ผู้เขียน หัวข้อ: Diagnostic kit for Yamaha Outboard Engines & PWC Using this Diagnostic Kit  (อ่าน 1487 ครั้ง)
  • กระทู้: 44104
« เมื่อ: 05 กันยายน 2567, 13:00:28 »
  •    Diagnostic kit for Yamaha Outboard Engines & PWC
    Using this Diagnostic Kit with the Yamaha ® Diagnostics Software Program, you can make many tests and analyses of Yamaha Outboard engines & PWC.
         ไฟไม่โชว์ วิ่งไม่ออก แต่กินน้ำมันเยอะ แล้วมันเป็นปัญหาที่อะไร
    เพื่อมีตัวช่วยก็คงต้องหาเครื่องมือในการหาปัญหาและวิเคราะห์
       The Yamaha Diagnostics can finally be offered to the independant powersports workshop
    or DIY home mechanic.
    The "Yamaha Diagnostics Software Program" communicates with the Engine Control Unit ("ECU")
    and the Engine Management Module ("EMM") and is used for retrieving engine diagnostic information,
    setting engine operating parameters, performing engine maintenance and printing engine reports on
     Yamaha engines.
    The diagnostic kit includes:
    - YDS Diagnostic device with cables (main unit for diagnosis of Yamaha engines)
    - USB Flash drive with software
       - Unlimited updates via the downloadable website,
       - Access to the workshop (service manuals)
       - User manual
    - 24 MONTHS WARRANTY
      Using this Diagnostic Kit with the Yamaha Diagnostics Software Program,
    you can make many tests and analyses, such as:
    - Reading and resetting the fault code(s).
    - Reading the EMM module identification.
    - Reading sensors and actuators in real time.
    - Reading of technical parameters in real-time.
    - Tests operation of the electric fuel pump.
    - Tests sensors and actuators in real time.
    - Tests operation of the injectors and high voltage coils.
    - Generating the graphics of engine operation.
    - Reading the serial numbers of the injectors.
    - Replace the injector and injector data file.
    - Reading of temperature and voltage of the TPS.
    - Printing or export of diagnostic data to PDF files.
    - Other tests and analyzes.
    Compatible with: Supports up to 2017 model years
    All Yamaha EFI 4-Stroke outboard models:
    F30 , F40 , F50 , T50 , F60, FT60, T60 , F70 , F75 , F90 , F115 , LF115 , F150 ,
    FL115, LF150, FL150, F200 , FL200, LF200 , F225 , FL225, LF225, F250 , FL250,
    LF250 , F300 , FL300, LF300 , F350 , FL350, LF350
    All Yamaha HPDI OUTBOARD MODELS
    Z150 , LZ150 , VZ150 , Z175 , VZ175 , Z200 , LZ200 , VZ200 ,VZ200 , Z225 ,
    VZ225 , Z250 , LZ250 , VZ250 , Z300 , LZ300 , VZ300
    JET-SKI MODELS
    GP1300R , VX , VX CRUISER , VX DELUXE , VX SPORT , FX , FX CRUISER ,
    FX HO FX CRUISER HO , FX SHO , FX CRUISER SHO , FZR , FZS , VX18R , VX18S
    JET-BOAT MODELS
    SR230 , SR230 HO , SX230 , SX230 HO , AR210 , AR230 , AR230 HO , SX210 ,
    212X , 212SS , 232 LIMITED , AR240 , AR240 HO , SX240 , AR190 , SX240 ,
    SX240 HO, 242 LIMITED
    ALL MERCURY MARINE 75, 90, 115 and 225 EFI 4-Strokes manufactured by Yamaha Marine
    The software will NOT work on Yamaha OX66 fuel injected engines, Yamaha carbureted engine!
    Language support in Software: English
    Minimum computer requirements:
    Computer with installed Windows XP, Windows 7, Windows 8, Windows 10 or Windows 11 operating system,
    VGA or higher resolution display (SVGA),
    Mouse or other pointing device,
    At least 300Mb of free space on HDD,
    One unused USB port
    • กระทู้: 44104
    « ตอบกลับ #1 เมื่อ: 05 กันยายน 2567, 13:02:49 »
    • กระทู้: 44104
    « ตอบกลับ #2 เมื่อ: 05 กันยายน 2567, 13:28:04 »
  • YAMAHA DIAGNOSTIC SYSTEM Outboards Watercraft
    • คุณต้องเป็นสมาชิกของกลุ่มใดกลุ่มหนึ่งต่อไปนี้: Administrator.
