ผู้เขียน หัวข้อ: ลองถาม AI การเปิดไฟล์คู่มือซ่อมเบนซ์แบบ VirtualBox  (อ่าน 45 ครั้ง)
  • กระทู้: 44849
ข้อมูลภาพรวมโดย AI
To activate and use the Mercedes W210 E230 repair manual (WIS/ASRA) in VirtualBox, you need to open the pre-configured virtual machine image. These files typically come as either a .vbox (VirtualBox configuration) or a .ova (Open Virtualization Appliance) file.Here is the step-by-step activation guide:Step 1: Install VirtualBoxIf not already installed, download and install Oracle VM VirtualBox.Crucial: Install the matching Oracle VM VirtualBox Extension Pack to ensure proper USB and network support for the virtual machine.Step 2: Open/Import the Manual FileDepending on your file type, choose one of the following methods:Method A: For .OVA Files (Most Common)Open VirtualBox.Click File > Import Appliance.Click the folder icon and navigate to your downloaded .ova file.Click Next, then Import.Crucial: During import, ensure "Reinitialize MAC address" is UNTICKED.Method B: For .VBOX FilesOpen VirtualBox.Click Machine > Add.Navigate to the folder and select the file ending in .vbox.Step 3: Run the Virtual ManualOnce imported, the manual will appear on the left-hand menu.Select it and click the green Start arrow.A virtual window will open (usually running Windows XP or Windows 7/8/10) and load the Mercedes software.Important: If prompted whether you "moved it" or "copied it," select "I MOVED IT".Step 4: Activating WIS/EWAOnce the virtual Windows loads:Open the EWA or WIS icon on the desktop.Log in with default credentials (if required). Common ones are User: admin, Password: 00000 or mercedes.Use the "Quick Start Guide" found on the virtual machine's desktop to find the specific W210 E230 model.TroubleshootingScreen Size Too Small: Right-click the virtual desktop, select screen resolution, and set it to \(1920 \times 950\) or higher.Virtual Machine Won't Start: If it fails, ensure you installed the Extension Pack (Step 1).Slow Performance: Ensure your physical computer has at least 8GB of RAM, as the virtual machine requires significant resources.
