ผู้เขียน หัวข้อ: YAMAHA Outboard Motor Fault Codes  (อ่าน 4317 ครั้ง)
  • กระทู้: 43779
« เมื่อ: 07 กันยายน 2567, 06:57:39 »
  •    YAMAHA Outboard Motor Fault Codes
       YAMAHA Outboard Marine Engine Fault Codes DTC
    1 - Normal (No Faults)
     13 - Incorrect Pulsar Coil Signal
     14 - Incorrect Crank Position Sensor Signal
     15 - Incorrect Engine Temperature Sensor Signal
     17 - Knock Sensor
     18 - Incorrect Throttle Position Sensor Signal
     19 - Incorrect Battery Voltage
     22 - Incorrect Atmospheric Pressure Sensor Signal
     23 - Incorrect Intake Air Temperature Signal
     24 - EX CAM Position Sensor
     25 - Incorrect Fuel Pressure Signal
     26 - Incorrect Injector Signal
     27 - Incorrect Water in Fuel Signal
     28 - Incorrect Shift Position Switch Signa
     29 - Incorrect Intake Air Pressure Sensorl
     31 - No Tach Signal Output From ECU (OX66)
     33 - Ignition Timing Slightly Corrected due to
     Starting a Cold Engine
     35 - ECU Processing Information (OX66)
     36 - ECU Processing Information (OX66)
     37 - Intake Air Passage (Electronic Throttle Valve)
     or ECU Processing Information (OX66)
     38 - ECU Processing Information (OX66)
     39 - Oil Pressure Sensor
     40 - ECU Processing Information (OX66)
     41 - Overrev Control During Ignition Cutoff Operation (OX66)
     42 - Overheat Control or No Oil Control (OX66)
     43 - Buzzer Sounding (OX66)
     44 - Incorrect Engine Stop Lanyard Switch Signal
     45 - Shift Cut Off
     46 - Overheat Switch
     49 - Over Cooling
     59 - ECM Memory (For Trouble Record Only)
     62 - 98 Low Fuel Pressure
     68 - VCT (S Bank) Starboard Valve Pulley Abnormal Advance
     69 - VCT (P Bank) Port Valve  Pulley Abnormal Advance
    71 - S bank IN Starboard IN CAM Position Sensor
     72 - P bank IN Port IN CAM Position Sensor
     73 - OCV (S Bank) Starboard Oil Control Valve
     74 - OCV (P Bank Port Oil Control Valve
     75 - RCS
     76 - RCS
     77 - RCS
     78 - RCS
     79 - RCS
     80 - RCS
     81 - RCS
     82 - RCS
     83 - Tirm/Tilt Angle Sensor
     84 - RCS
    85 - IDM Ioncurrent Detection Module
     86 - Y-COP Immobilizer, Theft Deterrent.
     87 - Remote Control System
     98 - 62 Low Fuel Pressure
    112 - ETV ETS (ECM-sub)
    113 - ETV ETS (ECM-System)
    114 - ETV ETS (ECM-Main)
    115 - ETV ETS (Throttle Valve Open)
    116 - ETV ETS (Throttle Valve Closed)
    117 - ETV ETS (Driving Motor P Short)
    118 - ETV ETS (Driving Motor N Short)
    119 - ETV ETS (Driving Motor Connector Open)
    121 - ETV ETS (Communication Error)
    122 - ETV ETS (Driving Motor Heat)
    123 - ETV ETS (Driving Motor Relay)
    124 - TPS MTPS Open
    125 - TPS MTPS Short
    126 - TPS Throttle Position Sensor Character Fail
    127 - TPS Sub Throttle Position Sensor Open
    128 - TPS Sub Throttle Position Sensor Short
    129 - ETV MTPS
    131 - APS/ETV
    132 - APS/ETV
    133 - APS/ETV
    134 - APS/ETV
    135 - APS/ETV
    136 - ETV ETS Comm.Error Main
    137 - ETV ETS Communication Error Sub
    138 - ETV ETS (ECM Main)
    139 - ETV ETS (ECM Sub)
    140 - ETV
    141 - ETV ETS Throttle Position Sensor Voltage
    142 - ETV ETS Return Spring
    143 - ETV ETS Comm. Error
    144 - ETV ETS Low Voltage Mode
    145 - ETV ETS Throttle Valve
    146 - SPS Main SSS Power Short / Ground Open
    147 - SPS Main SSS Power Open / Ground Short
    148 - SPS Sub SSS Power Short / Ground Open
    149 - SPS Sub SSS Power Open / Ground Short
    150 - SPS SSS Character Fail
    151 - SPS
    152 - SPS
    153 - SPS Shift Motor Over Current
    154 - SPS Shift Motor Deadlock While Stopping
    155 - SPS Shift Motor Deadlock While Operating
    156 - Comm. Error 1 Channel Engine remote Connector
    157 - Comm. Error 2 Channel Engine remote Connector
    160 - MSLPS 1 Main Power Short / Ground Open
    161 - MSLPS 1 Main Power Open / Ground Short
    162 - MSLPS 1 Sub Power Short/Ground Open
    163 - MSLPS 1 Sub Power Open / Ground Short
    164 - MSLPS 1 Watching Fail
    165 - MSLPS Character Fail
    166 - MSLPS 2 Main Power Short / Ground Open
    167 - MSLPS 2 Main Power Open / Ground Short
    168 - MSLPS 2 Sub Power Short / Ground Open
    169 - MSLPS 2 Sub Power Open / Ground Short
    170 - MSLPS 2 Character Fail
    171 - SSLPS 1 Main Power Short /  Ground Open
    172 - SSLPS 1 Main Power Open / Ground Short
    173 - SSLPS 1 Sub Power Short / Ground Open
    174 - SSLPS 1 Sub Power Open / Ground Short
    175 - SSLPS 1 Watching Fail
    176 - SSLPS 1 Character Fail
    177 - SSLPS 2 Main Power Short / Ground Open
    178 - SSLPS 2 Main Power Open / Ground Short
    179 - SSLPS 2 Sub Power Short / Ground Open
    180 - SSLPS 2 Sub Power Open / Ground Short
    181 - SSLPS 2 Character Fail
    183 - Station Selector System Fail
    184 - Lever Selector System Fail
    186 - Sub Station Communication Error
    187 - Lever Pickup Abnormal
    252 - FC Invalid Code - Engine Overheat
