ผู้เขียน หัวข้อ: V508 Super Mini ZedBull Smart Zed-Bull Key Transponder Programmer Mini ZED BULL  (อ่าน 2289 ครั้ง)
  • กระทู้: 43753
« เมื่อ: 08 มกราคม 2568, 10:49:22 »
  •    Mini ZED BULL Key Programmer
    Details
        Main feature of ZED BULL: Finding PIN Code, preparing precoded transponders and programming
    transponders from EEPROM and MCU. Zed-BULL PC software's excellent features will help you while
    using EEPROM applications. ECU pictures, which ECU has which MCU or EEPROM and the location of
    mcu or eeprom on the board, which type transponder will be used... With Automatic Module Finding (AMF)
    feature, when you select the EEPROM file, the module will be recognized automatically
       Another revolution of Zed-BULL is programing transponders when there is no key from ECUs. For now,
    Zed-BULL has 55 different applications and it is increasing... With this feature, you can program transponders,
    find pin codes and prepare precoded transponders for the cars which need precoded transponders like for fiat
    doblo 48. For this feature, you don't need expensive precoded transponders priced about 8-10 Euro. You can
    use blank transponders.
    Transponder Cloning: 11, 12, 13, 33, 73, 4C (writing to 4C electronic key and batteryless TPX1 transponder),
     for Philips Crypto 40 (some), 41(all), 42(all), 44(all unlocked VAG), 45(all), Texas crypto 4D(all 60-61-62-63
    -64-65-67)to batteryless TPX2 andfor for Silca electronic heads
        Until now, common transponder cloning tools could only copy fixed transponders. But the revolution
    that we started with our device, Zed-Qx, is increasing with Zed-BULL. 41(for NISSAN), 42(for VAG), 44
    (Unlocked for VAG) and 45(for PEUGEOT) transponders which normally known as can not be copied, can
    be copied with Zed-BULL. Also you can copy 4C transponders onto batteryless TPX1 4C glass transponders
    Producing Transponders for OBD Programing: If you have an OBD device like T-Code Pro, you will need
    special precoded transponders for some cars. Instead of buying these special transponders for high prices,
    you can produce them with Zed-BULL using blank transponders. The transponders that you can produce:
    40, 41, 42, 44, 45, 73 for Mitsubishi, 44 for VAG, 61, 62, 65 and 46 for BMW, for AUDI, for PORSCHE,
    for RENAULT... etc. For now, Zed-BULL has 24 different transponder production applications.
    product: ZED-Bull Transponder Clone Key Programmer Tool
    please noted that mini zedbull can not support ID46 chips and forbmw.
    Zed-BULL will fulfill all of your requirements as professional on Immobilizer Systems;
    Zed-BULL is a transponder cloning device which contains all of Zed-Qx's features and also has more additional features.
    Item Type: Auto Key Programmer
    Plug Type: , it applies to Canada, India, Mexico, Thailand, the United States, the Philippines, Taiwan and so on.
    voltage: AC100-240V
    Material: Plastic
    Package Contents:
    1 x Zed-bull Main Unit
    1 x PC USB Cable
    1 x Power Adapter
    1 x CD
    Only the above package content, other products are not included.
    Note: Light reflection and different displays may cause the color of the item in the picture
    a little different from the real thing. The measurement allowed error is +/- 1-3cm.
       สำหรับซอฟท์แวร์ที่ใช้กับเครื่องมือตัวนี้ สมาชิกวีไอพีสามารถดาวน์โหลดได้ที่ลิ้งค์ด้านล่าง
    • คุณต้องเป็นสมาชิกของกลุ่มใดกลุ่มหนึ่งต่อไปนี้: VIP ปีที่ 3, VIP ปีที่ 1, VIP ปีที่ 2, Super VIP, ศิษย์เก่า วท.นพ, สมาชิก VIP, สมาชิกกิตติมศักดิ์, VIP ปีที่ 5, VIP ปีที่ 4, VIP ปีที่ 6, VIP ปีที่ 7, VIP ปีที่ 8, VIP ปีที่ 9, VIP ปีที่10, VIP ปีที่11, VIP ปีที่12, วีไอพีสะสม 5 ปี, วีไอพีสะสม 10 ปี, VIP ปีที่13, VIP ปีที่14, VIP ปีที่15, ผู้สนับสนุนเว็บ/Sponsor, VIP ปีที่16, VIP ปีที่17, VIP ปีที่18, VIP ปีที่19, VIP ปีที่20, VIP ปีที่21, VIP ปีที่22, VIP ปีที่23, VIP ปีที่24, VIP ปีที่25, VIP ปีที่26, VIP ปีที่27, VIP ปีที่28, VIP ปีที่29, VIP ปีที่30.
    « แก้ไขครั้งสุดท้าย: 08 มกราคม 2568, 10:53:23 โดย Auto Man »
