ผู้เขียน หัวข้อ: เว็บที่ขายโปรแกรม Immo Killer v1.1  (อ่าน 3557 ครั้ง)
« เมื่อ: 16 เมษายน 2561, 15:07:25 »
  •   ไปเจอเว็บเมืองนอกเขาขายโปรแกรมนี้มา  มาจากที่นี่...
    Immokiller is a software for repairing, bypassing or "virginizing" the immobilizer of the Engine Control Module (ECM) of some cars. In version 1.1, the cars list it covers, are in the list below.
    It works by processing the dump files from the Immobilizer EPROM of the ECM and depending on the case, it removes or virginize the immobilizer system, so you may use an used ECM or make it accept new keys. You will need to use a regular EPROM programmer to read the contents of the EPROM in your ECU, then process it with the ImmoKiller software and finally write the processed file back to the Immobilizer EPROM. When the process is done, your car should start if you are using new keys or if you replaced the ECM by an used ECM.
    This is and instant download of the Immokiller software (EPROM programmer NOT included).
    Supported List for Immokiller v1.1 (146 Algorithms):
    Alfa Romeo 2.4JTD&2.0 24C04
    Audi A3,A4,A6 BOSCH 1.8T&1.9TDI 24C02 (Remove Immo)
    BMW Bosch 318&525 TDS 93C46 (Remove Immo)
    Citroen IAW G6.14 - Magneti Marelli
    Citroen Berlingo - BSI - MCU NEC
    Citroen C3- BSI - MEM 95160
    Citroen Xara - BSI - MEM 95040
    Citroen Xara Picasso - BSI - MEM 95040
    Citroen EDC15 5P08C3 (Remove Immo)
    Citroen MA 3.0 Bosch 93CS46 (Remove Immo)
    Citroen MA 3.1 Bosch 24C04 (Remove Immo)
    Citroen MA 3.1 Bosch 93CS46 (Remove Immo)
    Citroen MP 3.2 Bosch 93CS46 (Remove Immo)
    Citroen MP 5.2 Bosch 93S46 (Remove Immo)
    Citroen MP 7.2 Bosch 24C02 (Remove Immo)
    Citroen MP 7.3 Bosch 24C02 (Remove Immo)
    Citroen SID 803 PIN calculator (95320)
    Citroen SID 803 PIN programmer (95320)
    Daewoo Siemens TMS374
    Fiat Bosch - 24C02
    Fiat IAW 16F.EB - Magneti Mirelli
    Fiat IAW 4AF.M9 - Magneti Marelli
    Fiat 2.3 JTD Bosch 5P08C3
    Fiat BPKA DELCO HC11F1
    Fiat Hitachi MFI 003BC2 59C11
    Fiat IAW 8F.5T Magneti Marelli HC11E9
    Fiat IAW 8F.6B Magneti Marelli HC11E9
    Fiat IAW 18F.B4 Magneti Marelli HC11F1
    Fiat IAW 1ABB.92 TMS374
    Fiat IAW 1ABG.81 Magneti Marelli TMS374
    Fiat IAW 1AF.13 Magneti Marelli TMS374
    Fiat IAW 1AF.15 Magneti Marelli TMS374
    Fiat IAW 1AF.17 Magneti Marelli TMS374
    Fiat IAW 49F.B4 Magneti Marelli 95040
    Fiat IAW 4AF.M1 Magneti Marelli 95160
    Fiat IAW 4AF.M7 Magneti Marelli 95160
    Fiat IAW 4AF.S2 Magneti Marelli 95160
    Fiat IAW 59F.M2 (HYBRID)
    Fiat IAW 59F.M3 (HYBRID)
    Fiat IAW 59F.M7 (HYBRID)
    Fiat IAW 59F.M9 (HYBRID)
    Fiat IAW 5NF.T1 Magneti Marelli 95160
    Fiat IAW 8F.5T Magneti Marelli HC11F1
    Fiat IAW 8P.22 Magneti Marelli HC11
    Fiat Lucas DCU3F 95080
    Iveco Daily Bosch 24C16
    Kia Siemens TMS374
    Mercedes C,E class (infra-red) - ECU progr. ?
