ผู้เขียน หัวข้อ: Suzuki F Engine  (อ่าน 6185 ครั้ง)
  • กระทู้: 44077
Suzuki F Engine
« เมื่อ: 10 กุมภาพันธ์ 2567, 07:23:14 »
  •    Suzuki F Engine
       เครื่อง 3 สูบ
    - F5A
    The smallest F engine family with 543 cc of displacement, bore and stroke size
    is 62 mm × 60 mm. The F5A was basically a three-cylinder version of the F8A
    four-cylinder engine, without the fourth cylinder and the stroke reduced from
    66 to 60 mm. Available in various versions with 6, 9, or 12 valves and SOHC or
    DOHC head designs, carburettor or fuel injection and naturally aspirated,
    turbocharged, or supercharged
    Max power: 28–64 PS (21–47 kW; 28–63 hp)
    Max torque: 41–86 N⋅m (4–9 kg⋅m; 30–63 lbf⋅ft)
    Applications:
    SOHC 6-valve
    1980–1988 Suzuki Alto SS40/CA71
    1980–1989 Suzuki Carry/Every ST40/DA71
    1981–1988 Suzuki Fronte SS40/CB71
    1982–1988 Suzuki Cervo SS40C
    1983–1988 Suzuki Mighty Boy SS40T
    SOHC 6-valve with turbocharger
    1985–1987 Suzuki Cervo SS40C
    1985–1988 Suzuki Alto CA71
    1986–1990 Suzuki Jimny JA71
    1987–1989 Suzuki Every DA71V
    SOHC 9-valve
    SOHC 9-valve with supercharger
    1987–1989 Suzuki Carry DA71T
    DOHC 12-valve
    1987–1988 Suzuki Alto CA71
    1987–1988 Suzuki Fronte CB71
    DOHC 12-valve with turbocharger
    1987–1988 Suzuki Alto Works CA71
    - F5B
    This 547 cc engine is the successor of the earlier F5A engine, with the bore
    and stroke size increased to 65 x 55 mm. It was available with 6 or 12-valve
    SOHC/DOHC head designs. Naturally aspirated and also turbocharged models,
    with an available intercooler, were on offer. These engines were only used
    between 1989 and 1990, after which the Japanese government changed the
     maximum displacement for kei cars up to 660 cc.
    Max power: 34–64 PS (25–47 kW; 34–63 hp) at 6500 to 7500 rpm
    Max torque: 42–76 N⋅m (4–8 kg⋅m; 31–56 lbf⋅ft) at 4000 to 6000 rpm
    Applications:
    SOHC 6-valve
    1989–1990 Autozam Scrum DG41
    1989–1990 Suzuki Carry/Every DA41
    1988–1990 Suzuki Alto CL11
    1988–1990 Suzuki Alto Works S CL11
    SOHC 12-valve
    1989–1990 Autozam Carol AA5
    1988–1990 Suzuki Cervo CG72
    1988–1989 Suzuki Fronte CN11S
    DOHC 12-valve
    1988–1990 Suzuki Alto Works RS CL11
    - F6A
    The fuel injected, 12-valve version of the F6A in a Suzuki Wagon R
    The twin cam, turbocharged 12-valve F6A engine longitudinally mounted
    in a Cappuccino
    This 657 cc engine was introduced in 1990. Based on the old 550 cc F5B engine,
    it retains the 65 mm bore, but with new 66 mm stroke size.
    Max power: 36–64 PS (26–47 kW; 36–63 hp) at 6000 to 7000 rpm
    Max torque: 50–90 N⋅m (5–9 kg⋅m; 37–66 lbf⋅ft) at 3500 to 4000 rpm
    Applications:
    SOHC 6-valve
    1990–1998 Autozam/Mazda Scrum DG51
    1990–1998 Autozam/Mazda Carol AA6/AC6
    1990–1998 Suzuki Alto CL22/HA11
    1990–1998 Suzuki Carry/Every DA/DC51
    1994–1998 Suzuki Cervo Mode CN21
    1990–1998 Suzuki Cervo Mode CN21
    1990–1998 Suzuki Jimny JA11/12
    1990–2000 Autozam/Mazda Scrum DG51/52
    1990–2000 Suzuki Carry/Every DA/DC/DE51-52
    1999–2000 Suzuki Carry DA/DB52
    1991–2000 Autozam/Mazda Carol AA64/AC6P/HB12
    1991–2000 Suzuki Alto Works i.e. CL21/HA11-12
    1993–1998 Suzuki Wagon R CT21
    1998–2000 Suzuki Kei HN11S/Mazda Laputa HP11S
    SOHC 12-valve
    1990–1998 Suzuki Cervo Mode CN22
    1990–2000 Autozam/Mazda Carol AA64/AC6/HB12
    1990–2000 Suzuki Alto CL22/HB11-12
    1996–2000 Mitsuoka Ray[3]
    1997–2000 Autozam/Mazda Scrum DL51/DG52
    1997–2000 Suzuki Carry/Every DA51/52
    1991–1994 Suzuki Alto Works RS CL22
    1992–1994 Autozam AZ-1 PG66SA/Suzuki Cara PG66SS
    1991–1995 Suzuki Cappuccino EA11R
    - F8B
    A SOHC 6-valve 796 cc engine, bore and stroke size is 68.5 mm × 72 mm.
