ผู้เขียน หัวข้อ: วิธีซิงโครไนซ์แดชบอร์ดกับ ECU สำหรับฟอร์ด โฟกัส หลังจากเปลี่ยน ECU  (อ่าน 260 ครั้ง)
  • กระทู้: 44121
HOW TO SYNCHRONIZE DASHBOARD TO ECU FOR FORD FOCUS AFTER ECU REPLACEMENT
🔹 STEP 1: READ DASHBOARD EEPROM FILE
- Connect the Orange 5 programmer (or another compatible programmer) to the dashboard.
- Open Orange 5 software → go to
 Type → MC68HC12 → 04-MTRK → MC9S12H256.
- Click Read ID, then Read EEPROM, and save the file on your PC.
 👉 Example: save as “eprom_dash_focus.bin”
🔹 STEP 2: READ ECU EEPROM FILE
- Use your programmer to read the ECU EEPROM file before performing synchronization.
- Save this file for later use.
🔹 STEP 3: SYNCHRONIZE DASHBOARD TO ECU
- Open Ford All in One software.
- Load both files: the ECU EEPROM and Dash EEPROM you previously saved.
- Click “Synchro to ECU” and save the new synchronized file on your PC.
- (Optional) Use Fairdell HexCmp2 software to compare the new ECU EEPROM file with the original one to verify changes.
- Finally, write the synchronized EEPROM file back to the ECU using your programmer.
✅ Result: Your new ECU will now be synchronized with the dashboard, and the vehicle should start and function properly without immobilizer errors.
แปลไทย :
  • กระทู้: 44121
Ford All In One 3.2 Free for real mhhauto users
Product Information (Yeah... copy and past)
Supported cars :
 Ford Transit Connect 2005-2010,  Ford Fiesta 2006-2009,  Ford Fusion 2006-2009 ,  Ford Mondeo 2008+,  Ford Galaxy 2008+,
Ford S-max 2008+
Supported ECU :
 SID804, EDC16, SID206,  SID202, SID803, SIM210,
How immobiliser works on Ford Transit Connect 2005-2010,Ford Fiesta 2006-2009,Ford Fusion 2006-2009 :
 Immobiliser data (PATS) on these cars are stored in the instrument cluster(IC) HC12 processor.
 Instrument cluster receive transponder key signal from immobiliser coil and if key data is equal to car, IC send    synchronisation
signal to motor ECU.
 If transponder key is stored in IC and synchronization data IC-ECU is correct, ECU permit to start the engine.
How to use this program:
- if car transponder key is lost:
read with CarProg instrument cluster EEPROM by OBDII (or you can remove IC from car and read HC12 processor EEPROM  with
any programmer (like CarProg, XPROG OR UPA), save file and open it with "Open IC dump".Program will show you transponder
data.Write this data to EH2 or TPX2 transponder with any transponder programmer (like RW4, Codereader or Zedbull).
If immobilizer lamp is ON, motor ECU is defective/lost:
 Open ECU(SID804,EDC16,SID206,SIM210) and read EEPROM (with CarProg you can read in-circuit).
 Open file with "Open ECU EEPROM" button. Now press button Synchro to ecu (if you want to  transfer data from  dashboard to
ecu) or Synchro to Dash(if you want to transfer data from ecu to  dash) and write saved file to dash(if  you done synchro to dash)
or ecu (if you done synchro to ecu)
How does immobilizer work on Ford Mondeo 2008+, Galaxy 2008+, S-max 2008+:
 Immobilizer data (PATS) on these cars are stored in the Intelligent power distribution module (GEM)  located in  passenger
compartment fuse box. GEM receive transponder key signal from immobilizer coil and if the key data is equal to car, GEM   sends
synchronization signal to motor ECU.
 If transponder key is stored in GEM and synchronization data GEM-ECU is correct, GEM permits to  start the engine.
 If car transponder key is lost:
   1. Remove GEM (Intelligent power distribution module) from car.
   2. Open and locate 25320 EEPROM. Read (with CarProg you can read in-circuit).
   3. Save file and open with "Open GEM EEPROM". Program will show you transponder data.
   4. Write this data to EH2 or TPX2 transponder with any transponder programmer (like RW4, Codereader or Zedbull)
  If motor ECU is defective/lost:.
   1. Remove GEM (Intelligent power distribution module) from the car.
   4. Open ECU and read EEPROM.
   5. Open file with "Open ECU EEPROM" button.
   6. Now transfer synchronization data from GEM to motor ECU using button Synchro to ecu.
   7. Save ECU file and write it back to Engine Control Module
   __          _          _               _
  / /   _   _ (_) ___    /_\   _ __    __| | _ __   ___
 / /   | | | || |/ __|  //_\\ | '_ \  / _` || '__| / _ \
/ /___ | |_| || |\__ \ /  _  \| | | || (_| || |   |  __/
\____/  \__,_||_||___/ \_/ \_/|_| |_| \__,_||_|    \___|
            _      _                    _
 _ __ ___  | |__  | |__    __ _  _   _ | |_   ___       ___   ___   _ __ ___
| '_ ` _ \ | '_ \ | '_ \  / _` || | | || __| / _ \     / __| / _ \ | '_ ` _ \
| | | | | || | | || | | || (_| || |_| || |_ | (_) | _ | (__ | (_) || | | | | |
|_| |_| |_||_| |_||_| |_| \__,_| \__,_| \__| \___/ (_) \___| \___/ |_| |_| |_|
PASSWORD : mhhauto.com
Link:
https://mega.nz/#!khgVUboa!IGWhDMN53C2Qrx4bz4I-4P8iDbfZNJywlZMkhxXxm-s
Remember to press [reputation] + [thanks] button.
Note:
After pressing "synchro to ecu" or "synchro to dash" (and the file saved) the software
must be restarted or it will show the old synchronization code on the file saved.
« แก้ไขครั้งสุดท้าย: 09 ตุลาคม 2568, 06:28:23 โดย Auto Man »
