ผู้เขียน หัวข้อ: UPA USB V1.3 Programmer English With Full Adaptors With Nec Function  (อ่าน 4965 ครั้ง)
« เมื่อ: 01 กุมภาพันธ์ 2560, 20:15:27 »
  • V1.3 UPA USB Programmer English With Full Adaptors With Nec Function
    Description:
    Language: English.
    Hardware Version:  V2014
    Software Vesion: V1.3
    New Upa-usb is the full set with all adapters, The main Device can be directly connected to the Elrasoft.com UUSP (UPA-USB Serial Programmer) or by an optional DB9 male / female 1:1 extension cable. It's equipped with an 40pin ZIF Socket for all narrow and wide DIP / DIL devices as well as with a 16 pin SOIC ZIF (150mil, narrow) socket to cover most commonly used devices.
    « แก้ไขครั้งสุดท้าย: 11 กุมภาพันธ์ 2560, 12:04:11 โดย Auto Man »
    « ตอบกลับ #1 เมื่อ: 01 กุมภาพันธ์ 2560, 20:16:24 »
  • Device configuration is done over special config keys which make the work convenient and safe compared to wiring up all manually.
    Additional packages can be covered by commonly available Adapters plugged into the 40 pin ZIF socket.
    The main Device further includes a 10 pin ISP connector where the included ISP Adapters can be connected using a standard 1:1 flatribbon cable (included). The included PLCC ISP Adapters are to be put directly over the soldered chip of the target device making the work convenient and safe compared to soldering or using clips connecting up all manually. (Power from the UUSP to the ISP target can be enabled or disabled by a jumper next to the 10 pin ISP connector)
    UPA-USB Device Programmer V1.3 Update Info:
    Added MC9S12HY64/HA32 support
    Added Serial Flash memory support: A25L512/010/020/040/080/016/032, SST25VF512A/010A/020B/040B/080B/016B/032B, S25FL004A/008A/016A/032A/064A
    Added 24C1024, 24C1025 support
    Added Bulk erase data memory to PICs 16F913-7/946, 12F629/675
    Added script function GetPage
    Added script function AutoBaudRateDevice (hc08 devices only)
    Added script function GetProgrammerFrameChildCtrl( AChildCtrlName: string): TControl
    Added script function EnablePicMemoryAreas ( AProgram, AID, AConfig, ACalibration, AEEPROM: boolean ): boolean;
    Fixed bug with script functions ProgramDevice, ReadDevice ... when used with PICs
    Fixed bug with SetHC08SecurityBytes (SecBytes: string) function
    Fixed bug with 68hc11 reading if Oscillator is not set to Auto
    Updated script example files
    The software is digitally signed
    USB driver upausb.sys is digitally signed
    EEproms
    Simply connect the mainboard to the UPA programmer directly or by using a DB9 male / female extension cable (1:1). Insert the correct config key into the slot of the mainboard and start programming either via the ZIF or SOIC Socket. You can also use the included DIL to 10pin Flat-ribbon header, put it inside the ZIF socket and wire up an SOIC clip or clamps for ISP use from there.
    Motorola MCU's
    Pick the Adapter you want to use, attach the flat cable to the Adapter (PIN1 is always indicated, on both the cable and also the Adapter) and also to the main board's 10pin ISP connector. Select the VCC supply source by the jumper on the mainboard next to the ISP connector (on = target supplied from upa, off = target got own supply). Slide the Adapter over the soldered PLCC MCU on the target PCB. (No soldering, no pinout reviewing, no pin counting, saves lots of time and hassle and let's you make your job faster, precise and easier)
    Once your workshop is equipped with our Adapter Set you will have a all new UPA Experience.