    This engine has never been offered in Japan and was originally intended for
    export models of the Suzuki Alto. This engine has since become widely
    available in India, Pakistan, and China, where it has been installed in a
    wide variety of vehicles.
    Max power: 35–40 PS (26–29 kW; 35–39 hp) at 5000 to 5500 rpm
    Max torque: 62 N⋅m (46 lb⋅ft) at 3000 rpm
    Applications:
    1981–1994 Suzuki Alto 800 SS80/SB308/CA91
    1983–1988 Suzuki FX (Pakistan)
    1983–2000 Maruti 800
    1983–present Suzuki Bolan/Ravi (Pakistan)
    1984–2019 Maruti Omni (India)
    1988–2019 Suzuki Mehran (Pakistan)
    1990s Jilin JL1010/63xx (China)[4]
    1990s–2000s Changan SC10xx/63xx (China)[4]
    1990s–2001 Xi'an Qinchuan Alto (China)[5]
    1992–2008 Changan Alto (China)[5][6]
    1994–2001 Anhui Anchi MC6330E (China)
    2000s–2010s Jiangnan Alto/Zotye TT (China)[7]
    - F8C
    Main article: Daewoo S-TEC engine
    Licensed F8B engine by Daewoo Motors for their own vehicles, as a part
    of technical tie-up between Suzuki and Daewoo in 1991.[8]
    Max power: 41–52 PS (30–38 kW; 40–51 hp) at 5500 to 6000 rpm
    Max torque: 59–71 N⋅m (6–7 kg⋅m; 44–52 lbf⋅ft) at 2500 to 4500 rpm
    Daewoo F8C engine
    Applications:
    1991–2001 Daewoo Tico/Fino
    1991–2021 Daewoo Damas/Labo/Attivo (also labelled as Chevrolet CMV/CMP)
    1998–2010 Daewoo Matiz/Chevrolet Spark
    - F8D
    The SOHC 12-valve version of F8B engine, developed by Maruti Suzuki
    in India, introduced in 2000. This engine is also the cleanest in the family,
    as it was able to meet Bharat Stage VI emission standard in April 2020,[9]
    which is equivalent to Euro 6 emission standard.
    Max power: 47 PS (35 kW; 46 hp) at 6000 rpm
    Max torque: 69 N⋅m (7 kg⋅m; 51 lbf⋅ft) at 3500 rpm
    Applications:
    2000–2011 Maruti 800
    2000–2022 Maruti Suzuki Alto 800
       Four-cylinder
    - F6B
    The 658 cc F6B engine is the smallest four-cylinder engine in the family
    and also the only one with DOHC 16-valve valvetrain design. This engine
    is also the only one with turbocharger and intercooler within the four-cylinder
    variant. The bore and stroke size is 65 mm × 49.6 mm (2.56 in × 1.95 in).
