ผู้เขียน หัวข้อ: การเคลียโค๊ดในระบบ DFI  (อ่าน 4479 ครั้ง)
« เมื่อ: 26 สิงหาคม 2563, 09:24:10 »
  •    การเคลียโค๊ดในระบบ DFI
    Enter the self-diagnosis dealer mode 2 (see Self- diagnosis
    Procedures in this chapter).
    NOTE
    ○Make sure to keep the grounding until the following
    opening and grounding starts.
    •Pull the clutch lever in more than 5 seconds, and then
    release it.
    •Repeat opening and grounding [A] the lead [E] (self
    -diagnosis terminal [G]) more than five times [F] within 2
    seconds [C] after the lead is grounded, and then keep it
    grounded continuously [D] for more than 2 seconds
    3-38 FUEL SYSTEM (DFI)
    Self-Diagnosis
    Self-diagnosis Outline
    The self-diagnosis system has three modes and can be
    switched to another mode by grounding the self-diagnosis
    terminal [A].
    User Mode
    The ECU notifies the rider of troubles in DFI system and
    ignition system by lighting the FI indicator when DFI system
    and ignition system parts are faulty, and initiates fail-safe
    function. In case of serious troubles ECU stops the injection/
    ignition/starter motor operation.
    Dealer Mode 1
    The FI indicator light (LED) emits service code(s) to show
    the problem(s) which the DFI system and ignition system
    has at the moment of diagnosis.
    Dealer Mode 2
    Self-diagnosis Procedures
    ○When a problem occurs with the DFI system and ignition
    system, the DFI indicator light (LED) [A] goes on.
    NOTE
    ○Use a fully charged battery when conducting
    self-diagnosis. Otherwise, the light (LED) blinks
    very slowly or doesn’t blink.
    ○Keep the self-diagnosis terminal grounded during self
    -diagnosis, with a auxiliary lead.
    •Remove the front seat (see Front Seat Removal in the
    Frame chapter) and pull the self-diagnosis terminal [G]. •Turn the ignition switch ON. •Connect an auxiliary lead [E] for grounding to the self
    -diagnosis terminal. •To enter the self-diagnosis dealer mode 1, ground [A] the
    self-diagnosis terminal for more than 2 seconds [C], and
    then keep it grounded continuously [D].
    ○Count the blinks of the light (LED) to read the service
    code. Keep the auxiliary lead ground until you finish reading
    the service code.
    •To enter the self-diagnosis dealer mode 2 repeat opening
    and grounding [A] the lead more than five times [F]
    within 2 seconds [C] after the lead is first grounded, and
    then keep it grounded continuously [D] for more than 2
    seconds.
    Self-diagnosis Terminal [G]
    code. Keep the auxiliary lead [E] ground until you finish
    reading the service code.
    NOTE
    ○If the self-diagnosis mode is in dealer mode 1 then you
    need to enter the dealer mode 2, turn off the ignition
    switch once.
    Service Code Clearing Procedures
    https://www.kawiforums.com/threads/clearning-an-f1-code.126425/
