ผู้เขียน หัวข้อ: เอา ECM/PCM Pinout Wiring Diagram (Honda Civic) มาฝาก  (อ่าน 13750 ครั้ง)
  • กระทู้: 44077
« เมื่อ: 08 สิงหาคม 2559, 13:45:44 »
  • เผื่อใครจะมี Idea ทำอะไรเล่นกัน
    ECM/PCM Pinout
    2001-2003 Honda Civic ECU Wiring
    Connector A (31 Pins)
    1-blk/wht-Primary O2 sensor heater control
    2-yel/blk-Power Source
    3-yel/blk-Power source
    4-blk-Power ground
    5-blk-Power ground
    6-wht-Primary O2 sensor
    7-blu-Crankshaft position
    8-yel-Sensor return volt
    9-red/blu-Knock sensor
    10-grn/yel-Sensor ground
    11-grn/wht-Sensor ground
    12-blk/red-Idle air control valve
    13-wht/blk-EGR Valve position VTEC ONLY
    14-blk/wht-Secondary O2 sensor heater control
    15-red/blk-Throttle position sensor
    18-wht/grn-Vehicle speed sensor
    19-grn/red-MAP Sensor
    20-yel/blu-Sensor Voltage Supply
    21-yel/red-Sensor Voltage Supply
    23-brn/yel-Logic ground
    24-brn/yel-logic ground
    25-wht/red-Secondary O2 Sensor
    26-grn-Top dead center sensor
    27-brn-Igniton coil 4
    28-wht/blu-coil 3
    29-blu/red-coil 2
    30-yel/grn-coil 1
    Connector B (24 Pins)
    2-yel-Fuel injector 4
    3-blu-Injector 3
    4-red-Injector 2
    5-brn-Injector 1
    6-grn-Radiator fan control
    7-red/blk-A/T Pressure control solenoid valve A
    8-red/wht-Engine Coolant sensor
    9-blu/blk-VTEC Oil pressure switch VTEC ONLY
    10-wht/blu-Alternator L Signal
    13-wht/red-Alternator FR Signal
    14-blu/red-EGR Valve VTEC ONLY
    15-grn/yel-VTEC Solenoid valve
    16-blk/red-A/T Pressure control solenoid valve B
    17-red/yel-Intake air temp sensor
    18-wht/grn-Alternator control
    21-yel/blu-EVAP Canistor purge valve
    Connector C (22 Pins)– AUTO TRANSMISSION ONLY
    1-wht/blk-A/T Pressure control solenoid valve A
    2-yel/blu-Torque converter clutch solenoid
    4-grn/wht-Shift solenoid B
    6-blu/blk-Shift Solenoid A
    7-wht/red-Mainshaft speed sensor
    8-brn/wht-A/T Pressure control solenoid valve B
    9-red-Position switch D3
    10-wht-position switch R
    11-blu-position switch 2
    12-blu/wht-position switch neutral or park
    14-grn-countershaft speed sensor ground
    15-blu-countershaft speed sensor
    18-blu/yel-position switch D3 or D
    20-yel-position switch D
    21-wht/grn-mainshaft speed sensor ground
    Connector E (31 pins)
    1-grn/yel-Immobilizer fuel pump relay
    2-wht/red-Secondary O2 Sensor EX Only
    4-pnk-Sensor ground
    5-yel/blu-Sensor voltage source
    6-blk/wht-Secondary O2 sensor heater control EX Only
    7-red/yel-PGM-FI main relay 1
    9-yel/blk-Ignition input signal
    12-blu/orn-Cruise control signal
    13-wht/blu-Interlock control unit
    14-lt grn-Fuel tank pressure sensor
    15-grn/red-Electrical load detector
    16-lt grn/blk-Power steering pressure switch
    18-red-A/C Clutch
    20-blu/red-EVAP bypass solenoid valve
    21-lt grn/red-EVAP Canister shut valve
    22-wht/blk-Brake pedal position switch
    23-lt blu-K line
    24-yel-Multiplex control unit comm line
    26-blu-Engine speed pulse
    27-red/blu-Immobilizer code
    29-brn-Service check signal
    30-red/wht-Write enable signal
    31-grn/orn-MIL or check engine light enable
    « แก้ไขครั้งสุดท้าย: 12 พฤศจิกายน 2565, 17:25:27 โดย Auto Man »
    • กระทู้: 44077
    « ตอบกลับ #1 เมื่อ: 08 สิงหาคม 2559, 13:46:48 »
    • กระทู้: 44077
    « ตอบกลับ #2 เมื่อ: 08 สิงหาคม 2559, 14:45:56 »
    • กระทู้: 44077
    « แก้ไขครั้งสุดท้าย: 30 มกราคม 2560, 12:00:51 โดย Auto Man »
    • กระทู้: 44077
    เอกชัย แก้วนิวงศ์
    « ตอบกลับ #5 เมื่อ: 19 มกราคม 2560, 08:57:37 »
  •  -OOO-
    vichienthampracha
    « ตอบกลับ #6 เมื่อ: 21 มกราคม 2560, 21:33:33 »
  • มี ECM/PCM Pinout Wiring Diagram Honda กล่องเบอร์ 37820-psa-j51 หรือเปล่าครับ
    • กระทู้: 44077
    « ตอบกลับ #7 เมื่อ: 22 มกราคม 2560, 08:14:57 »