    This engine shared the same 65 mm bore size of the three-cylinder F6A,
    although the stroke was shortened to 49.6 mm to keep the displacement nearly
     the same as the three-cylinder F6A, even with the additional fourth cylinder.[10]
    Max power: 64 PS (47 kW; 63 hp) at 7000 rpm
    Max torque: 82 N⋅m (8 kg⋅m; 60 lbf⋅ft) at 3500 rpm
    Application:
    January 1990–May 1997 Suzuki Cervo Mode SR-Four CN31
    - F8A
    A 797 cc with 62 mm x 66 mm bore and stroke size. The cylinder
    head design is SOHC 8-valve. This was Suzuki's first four-stroke car
    engine and also the oldest in the family.[1]
    Max power: 42 PS (31 kW; 41 hp) at 5500 rpm
    Max torque: 60 N⋅m (6 kg⋅m; 44 lbf⋅ft) at 3500 rpm
    Applications:
    1977–1981 Suzuki Jimny 8 (SJ20/LJ80)
    1977–1989 Suzuki Carry ST80-90/SK408
    1977–1982 Suzuki Cervo SC80 (Chile)
    1980s Jilin JL110 (China)[4]
    1980s–2000s Changan SC10xx/63xx (China)[4][5]
    1985–1992 Ford Pronto (Taiwan)
    - F10A
    Suzuki F10A engine, manufactured in China.
    This is a 970 cc, SOHC 8-valve engine version of F engine. The bore
    and stroke size is 65.5 mm x 72 mm. F10A is also the longest running
    F engine family. Debuted in 1978 Suzuki SC100, but most of the applications
    were ceased at least until late 1990s for international market with stricter
    emission regulation, such as in Europe. In 2005, this engine was upgraded
    with fuel injection and catalytic converter to meet Euro 2 emission standard
    for Indonesian market Suzuki Carry 1.0.[11] In 2017, this engine was
    upgraded again to meet the Euro 4 emission standard for Vietnamese market
    Suzuki Super Carry.[12] As of December 2020, F10A is still available in Vietnam
    and Myanmar.
    Max power: 40–60 PS (29–44 kW; 39–59 hp) at 5500 rpm
    Max torque: 62–78 N⋅m (6–8 kg⋅m; 46–58 lbf⋅ft) at 3000–4000 rpm
    Applications:
    1978–1982 Suzuki SC100
    1982–2006 Suzuki Jimny 1000/Samurai 1.0/Katana/Potohar SJ410[nb 3]
    1983–present Suzuki Carry ST100/SK410[nb 4]
    1985–2000 Maruti Gypsy (India)
    1985–1986 Holden Scurry (Australia)
    1986–1990 Suzuki Forsa SA410 (Indonesia)[13]
    1986–1999 Bedford/GME/Vauxhall Rascal (United Kingdom/Europe)
    1990–2000 Maruti 1000 (India)
    1992–1999 Ford Pronto (Taiwan)
    1999–2006 Suzuki Karimun SL410R (Indonesia)[14]
    2000–2012 Suzuki Alto RA410 (Pakistan)
    The 970 cc F10A engine as well as 870 cc (62 mm x 72 mm) DA/LJ462 and
    1051 cc (65.5 mm x 78 mm) DA/LJ465Q versions are available in China
    and produced by numerous Suzuki's former business partners such as Jilin,
     Jiefang, Changan, Changhe or Hafei and used in a wide number of small vehicles,
    mostly based from Suzuki Carry, Suzuki Alto or even Daihatsu Hijet.
    - F10D
    Suzuki F10D engine
    A F10D engine installed in the Maruti Wagon R.
    Overview
    Manufacturer   Maruti Suzuki
    Production   2001-2010
    Layout
    Configuration   Straight-four engine
    Displacement   1,061 cc (1.1 L; 64.7 cu in)
    Cylinder bore   68 mm (2.68 in)
    Piston stroke   72 mm (2.83 in)
    Cylinder block material   Cast iron
    Cylinder head material   Aluminium
    Valvetrain   SOHC 4 valves x cyl.
    Compression ratio   10.0:1
    Combustion
    Fuel system   Multi-port fuel injection
    Fuel type   Gasoline
    Oil system   Wet sump
    Cooling system   Water-cooled
    Output
    Power output   61–64 bhp (45.5–47.7 kW; 61.8–64.9 PS) at 6,000 rpm (EEC)
    Specific power   57.5 bhp (42.9 kW; 58.3 PS)/litre
    Torque output   8.7 kg⋅m (85 N⋅m; 63 lb⋅ft) at 3,200 rpm (EEC)
    Chronology
    Successor   Suzuki K engine
    The Suzuki F10D engine is an inline four-cylinder 1.1 L; 64.7 cu in (1,061 cc)
    engine that was developed in India by Maruti Suzuki for the domestic market.
    It was debuted in the Maruti Wagon-R in India in 2001. It was briefly installed
    in Maruti Alto and it was the engine that the first Maruti Zen Estilo came with.
