ผู้เขียน หัวข้อ: Turbosound MILAN M12 ลำโพงแบบมีแอมป์ในตัว เสียง...  (อ่าน 5795 ครั้ง)
  • กระทู้: 44008
« เมื่อ: 02 กุมภาพันธ์ 2559, 01:53:41 »
    รหัส : MILAN M12
    ยี่ห้อ : Turbosound
    รุ่น : MILAN M12
    ราคาปกติ :  28,000.00 บาท
    ราคาพิเศษ :  24,600.00บาท
    Color/ สีของสินค้า :
    รายละเอียดย่อ :
    ตู้ลำโพงพร้อมขยายเสียง 1100 Watt 2 Way 12" Full Range Powered Loudspeaker with KLARK TEKNIK DSP Technology for Portable PA and Installation Applications 90x60 dispersion
    รายละเอียดทั้งหมด :
    Turbosound MILAN M12 ตู้ลำโพงพร้อมขยายเสียง 1100 Watt 2 Way 12" Full Range Powered Loudspeaker with KLARK TEKNIK DSP Technology for Portable PA and Installation Applications 90x60 dispersion
    1100-Watt Powered 12" Loudspeaker with KLARK TEKNIK DSP Technology
    The Milan M12 is a portable 12” two-way powered loudspeaker featuring two independent input channels,  mic and line inputs, two band EQ, intelligent limiting, and a Mix Out function  for connection to additional Milan loudspeakers for easy system expansion.
    The Class-D amplifier is a true 2-channel unit with an integrated electronic crossover, allowing the HF and LF drivers to be powered separately without one being able to influence the sound of the other. Total output power is 1,100 watts peak, providing plenty of headroom to maintain good dynamic range so that transient signals are delivered effortlessly. The lightweight switch-mode power supply coupled with industry leading Klark Teknik digital signal processing, providing dynamic equalisation and sophisticated limiting functions to ensure optimum performance and long term reliability.
    The two discrete input channels are each equipped with balanced, combination jack/XLR connectors and a level control, catering for a range of music sources from low impedance microphones, acoustic guitars and keyboards to mp3 players and mixing consoles, selectable via a mic/line slide switch.
    Common to both channels are bass and treble controls with ±6 dB of cut or boost to allow the loudspeaker to be equalised to the venue. In addition, a low cut filter is provided at 100 Hz to shelve the low frequency response when used on the floor as a wedge monitor, or to ensure correct integration with subwoofers. A speech/music switch optimises the loudspeaker’s frequency response either for predominantly vocal material or for music programme. A Mix Out function sends the mix of both input channels post-EQ to additional Milan loudspeakers on a balanced male XLR for easy system expansion.
    The trapezoidal enclosure is fabricated from high density polypropylene, and is extensively ribbed externally and internally to eliminate resonances and also to provide an attractive and durable cabinet finish. The symmetrical 43° side angles allow the loudspeaker to be conveniently used as a floor monitor. A recessed grab handle on the top is designed for easy lifting and carrying, while the dual angle pole mount socket allows the loudspeaker to be mounted on straight poles or speaker stands either vertically, or raised higher and angled down to optimise audience coverage. A total of six M10 rigging points are provided on the top and bottom of the cabinet to enable vertical or horizontal suspension in permanent installations using M10 shoulder eyebolts.
    Mains power is connected via a non-locking IEC with integrated fuseholder. The illuminated front badge can operate in one of three possible modes: permanently on; permanently off; or to indicate the action of limiting.
    Feature.
    2 way full range powered loudspeaker for portable PA and installation applications
    1,100 Watt power featuring KLARK TEKNIK Class-D technology
    KLARK TEKNIK Digital Signal Processing for total system control
    High excursion 12" low frequency driver with low mass voice coil for improved transient response
    1" high temperature dome compression driver with extended high frequency reproduction
    Converging elliptical waveguide provides wide dispersion and excellent pattern control
    Speech/music switch featuring optimised equalisation for voice or music applications
    Switchable 100 Hz high pass filter for subwoofer integration
    Lightweight composite enclosure with black finish
    Rugged powder coated perforated steel mesh grille
    Dual angle pole mount for accurate audience coverage
    Multiple internal rigging points for installation applications
    3-Year Warranty Program*
    Designed and engineered in England
    Specs.
    Dimensions (H x W x D)   620 x 394 x 330 mm (24.4 x 15.5 x 13")
    Net Weight   20.5 kg (45.1 lbs)
    Components   1 x 12" (305 mm) LF driver, 1 x 1" (25 mm) HF compression driver
    Frequency Response   50 Hz - 18 kHz ±3 dB
    Dispersion   90° H x 60° V @ -6 dB points
    Calculated Max SPL   128 dB peak
    Construction   Injection-moulded polypropylene enclosure. Recessed carrying handles. Integral dual-angle pole mount socket
    Grille   Powder coated galvanised perforated steel mesh with foam backing
    Connectors
    Mic/Line input: combo jack/female XLR wired pin 2 hot
    Mix out: male XLR wired pin 2 hot
    IEC mains connector with integrated fuseholder with integrated fuseholder
    Rigging   (6) M10 threaded internal rigging points
    Spares & Accessories   LS-1229 12" (305 mm) Replacement LF loudspeaker
    RC-1229 Recone kit
    CD-125 1" (25 mm) HF compression driver
    RD-125 HF diaphragm
    MG-M12 Metal grille
    PB-55 Wall bracket, pole mount fixing
    EB-10 Shoulder eyebolt
    ราคา ต่อ 1 ใบนะครับ
    ข้อมูลมาจากที่นี่
    • กระทู้: 44008
    « ตอบกลับ #1 เมื่อ: 02 กุมภาพันธ์ 2559, 01:55:56 »
  • Turbosound Milan MI5 vs QSC K12
    • กระทู้: 44008
    « ตอบกลับ #2 เมื่อ: 02 กุมภาพันธ์ 2559, 02:00:44 »
  • นี่ของคุณ สุภชัย จัดหามา  เยี่ยมจริงๆ ลองไปดูกัน
    ลองเสียงตู้ มอนิเตอร์ ใหม่ครับเพิ่งได้มาเมื่อวาน
    TURBOSOUND MILAN M12
    • กระทู้: 44008
    « ตอบกลับ #3 เมื่อ: 02 กุมภาพันธ์ 2559, 02:02:01 »
  • ดูกันต่อ สวยจริงๆ
    • กระทู้: 44008
    « ตอบกลับ #4 เมื่อ: 02 กุมภาพันธ์ 2559, 02:02:46 »
  • Presonus 16.0.2 VS TURBOSOUND MILAN M12
    • กระทู้: 44008
    « ตอบกลับ #5 เมื่อ: 02 กุมภาพันธ์ 2559, 02:03:10 »
    • กระทู้: 44008
    « ตอบกลับ #6 เมื่อ: 02 กุมภาพันธ์ 2559, 02:04:06 »
    • กระทู้: 44008
    « ตอบกลับ #7 เมื่อ: 02 กุมภาพันธ์ 2559, 02:04:32 »
    • กระทู้: 44008
    « ตอบกลับ #8 เมื่อ: 02 กุมภาพันธ์ 2559, 02:05:05 »