       บอกรายละเอียดเพิ่มเติมหน่อย รุ่นรถ ปี เกียร์อะไร นำเข้าไหม ประมาณนี้ จะได้ช่วยกันตามหา
    vichienthampracha
    « ตอบกลับ #8 เมื่อ: 22 มกราคม 2560, 20:01:44 »
  • ขอบคุณครับ !!!เป็นเครื่องที่มาจาก Honda Stream Japan นำเข้าไม่ทราบว่าปีอะไร  จะเอามาใส่ Isuzu vertec (น่าจะตาโต)
    • กระทู้: 44077
    « ตอบกลับ #9 เมื่อ: 29 มกราคม 2560, 09:41:15 »
  • ลองดูเรื่องราวรหัสกล่องอีซียู หรืออีซีเอ็มรถยนต์ Honda
    ECU Part Numbers
    All Honda ECUs have a part number which is located on the side of the ECU and inside the ECU on the connector. e.g. 37820-P72-A01
    The part number consists of three components:
    Honda's part number for ECU, which is always 37820
    Three characters (which are loosely related to the model of car/engine). e.g P72
    Three characters (which are the revision of the ECU) e.g. A01
    The middle three characters are the most useful to identify what the ECU is. Different generation ECUs may use the same characters. e.g. a P72 OBD I ECU is different from a P72 OBD II ECU. Here is a list of common ECUs:
    PG6: 88-89 Integra (all makes)
    PM5: 88-91 Civic/CRX DX
    PM6: 88-91 Civic/CRX SOHC Si
    PM7: 89-91 DOHC ZC (JDM 'EF' ECU)
    PM8: 88-91 CRX HF
    PR2: 89-91 ZC (Euro)
    PR3: 89-91 JDM B16A EF8/9
    PR3-J00 or J51: 92 JDM Integra B16A EF8/9
    PW0: 89-91 JDM B16A EF8/9 DA6-XSi
    PR4: 90-91 Integra LS/GS
    PS9: 88-91 4 door Civic EX Auto
    P05: 92-95 OBD-1 Civic CX
    P06: 92-95 OBD-1 Civic DX
    P07: 92-95 OBD-1 Civic VX
    P08: 92-95 OBD-1 Civic D15 JDM
    P0A: 94-95 OBD-1 Accord EX
    P13: 93-95 OBD-1 Prelude Vtec
    P14: 93-95 OBD-1 Prelude Si (non Vtec)
    P27: 92-95 OBD-1 EG JDM Civic 1600 sohc
    P28: 92-95 OBD-1 Civic Si/Ex
    P30: 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
    P54-G31: 1997 Honda Accord 1.8 LS
    P61: 92-93 OBD-1 Integra GSR
    P72: 94-95 OBD-1 Integra GSR
    P72: 96-00 OBD-2 Integra GSR
    P73: 96-00 OBD-2 Integra Type-R (JDM & USDM)
    P74/75: 92-95 OBD-1 Integra LS/GS
    P75: 96-00 OBD-2 Integra LS/GS
    P2N: 96+ OBD-2 Civic HX Coupe
    P2P: 96+ OBD-2 Civic EX Coupe
    P2E: 96+ OBD-2 Civic DX Coupe
    P2M: 96+ OBD-2 NZ Civic SOHC VTEC
    P2T: 99+ OBD-? Civic Si Coupe
    P5P: 97-00 OBD-2 Prelude Type-S (JDM ECU)
    PBA: 97+ US Acura 1.6EL
    PCT: 98+ JDM ITR / CTR
    PCX: 99+ OBD-? S2000
    PICS OF WHAT ECU IT IS....
    From top to bottom...
    1. OBD IIb ECU
    2. OBD II ECU
    3. OBD I ECU
    4. OBD 0 (JDM PR3 and PWO)
    • กระทู้: 44077
    « ตอบกลับ #10 เมื่อ: 29 มกราคม 2560, 09:44:44 »
  • เบอร์กล่องสำคัญไฉน...
    in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
    5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
    Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80, L50, L51
    92-5 ECUs (P28, P30, P61, P72, P91, P08)
    5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02, G00, G01
    Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52, L50, L51, G51
    96-00 ECUs (P2E, P2P, P2J, P72)
    5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
    Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
    from the patterns we can learn the following:
    first letter = country of orgin
    J = Japan
    C= Canada
    A=USA
    G=Europe
    second digit, if 5, 7, 9 then ecu is auto usually
    third digit denotes the version/variation
    • กระทู้: 44077
    vichienthampracha
    « ตอบกลับ #12 เมื่อ: 04 มีนาคม 2560, 15:38:19 »
  • หวัดดีครับ++โปรเจค วาง D17A ลงใน อีซูซุ vertec เกือบสมบูรณ์แล้วครับ  ยังมีปัญหาเรื่องเร่งรอบเครื่องเวลาเปิดแอร์  ช่วยแนะนำหน่อยครับ
    Punya
    « ตอบกลับ #13 เมื่อ: 12 สิงหาคม 2561, 22:07:19 »
  •  -OO- -OO-
    ออฟไลน์ vjm-pk
    • Y1 2 3 4 5 6 7 8 +15
    • วีไอพีตลอดชีพ
    • VIP ปีที่ 4
    • กระทู้: 160
    • สมาชิกลำดับที่ : 2739
    « ตอบกลับ #14 เมื่อ: 09 กุมภาพันธ์ 2564, 13:42:39 »
  •  -O- -O- -O-
