322 Software Incompatibility with Body Control Module
    U0323 Software Incompatibility with Instrument Panel Control Module
    U0324 Software Incompatibility with HVAC Control Module
    U0325 Software Incompatibility with Auxiliary Heater Control Module
    U0326 Software Incompatibility with Vehicle Immobilizer Control Module
    U0327 Software Incompatibility with Vehicle Security Control Module
    DTC Reference
