ผู้เขียน หัวข้อ: 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster  (อ่าน 5136 ครั้ง)
  • กระทู้: 43969
« เมื่อ: 03 กุมภาพันธ์ 2559, 07:10:07 »
  • 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    882 บาท
    ราคาปกติ 1,225 บาท,
    ประหยัดทันที 28%
    ราคาโปรโมชั่นสามารถใช้ได้กับ 3/2/2016
    Product details of 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    This Broadband Amplifier can add strength of the radio signal to increase the effective range and coverage area for Wi-Fi communication. Simply remove the AP/Router RP-SMA antenna and plug it into the booster female RP-SMA connector. This may even penetrate complex environments with many walls and obstacles. The benefit of the amplifier can save lots of wiring costs and easy to build.
    Description:
    Brand new and high quality
    This indoor signal booster can increase the effective range and coverage area of your Wi-Fi network
    Ideal for increase the 2400-2500Mhz frequency devices
    Simply attach the booster in between the standard antenna on a wireless router or wireless access point and watch your range grow
    The amplified wireless signal may even penetrate complex environments with many walls and obstacles
    It can save on wiring costs with this easy-to-build wireless infrastructure for home or business use
    Maximum output power of 2000mW by the Booster
    Signal activity LED
    High Gain, High Value, High Performance
    Low-noise receive gain
    Ideal for use with 2.4GHz Wireless LANs, Support 802.11b, 802.11g(2.4Ghz mode only)
    Plug-and-play, Easy installation, no driver needed
    Operation Range: 2400-2500 MHz
    Operation Mode: Bi-directional, half-duplex, Auto-Switching via carrier sensing
    Frequency Response: ┬▒ 1dB over operation range
    Input Power: 6dBm (Min.)-20dBm (Max.)
    Optimal Input Power 15 ~  18 dBm
    Output Power: 2000mW/33dBm nominal for 802.11b/11Mbps
    Connector: SMA Receptacle, 50 ohm
    Transmit Gain: 13-17dBm nominal
    Receiver Gain: 8-12dBm
    Receive Noise Figure: 3.0dBm nominal
    Operating Temperature: 20 to 70 degree
    Operating Humidity: Up to 95% relative humidity
    Material: Cast Aluminum
    Safety Certification: FCC/CE/VCC
    Size (L x W x H): Approx. 9.5 x 5.7 x 3.1 cm / 3.74 x 2.24 x 1.22 inch
    NOTE: The item needs connect with the Access Point Router together, then it can work and the Access Point Router are NOT included
    • กระทู้: 43969
    « ตอบกลับ #1 เมื่อ: 03 กุมภาพันธ์ 2559, 07:11:08 »
    Package Includes:
    1 x Booster
    1 x US Power Plug
    1 x SMA Cable
    1 x 5 dBi Antenna
    1 x User Manual
    ข้อมูลจำเพาะของ 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    รายการสินค้าในกล่อง
    1 x 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    คุณสมบัติทั่วไป
    SKU   GE127ELBM92FANTH-2387705
    สภาพ   ใหม่
    Gender   Unisex
    Size (cm)   30.00 x 21.50 x 4.00
    Product warranty   No Warranty Provided
    Weight (kg)   0.365
    ที่มา...
    « แก้ไขครั้งสุดท้าย: 03 กุมภาพันธ์ 2559, 07:13:42 โดย ▒ Auto Man ▒ »
