ผู้เขียน หัวข้อ: 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz  (อ่าน 4297 ครั้ง)
  • กระทู้: 43969
« เมื่อ: 25 กุมภาพันธ์ 2559, 07:28:15 »
  • 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    Product details of 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    This Broadband Amplifier can add strength of the radio signal to increase the effective range and coverage area for Wi-Fi communication. Simply remove the AP/Router RP-SMA antenna and plug it into the booster female RP-SMA connector. This may even penetrate complex environments with many walls and obstacles. The benefit of the amplifier can save lots of wiring costs and easy to build.
    Description:
    - Brand new and high quality
    - This indoor signal booster can increase the effective range and coverage area of your Wi-Fi network
    - Ideal for increase the 2400-2500Mhz frequency devices
    - Simply attach the booster in between the standard antenna on a wireless router or wireless access point and watch your range grow
    - The amplified wireless signal may even penetrate complex environments with many walls and obstacles
    It can save on wiring costs with this easy-to-build wireless infrastructure for home or business use
    - Maximum output power of 2000mW by the Booster
    - Signal activity LED
    - High Gain, High Value, High Performance
    - Low-noise receive gain
    - Ideal for use with 2.4GHz Wireless LANs, Support 802.11b, 802.11g(2.4Ghz mode only)
    - Plug-and-play, Easy installation, no driver needed
    - Operation Range: 2400-2500 MHz
    - Operation Mode: Bi-directional, half-duplex, Auto-Switching via carrier sensing
    - Frequency Response: ┬▒ 1dB over operation range
    - Input Power: 6dBm (Min.)-20dBm (Max.)
    - Optimal Input Power 15 ~  18 dBm
    - Output Power: 2000mW/33dBm nominal for 802.11b/11Mbps
    - Connector: SMA Receptacle, 50 ohm
    - Transmit Gain: 13-17dBm nominal
    - Receiver Gain: 8-12dBm
    - Receive Noise Figure: 3.0dBm nominal
    - Operating Temperature: 20 to 70 degree
    - Operating Humidity: Up to 95% relative humidity
    - Material: Cast Aluminum
    - Safety Certification: FCC/CE/VCC
    - Size (L x W x H): Approx. 9.5 x 5.7 x 3.1 cm / 3.74 x 2.24 x 1.22 inch
    NOTE: The item needs connect with the Access Point Router together, then it can work and the Access Point Router are NOT included
    Package Includes:
    1 x Booster
    1 x US Power Plug
    1 x SMA Cable
    1 x 5 dBi Antenna
    1 x User Manual
    ข้อมูลจำเพาะของ 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    รายการสินค้าในกล่อง
    1 x 2W Wifi Wireless Broadband Amplifier Router 2.4Ghz Power Range Signal Booster US Plug
    คุณสมบัติทั่วไป
    SKU   GE127ELBM92FANTH-2387705
    สภาพ   ใหม่
    Size (cm)                   30.00 x 21.50 x 4.00
    การรับประกันสินค้า   No Warranty Provided
    Weight (kg)           0.365
    « แก้ไขครั้งสุดท้าย: 25 กุมภาพันธ์ 2559, 07:35:51 โดย ▒ Auto Man ▒ »
    • กระทู้: 43969
    « ตอบกลับ #1 เมื่อ: 25 กุมภาพันธ์ 2559, 07:36:49 »
