ผู้เขียน หัวข้อ: เครื่องล้างและทดสอบหัวฉีดเบนซิน Autool CT200  (อ่าน 1975 ครั้ง)
  • กระทู้: 43783
  • กระทู้: 43783
« ตอบกลับ #1 เมื่อ: 08 กันยายน 2567, 08:35:10 »
  • CT200 Fuel Injector Cleaner & Tester
       The CT200 is an injector cleaner and tester machine that combines ultrasonic cleaning
    technology with oil pressure control cleaning and inspection technology. It can simulate
    various working conditions of the engine to clean and test the injectors. It can support
    6-cylinder injectors at the same time, saving time, and efficiency. Also supports testing
    of fuel injectors for most cars and motorcycles in the market. Since its launch, AUTOOL
    CT200 model has been widely received and approved by professional auto repair technicians.
         It is an expert in Injector solutions, featuring 12 injector-specific functions
    Ultrasonic cleaning: It sends signals to the injectors through the pulse signal line, using the
    cleaning fluid with the ultrasonic vibration so as to completely remove the carbon and impurities
    inside the injectors.
        Idle speed test (0-20ms): Simulate the engine idling speed and test the state of the fuel injector.
    Medium speed test (0-7.5ms): simulate the engine running at medium speed and test the state of
    the fuel injector.
        High-speed test (0-4ms): Simulate the high-speed performance of the engine and test the state
        Acceleration test: Simulate the acceleration state of the car and test the performance of the
    fuel injector.
        Shift speed test: Simulate the shifting state of the car and test the working performance of
    the fuel injector.
       Leakage test: Test the sealing condition of the fuel injector.
    Idle dpeed sprayability Test: Simulate the engine idling state and test the spraying performance
    Medium speed sprayability test: Simulate the engine medium-speed state and test the spraying
    performance of the fuel injector.
    High-speed sprayability test: Simulate the high-speed state of the engine and test the spraying
    Reverse flush: Reverse flush is a way to clean the injectors with the test liquid flowing from the
    outlet to the inlet of the injector. Reverse flush may remove the dirt inside the injector or the
    injector Strainer (Only for the top fuel supply injector).
    No-disassembly cleaning: Direct cleaning without disassembling the injectors, this function is an
    additional function, which requires special adapters.
    Cleaning fluid & Test fluid recovery valve
    After the cleaning or tetsing is completed, the fluid needs to be recovered through the valve, which
    has the advantage of:
    Damage will be caused to the product of the liquid is left inside the cleaning bath for a long time.
    The recovered liquid can be reused, thus saving your cost.
    Pressure gauge
    It allows you to observe the pressure during test to avoid damage to machine or injectors
    caused by excessive pressure.
    Test level gauge
    It allows you to observe the amount of test fluid directly and clearly.
    Full inspection of injectors
    Uniformity test: To test the uniformity of injecting amount of each injector.
    Sprayability test: To monitor the spraying status of each injector with the help of backlight.
    Leakage test: To test the sealing and dribbling conditions of injectors under high pressure.
    Injecting flow test: To check the injecting amount of the injector of specific injection condition(eg. same time and number of times).
    AUTOOL CT200 model supports 110V/220V supply voltage, as well as simultaneous cleaning
    and testing of 6-cylinder injectors; Increase efficiency and save time. You can also optionally
    test two injectors or four injectors for your different needs.
      How to choose test fluid?
    The test fluid is used to test and judge whether the performance of the fuel injector is in good
    condition. It is a colorless and transparent liquid with no irritating odor, non-corrosive, and not
    easy to emit. Its function is to simulate various working states of the fuel injector as a medium.
    In order to achieve the best test effect, it is recommended to use professional automotive injector
    test fluids. If it is not available locally, as an alternative, it\'s recommended that medical alcohol
    with an alcohol content of more than 75% can be used instead of the test fluid.
    How to choose cleaning fluid?
    Cleaning fluid is used to clean deposits (such as carbon deposits) on fuel injectors, and it is usually
    highly corrosive and flammable. In order to achieve the best test effect, it is recommended to use
    professional injector ultrasonic cleaning fluid. If it is not available locally, it\'s recommended that
    medical alcohol with an alcohol content of more than 75% can be used instead of the cleaning fluid,
    but note that the effect may not good enough.
    How does the CT200 work?
    Ultrasonic Cleaning:
    Add the cleaning fluid and put the injectors into the ultrasonic cleaning bath.
    Connect the pulse signal lines and select the item 1 Ultrasonic Cleaning function to start.
    Ultrasonic cleaning bath size: 150x84x64(mm), power: 50W.
    Injector Testing
    First add the test fluid, then install the injectors on the fuel distributor, and fix them with bolts.
    Different functions can be selected to test to see if any of the injectors are leaking or blocked.
    Precautions for injector test fluid and cleaning fluid
    Do not use corrosive fluids as injector test fluids to test the injectors. Corrosive fluids can
    damage machine seals and injectors.
    Do not use cleaning fluids instead of test fluids, as cleaning fluids are generally corrosive and
    can damage machine and injector seals.
    It is strictly forbidden to use gasoline instead of cleaning fluid or testing fluid, which is very
    dangerous! It may cause safety hazards!
    Packing list:
    1pc* AUTOOL CT200 Fuel Injector Cleaner Tester Main Unit;
    1pc* Funnel(for adding test fluid);
    1pc* Ultrasonic Cleaning Bracket(for placing the injectors during cleaning);
    2pcs* Drain Valves(For recovering the cleaning and test fluid );
    2pcs* Fixing rods(For fixing the oil separator);
    2pcs* Fixing Nuts(For fixing the oil separator);
    6pcs* Reverse flush connectors φ15.8mm(for connecting the bottom of the injector and the oil separator hole)
    6pcs* Conical top inlet connectors φ10.5mm&13.6mm (for connecting the top of the injector and the oil separator hole)
    6pcs* Adapter cables(For transferring the pulse signal line connector, instead of connecting the injector signal input pin)
    1pc* Power Cable(for connecting power supply);
    1pc* Oil Separator(Distribution device for outputting pressurized test fluid to the injectors);
    6pcs* Special injector gaskets(for auxiliary installation of special fuel injectors)
    5pcs* Special plugs for oil separator(used to block the holes on the oil separator)
    1pc* Ultrasonic Cleaning Cover(for keeping the cleaning bath clean)
    1pc* User Manual(Instructions)
