ผู้เขียน หัวข้อ: BROTHER DCP-T300 + INK TANK ราคา 4,550 บาท  (อ่าน 4447 ครั้ง)
  • กระทู้: 43826
« เมื่อ: 04 มิถุนายน 2559, 12:41:00 »
    • Print Resolution :1200 x 6000 dpi
    • Scan Resolution : 1200 x 2400 dpi (Optical)
    • Print Speed : Bk 27/Col 10 ppm
    ราคา 4,550 บาท ประกัน 1 ปี
    รายละเอียด BROTHER DCP-T300 + INK TANK
    Functions   Print Speed   Print Resolution
    Print, Scan, Copy   Fast print speeds up to 27/10 ppm (mono/colour) in Fast Mode
    Up to 11/6ipm (mono/colour) based on ISO/IEC 24734
    Click here for more.   Up to 1,200 x 6,000 dpi
    Designed to give high print volume users bigger savings, Brother's inkjet Multi-Function Centre series features Refill Tank System that offers highly affordable ink bottles with ultra-high 6000 page-yield#. Besides enjoying low running cost, users also benefit from a smarter design that makes ink refilling effortless!
    #Refers to black ink. Colour ink: 5000 page-yield. Approx. yields are extrapolated based on Brother original methodology using Test Patterns ISO/IEC 24712. Approx. yields are not based on ISO/IEC 24711.
    Main Features
    Exceeding Low Running Costs
    Enjoy low running cost with exceedingly affordable ultra-high 6000 page-yield# ink bottles. Reduce ink wastage with individual ink bottle refill system that allows you to replace only the colours you need. Plus, easily produce 2-up and 4-up on a single sheet. This saves paper when viewing drafts or layouts.
    Easy Ink Refilling
    Easy Ink Refilling
    Refilling is easily done in 3 simple steps, thanks to easily accesible ink tank at the front.
    Minimizes Ink Spillage
    Minimise Ink Spillage
    Smart design allows for ink refilling at an optimised 45⁰ refilling angle. This minimises ink leakage and takes the hassle out of refilling.
    Saves Space and Convenient
    Save Space and Convenient
    Designed with embedded front-access ink tank and see-through cover, Brother's Refill Tank System saves space effectively, and makes it easy to check how much ink is left.
    Improve Productivity
    Featuring high print speeds of 11/6ipm* , time is saved when there are large volume printing tasks. Users can utilise their time more efficiently instead of waiting for their printouts. Furthermore, with paper input of up to 100 sheets, users avoid having to refill paper tray too frequently.
    *ISO/IEC 24734. Click here to find out more about Brother print speed.
    Save Time
    Save Time
    Enjoy convenience of less-frequent ink purchases with ultra high-yield ink bottles. Plus, save valuable time as you can still print in black even if colour runs out.
    Professional Quality
    Our colour inkjet series deliver consistent and high quality results with sharp images and crisp text. Our Multi-Function Centres offer unique colour enhancement designed to optimise your color prints with true to life colours. Brother blackpigment ink* will provide you with sharp text printing on standard paper. It is water resistant so it won't smudge. You get consistently sharp text every time.
    • กระทู้: 43826
    « ตอบกลับ #1 เมื่อ: 04 มิถุนายน 2559, 12:42:51 »
  • มาจากที่นี่เด้อ
    https://www.advice.co.th/product/inkjet-printer/inkjet-all-in-one/brother-dcp-t300-ink-tank
       ส่วนใครเงินไม่ถึง ก็ตัวนี้ DCP-J100  ร้าน Advice ราคา 3,850 ไม่รู้รวมติดแทงค์หรือยัง
    « แก้ไขครั้งสุดท้าย: 24 ตุลาคม 2559, 13:05:36 โดย Auto Man »
