ผู้เขียน หัวข้อ: ความหมายแต่ละหลักของโค๊ด OBD-II  (อ่าน 5230 ครั้ง)
  • กระทู้: 43849
« เมื่อ: 03 กรกฎาคม 2559, 06:56:02 »
  • OBD2 Codes Explained
    OBD-II codes consist of a number of parts. Here is a sample OBD2 code:
    P0171
    Here is a breakdown of what each digit of the code means:
    The first character identifies identifies the system related to the trouble code.
    • P = Powertrain
    • B = Body
    • C = Chassis
    • U = Undefined
    The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code.
    0 = Generic (this is the digit zero -- not the letter "O")
    1 = Enhanced (manufacturer specific)
    The third digit denotes the type of sub-system that pertains to the code
    1 = Emission Management (Fuel or Air)
    2 = Injector Circuit (Fuel or Air)
    3 = Ignition or Misfire
    4 = Emission Control
    5 = Vehicle Speed & Idle Control
    6 = Computer & Output Circuit
    7 = Transmission
    8 = Transmission
    9 = SAE Reserved
    0 = SAE Reserved
    These digits, along with the others, are variable, and relate to a particular problem. For example,a P0171 code means P0171 - System Too Lean (Bank 1). To lookup your particular code, visit our OBD Trouble Codes section.
    ที่มา...  http://www.obd-codes.com/faq/obd2-codes-explained.php
    « แก้ไขครั้งสุดท้าย: 03 กรกฎาคม 2559, 07:05:25 โดย Auto Man »
