ผู้เขียน หัวข้อ: Update SM2 To หลังอัพ V 2.21.32 เทียบเท่าแท้  (อ่าน 361 ครั้ง)
  • กระทู้: 44121
« เมื่อ: 02 กันยายน 2568, 10:25:36 »
    SM2 Firmware Version 2.21.32 – February 4, 2025
    – J2534: CM3 fixed message timeout processing error (appeared in PCMFlash 58, 62, 79, 80, 82, 94 and other programs)
    – J2534: improved GPT signal generation algorithm for CM2/CM2PRO (for Renault EDC16C3, EDC16CP33 ECUs, etc.)
    – KAMAZ: added diagnostics of the CBEU unit 211.386700 with USD2.2 protocol
    – KAMAZ: SORL EBS variable names corrected
    – HAVAL: adjustment of the algorithm and training conditions of VVL F7/JOLION/DARGO
    – other changes
    V2.21.31 – January 25, 2025
    – KAMAZ: added units SORL ECAS, SORL EBS(K5), SORL CM-ESC(Compass), BCM(Compass electrical package), ICM (Compass instrument cluster)
    – J2534: CM3 multiple improvements based on feedback on unstable operation with PCMFlash loaders (77, 53, 82 and others), Combiloader and others.
    – J2534: Renault ASOS dealer program did not work due to the ability to connect to CM2 as CM3 and vice versa (now you need to select the exact adapter model in all programs)
    – PAZ: Wabco JED677 did not work with CM3 adapter
    – other changes
    Version 2.21.30 – December 13, 2024
    – GAZ: added body electronics ECU BCM A31R33.3765100 (Gazelle/Sobol NN)
    – GAZ: added ECU body electronics UHM A31R33.3765X10 (Gazelle/Sobol NN)
    – VAZ: support for units manufactured by NPO Itelma has been added to the ABS KESENS ECU
    – J2534: CM3 fixed the problem with 100% CPU core load in J2534 applications (Combiloader, PCMFlash, etc.)
    – RP1210: CM3 fixed bug with sending messages via J1939 protocol (found in Cummins Calterm)
    – other changes
     2.21.29 – December 4, 2024
    – fixed a bug in version 2.21.28 that caused the PCMFlash program to crash in modules 71, 77, 92
     2.21.28 – December 3, 2024
    – Added support for SM3 adapters
    – New USB driver supports ARM, ARM64 architectures
    – J2534: DoIP support for MB Xentry PassThru (W206, W223) for SM3 adapters implemented
    – J2534: Support for CAN-FD channels according to J2534-1 has been implemented for SM3 adapters
    – VAZ: PRIORA electrical package – on early firmware versions the program displays a warning about incorrect data issued by the ECU
    – Ravon: in version 2.21.27 the brand menu did not open
    – support for versions before Windows 7 has been discontinued
    SM2 2.21.27 – November 27, 2024
    – VAZ: BCM Itelma unit added (Vesta NG)
    – VAZ: WLY CVT18 unit added (Vesta NG)
    – VAZ: added SRS ECU Conti –0954 (Xray, Largus, Granta)
    – VAZ: ESCL Worldtech unit added (Vesta NG)
    – VAZ: ECU BDFKE added IM control and support for different software versions
    – VAZ: MMC Enjoy fixed configuration item “Buttons”
    – GAZ: Foton Gxx ECU (MD1CS089) added support for new software versions
    – Greatwall: Jolion SRS fixed the function of switching to normal/factory modes
    – J2534: Fixed a bug that caused incompatibility with Windows XP
    – J2534: Fixed ignition emulator for Nissan Consult
    – J2534: added support for Renault Clip up to version V236
    – Android: fixed a bug that caused the recording of variables to be interrupted on some ECUs
    – Wabco: ABSEplus CAN new firmware versions added (08020205, 08020207)
    – Wabco: ECAS CAN2 new firmware versions added (108E0101)
    – KAMAZ, GAZ, PAZ: added ABS unit SORL ECU CM4XL-25VI-EDB
    – other changes
    Version 2.21.26 – February 25, 2024
    GAS: added ECU M74.9 UMP
    VAZ: added ECU Multimedia EnjoY
    J2534: added support for Clip up to version V234
    J2534: updated ignition emulator function for ODIS latest versions (S-23, E-17)
    Android: added support for Android 14
    2.21.25 – February 14, 2024
    – VAZ: ABS control unit KESENS C102 added
    – VAZ: added block of additional functions of body electronics (BDKFE 84500331101) Vesta
    – GAS: added engine ECU MD1CS089 Foton Gxx FD25 (Gazelle, Valdai)
    – Wabco EBS3: added diagnostics of Std EBS3.1 (4461352410), Std EBS 3.2 (4461352420), EBS3.3 (4461352460) units
    – KAMAZ: M240S1 corrected display of SCR temperatures, added variables for outputs, synchronization of KV-RV, etc.
    – R1210: Fixed bug with receiving ISO15765 messages (introduced in 2.21.23)
    – other changes
    2.21.24 – December 26, 2023
    – UAZ: added ECM unit AECS D+ AY3201479
    – UAZ: added ABS APG block
    – MAZ: added Knorr-Bremse ELC5 unit (air suspension)
    – Greatwall: added diagnostics for HAVAL Dargo (all systems)
    – Greatwall: added various procedures for models H9, F7, Jolion (sensor training, etc.)
    – PAZ MD22: display of the status of discrete inputs has been fixed
    – KAMAZ: autodetection did not work
    – Hyundai: at 2.21.23 there was no connection with some units via K-line
    – VAZ: fixed display of service records on the M86 ECM
    – VAZ: fixed crash of the program when auto-detecting a vehicle with an M74K ECM
    Version 2.21.23 – December 01, 2023
     VAZ: added support for ECU M74.8 and M74.9
    KAMAZ: added support for ECU M240.S1 CAN K5 P6 (diagnostics and programming)
    Greatwall: added diagnostics of Haval H9 cars (all units)
    Greatwall: added diagnostics of Haval Jolion cars (all units)
     Greatwall: DCM3.7 H6 injector coding procedure fixed
    Wabco ABS E4,E8: added steering position sensor (SAS) calibration functions
     J2534: Added support for UART Echobyte protocol
    J2534: Clip support up to and including version 232
    J2534: Added support for long messages via J1850 VPW
    other changes
    News&Notice|0 Comm
    « แก้ไขครั้งสุดท้าย: 02 กันยายน 2568, 11:07:21 โดย Auto Man »
    • กระทู้: 44121
    « ตอบกลับ #1 เมื่อ: 02 กันยายน 2568, 10:31:18 »
  • โคลน SM2 PRO อัปเดตเฟิร์มแวร์เป็น V2.21.32
      ผู้ซื้อได้รับการยืนยันแล้วว่า โคลน SM2 PRO J2534 VCIนี้ทำงานได้อย่างสมบูรณ์แบบกับเฟิร์มแวร์ V2.21.32
    คุณต้องแฟลชเฟิร์มแวร์ด้วยเครื่องมือ ST-Link อัปเกรดจาก V2.21.22 เป็น V2.21.32 (2025/กุมภาพันธ์)
    หลังจากอัปเดตแล้ว จะให้การปรับปรุงเมื่อใช้ซอฟต์แวร์บางตัว อ่านโพสต์นี้เกี่ยวกับวิธีการแฟลชเฟิร์มแวร์
    « แก้ไขครั้งสุดท้าย: 02 กันยายน 2568, 11:02:28 โดย Auto Man »