    STMicroelectronics ST62*:
    ST6240, ST6245, ST6249
    NSC CR16*: CR16HCS5(9), CR16MCS5(9), CR16MES5(9), CR16MFS5(9), CR16MCT5/9, CR16HCT5/9
    Motorola HC05*: MC68HC05B6, MC68HC05B8, MC68HC05B16, MC68HC705B16, MC68HC05B32, MC68HC05E6, MC68HC705E6, MC68HC05H12, MC68HC05L28, MC68HC05P3, MC68HC705P3*, MC68HC05X16, MC68HC05X32
    Motorola HC08*: MC68HC08AS20, MC68HC08AS32, MC68HC08AS60, MC68HC08AZ32, MC68HC(9)08AZ32A, MC68HC908AZ60, MC68HC908AZ60A
    Motorola HC11*: MC68HC11A1, MC68HC11A8, MC68HC11E9, MC68HC11EA9, MC68HC11E20, MC68HC11F1, MC68HC11K4, MC68HC11KA2, MC68HC11KA4, MC68HC11KG4, MC68HC11KS2, MC68HC11KS8, MC68HC11L6, MC68HC11P2, MC68HC11PA8, MC68HC11PH8
    Motorola HC12*: MC68HC912B32, MC68HC912BE32, MC68HC912D60, MC68HC912D60A, MC68HC912DC128A, MC68HC912DG128, MC68HC912DG128A
    Motorola HCS12*: MC9S12D64, MC9S12A128, MC9S12DG128, MC9S12DG256, MC9S12H128, MC9S12H256
    Atmel 8051 Architecture: AT89S51, AT89S52, AT89S53, AT89S8252, AT89S8253
    Atmel AVR 8-Bit Risk: AT90S1200, AT90S2313, AT90S2323, AT90S2333, AT90S2343, AT90S4433, AT90S4434, AT90S8515, AT90S8535, ATmega8, ATmega16, ATmega161, ATmega162, ATmega163, ATmega323, ATmega64, ATmega103, ATmega128, ATtiny12, ATtiny15, ATtiny2313
    Microchip PIC12: PIC12F508, PIC12F509, PIC12F629, PIC12F675
    Microchip PIC16: PIC16F627(A), PIC16F628(A), PIC16F648A, PIC16F72, PIC16F73, PIC16F74, PIC16F76, PIC16F77, PIC16F818, PIC16F819, PIC16F83, PIC16F84(A), PIC16F870, PIC16F871, PIC16F872, PIC16F873(A), PIC16F874(A), PIC16F876(A), PIC16F877(A)
    EEPROMs I2C: 24C01, 24C02, 24C04, 24C08, 24C16, 24C32, 24C64, 24C65, 24C128, 24C256, 24C512, 85C72, 85C82, 85C92, BAW574252, GRM-003, GRM-004, GRM-005, KKZ-06F, MCM2814, PCA8581, PCF8581, PCF8582, PCF8594, PCF8598, PCF85102, PCF85116, SDA2516, SDA2526, SDA2546, X24C00, X24C01
    EEPROMs Microwire: 7002, 93C06, 93C14, 93C46, 93C56, 93C57, 93C66, 93C76, 93C86, 93S46, 93S56, 93S66, GRN-001, GRO-002, KKZ-01, S220, S2914, ST61907, XLS93C46
    EEPROMs SPI: M35080, 25C010, 25C020, 25C040, 25C080, 25C128, 25C160, 25C256, 25C320, 25C640, M25P05, M25P10, M25P20, M25P40, M25P80, ST95010, ST95020, ST95040, ST95080, ST95160, ST95320, ST95640, ST95P02, ST95P04, ST95P08, X5043, X5045
    EEPROMs Miscellaneous: CXK1011, CXK1012, CXK1013, M6M80011, M6M80021, M6M80041, SDE2506, TC89101, TC89102
    *EEPROM Only
    NEC ..uDP780828A uDP780948 uDP780949 uDP780973 uDP780974
    TMS...TMS370CX02 TMS370CX32 TMS370CX36 TMS370CX42 TMS370CX56 TMS370CX56 TMS370CX56 78K0/HC912
    TMS370CX58 TMS370CX58 78K0/HC912 TMS375C006
    Package List:
    1pcXMain unit
    1pcXUSB cable
    1pcXCD
    1pcX5pin cable
    1pcXAdapter Type1 Per eprom I2C,SPI, Microware e M35080
    1pcXAdapter Type2 Motorola MC68HC11P2+MC68HC11PH8-PLCC84
    1pcXAdapter Type3 Motorola MC68HC08AS-PLCC52
    1pcXAdapter Type4 Motorola MC68HC11KA2/4+MC68HC11KS-PLCC68
    1pcXAdapter Type5 Motorola MC68HC(9)08-QFP64
    1pcXAdapter Type6 Motorola MC68HC11F1-PLCC68
    1pcXAdapter Type7 Motorola MC68HC05H12-PLCC52
    1pcXAdapter Type8 Motorola MC68HC11K-PLCC84
    1pcXAdapter Type9 Motorola MC68HC11A8/E1/E9/E20+MC68HC11EA9-PLCC52
    1pcXAdapter Type10 Motorola MC68HC11KA2/4+MC68HC11PA8-QFP64
    1pcXAdapter Type11 Motorola MC68HC11K-QFP80
    1pcXAdapter Type12 Extended address
    1pcXAdapter Type13 Motorola MC68HC11A8/E1/E9/E20-QFP64
    1pcXAdapter Type14 Motorola MC68HC05B4/B6/B8/B16/B32+MC68HC705B16/B32-PLCC52
    1pcXAdapter Type15 Motorola MC68HC(7)05E6-SOIC28
    1pcXAdapter Type16 Motorola MC68HC05B4/B6/B8/B16/B32+MC68HC(7)05X16/X32-QFP64
    1pcXAdapter Type17 Motorola MC68HC(9)12B32-MC68HC(9)12D60(A)-QFP80
    1pcXAdapter Type18 Motorola MC68HC11F1-QFP80
    1pcXAdapter Type19 Motorola MC68HC11L6-PLCC68
       อยากเสียเงิน... ไปที่นี่