    This engine is very similar to the three-cylinder F8D 12-valve engine that was
    optional on the Maruti 800 at the time. The bore and stroke of F10D is the
    same as that of the smaller sibling and shares quite a few parts like pistons,
     rings, connecting rods, and valves. The cast-iron engine block is very similar
     to that of the older 1.0 L (970 cc) F10A engine that powered the earlier Maruti
    Gypsy and Maruti 1000. Both F10A and F10D shares the same stroke length;
    but interchangeability of parts between these two engines is limited, and in
    some cases unknown, with current findings listed below:
    Likeness:
    F10A/F10D transmission bellhousing bolt patterns and diameters are the same,
    and it is possible to swap transmissions between A and D engines.
    F10A/F10D both have the same engine mounting points threaded into the side
    of the engine block.
    F10A/F10D have identical oil filter mounting points, the extended oil filter housing
    from the D can be fitted to the A, or the oil filter spigot from the A fitted to the D
    Differences:
    F10A intake and exhaust manifolds will not fit the F10D engine (or vice versa) due to
    difference in the cylinder head bolt patterns and port spacing.
    F10A oil dipstick tube is located in the centre of the block on the right-hand side,
    the F10Ds is front mounted on the right hand side with no port drilling in the centre
    of the block.
    The F10D got a contemporary SOHC alloy cylinder head with 4 valves per cylinder
    and MPFI.[15] The earlier engines made 62 bhp (46.2 kW) and the late model 32-bit
    ECU raised it to 64 bhp (47.7 kW). It is very respectable performance for naturally
    aspirated 1.1 L engine. Maruti re-engineered and optimized the F10D after a few years
    of its introduction. This "low friction engine" as it was called has a revised engine block,
    lighter crank and revised oil pump.
    The head is much longer than the F10A version, with a three-inch overhang over the
    gearbox, due to a sensor on the end of the camshaft in place of a traditional distributor,
    and with a cast aluminium coolant outlet bolted onto the block, consisting of a thermostat,
    protruding even further.
    The FWD F10D sump is different shape and length, the block has differing bolt hole
    arrangement. The oil pick up pipe and it's mounting points are completely dissimilar
    on the RWD F10A, and both have different cranks and bearing caps
    While the F10A and F10D could bolt to each other's FWD/RWD gearboxes and engine
    mounts, the F10D occupies more space and would need an updated oil feed system.
    Maruti announced in September 2009 that the F10D would not meet upcoming
    Euro 4 emissions norms and was to be phased out in 2010. It was replaced by
    the new 3- and 4-cylinder K-series engines.
    Bore/stroke ratio : 0.95
    Unitary capacity  : 265.25 cc (16.19 cu in) /cylinder
    bmep  : 146 psi (1,006.6 kPa)
    Specific torque  : 8.2 kg⋅m (80.4 N⋅m; 59.3 lb⋅ft)/litre
    Main bearings : 5
    Applications:
    1999–2010 Maruti Suzuki Wagon R (India)
    2001–2010 Suzuki/Maruti Alto
    2006–2009 Maruti Zen Estilo/Suzuki Karimun Estilo (India/Indonesia)
    « แก้ไขครั้งสุดท้าย: 10 กุมภาพันธ์ 2567, 08:09:42 โดย Auto Man »
    • กระทู้: 44077
    Suzuki F Engine
    « ตอบกลับ #1 เมื่อ: 10 กุมภาพันธ์ 2567, 08:22:23 »
     Suzuki Alto F5A Service Manual! (SuzukiHatchF5AServiceManual.pdf) 16.1Mbyte!
     Suzuki Hatch Alto F5A Service Manual! (Suzuki_Hatch_Alto_F5A_Service_Manual.pdf) 53,5 Mbyte!
     Suzuki Hatch Alto F8B Service Manual! (Suzuki_Hatch_Alto_F8B_Service_Manual.pdf) 64,3 Mbyte!
     Daewoo Matiz Service Manual! (Daewoo Matiz.pdf) 36Mb!
     Daihatsu Charade Service Manual! CB21 CB80 & CB61 (Daihatsu CB Engine - CB23 CB61 CB80.pdf) 9,81Mb!
    Funny movie: Did you do the same in your mama?
     Gearbox ratio's (MA5 Gearbox ratio's.xls)
     Melett Part List KKK14 Turbo
    Suzuki F Engine