    Mercedes C,E class (infra-red) - Immo progr. 2/2
    Mercedes Sprinter 24C02 - Unlock ECU
    Mercedes Sprinter 5P08C3 - Unlock ECU
    Mercedes Start Error - Sprinter
    Mercedes Start Error - Vito HC05
    Mercedes Start Error - Vito HC08
    Mercedes Vito 24C04 - Unlock ECU
    Opel Delco HC11F1 2 plugs (blue,grey)
    Opel DELCO HC11F1 2 plugs (red,white)
    Opel DTL - Bosch
    Opel Siemens SIMTEC 56.1 9356
    Opel 1.2 8V Delco 27C256 (Remove Immo)
    Opel 1.7 ; 2.0 16V Turbo Diesel 24C04 (Remove Immo)
    Opel Bosch DTL 24C04 + 2x29F010
    Opel Siemens SIMTEC 56.1 - 29F010 (Remove Immo)
    Peugeot MP5.1.1 - Bosch
    Peugeot S2000 - Sagem
    Peugeot BSI - De/encryption
    Peugeot ECU Bosch ME7.4.4 PIN progr.
    Peugeot EDC 15 - 5P08C3 PIN prog.
    Peugeot EDC 16 - 95160 PIN prog.
    Peugeot EDC15 PIN calculator (5P08C3)
    Peugeot EDC16 PIN calculator (95160)
    Peugeot 206 BSI - MCU HC912
    Peugeot 206 BSI - MEM 95160
    Peugeot 307 BSI - MCU HC912
    Peugeot 307 BSI - MEM 95160
    Peugeot 2.3 JTD Bosch 5P08C3
    Peugeot ECU SAGEM S2000 PIN progr.
    Peugeot IAW 1AP.20,90 TMS374
    Peugeot IAW 1AP.41 Magneti Marelli TMS374
    Peugeot IAW 1AP.43 Magneti Marelli TMS374
    Peugeot IAW 1AP.80, 81, 40 TMS374
    Peugeot IAW 1AP.83 Magneti Marelli TMS374
    Peugeot IAW 48P2.XX Magneti Marelli 29F400
    Peugeot IAW 8P.XX Magneti Marelli HC11A8 MCU
    Peugeot Sagem SL96 TMS374 1x28F512
    Peugeot Sagem SL96 TMS374 2x28F512
    Polonez Delco HC11F1
    Renault 5NR.CE1 - Magneti Marelli
    Renault DCI - Bosch
    Renault DCI - Delphi
    Renault DCU3R - Lucas, Clear Immo
    Renault DCU3R - Lucas, Remove Immo
    Renault SIRIUS32 - Siemens
    Renault SIRIUS34 - Siemens
    Renault 1.9 DTI Bosch 24C04 (1 plug)
    Renault 1.9 DTI Bosch 24C04 (2 plugs)
    Renault Fenix 3 95160
    Renault IAW 6R.20 Magneti Marelli TMS370
    Renault IAW 6R.30 Magneti Marelli TMS370
    Renault IAW5NR2.C5 95160
    Renault S2000RPM 95080 - SAGEM
    Renault Siemens TMS374
    Renault Sirius32 (16V) 29F200 (Remove Immo)
    Rover 214,216 93C46
    Skoda SIMOS - Siemens
    Toyota Land Cruiser 93LC66
    Toyota YarisDenso 93C46
    V.A.G IMMO 5WK4 678 - HC05 - Siemens
    V.A.G IMMO 6X0 953 257 - 24C04 - Valeo
    V.A.G IMMO VW LT - HC05X16
    V.A.G IMMO White box - 93C46 - f+g Megamos
    V.A.G EDC16 Remove Immo (95320)
    V.A.G. EDC16 Bosch 95320
    V.A.G. TDI - Bosch
    V.A.G. TDI 24C02 (1 plug) Bosch.QVAG 1.9TDGI REMOV
    V.A.G. TDI 24C02 (2 plugs) Bosch
