ผู้เขียน หัวข้อ: Scanmatik 2 Pro มันคืออะไร  (อ่าน 3547 ครั้ง)
« เมื่อ: 22 พฤศจิกายน 2566, 17:08:47 »
  •   Scanmatik 2 Pro - one of the best j2534 / PassThru diagnostic + chip-tuning device
    The J2534-RP1210 driver for the SM2 adapter (SM2-PRO) makes it possible to work with a large number of third-party programs that support operation via the J2534 interface. The purpose of the driver development was an attempt to make not the next J2534 adapter “for show”, but the device that most meets the requirements of J2534-1 / 2 and RP1210, as far as the hardware of the SM2 and Scanmatik 2 Pro adapters allows.
    The current Windows and Android versions: Scanmatik 2.21.21
    List of tested programs:
    Allison DOC
    CAT Caterpillar Electronic Technician (CAT ET)
    Chiploader
    Chrysler Flash Application
    Combiloader
    Cummins Calterm
    Cummins Insite
    Detroit DDDL
    Eaton Service Ranger
    ECU Flasher (auto-bk)
    Ford Module Programming Tool
    Forscan
    GM GDS-2/SPS
    Hino Diagnostic Explorer
    Honda HDS
    Jaguar/Land Rover SDD
    JCB Service Master 4
    MDFLASHER
    MMC Flasher (Bruce-Willis)
    Nissan Consult 3+
    Noregon JPRO
    ODIS Service
    OpenBox
    PCMFlash
    Toyota Techstream
    Renault CAN Clip
    Volvo Premium Tech Tool PTT
    Volvo Vida
    Wabco Toolbox
    Xentry PassThru.
    Supported data buses:
    ISO-9141 / ISO-14230 (K-LINE)
    J1850VPW
    J1850PWM
    CAN
    Single Wire CAN.
    Specifications:
    Integrated multiplexer for switching diagnostic lines
    The broadest support for J2534-1 / 2 standards
    Programming voltage supply (5-24V) - to the legs of the OBD2 connector: 6, 8, 11, 12, 13, 14.
    Base kit:
    Scanmatik 2 Pro
    OBD2 cable
    USB cable
    Car cigarette lighter power cable
    Case.
    Maximum kit:
    Adapter Scanmatik SM2-PRO
    OBD2 cable
    USB cable 1.8m
    OBD2-GM 12pin
    OBD2-GAZ 12pin
    GAZ-ABS for ABS Bosch 5.3
    OBD2-Mitsubishi 12pin
    OBD2-KIA 20pin
    OBD2-Fiat 3pin for Fiat, Chery
    Deutsch 6 + 9pin
    GAZ Westport XCP
    ISO-16
    OBD2-Mercedes Benz 14pin
    SCR-MRS
    OBD2-Honda 3pin
    Case.
    Price depends on the device kit:
    Scanmatik 2 Pro (base kit) - $860
    Scanmatik 2 Pro (base kit + AUX) - $890
    Option:
    - Scanmatik 2 Pro bench cable (it's option if you will buy tool) - $140. Boot/bench cable for operation with PCMFlash boot loader modules 53 and 71. There is an indication of the ECU power supply, power, and signal control automatically. An external power supply is required to work with the cable.
    - PCMFlash dongle - $39 + any module. This is ECU loader for engine and transmission of Volkswagen, Skoda, Ford, Mazda, Mitsubishi, Nissan / Infiniti, Subaru, Honda / Acura, Hyundai / Kia, Renault, Toyota / Lexus, and others. There are universal modules Denso SH705x Bootloader and BSL TriCore. Supports work with the ADS adapter (version 1, not for all ECU), as well as any J2534 compatible adapter, with the appropriate drivers and libraries. Tested work with OpenPort 2.0, Mongoose JLR, MongoosePro JLR, Teradyne GNA600 (VCM 1), Mazda VCM 2, Scanmatik.
      ข้อมูลมาจากที่นี่...
