ผู้เขียน หัวข้อ: กล่อง ECU Mazda Astina  (อ่าน 4061 ครั้ง)
  • กระทู้: 44121
« เมื่อ: 08 กรกฎาคม 2560, 05:26:47 »
  • the diagram you have there is for series 1/2. Series 3 is completely different. I've been searching for series 3 diagram for so long without any luck. I have all factory manuals including wiring diagram supplement but they all are written for series 1/2. Series 1/2 ECU has 3 plugs and series 3 has only 2 plugs. In series 3 ,MAF, IAT, TPS pins are all shifted from middle plug to left plug.
       Top series 2, bottom series 3
    If you go by the above pin diagram
    MAF wires are going to 4C=4A=4D (r/b), 4M (g/b), 4L (p), 4E, 4B(r/w)
    These 5 wires include IAT within them. 4C,4A, 4D are all interconnected.
    IAC wires 4Q (b/w), 4S (b)
    O2 sensor 4J
    TPS 4H (b/y), 4G (g/r) , 4E (b/b)
    in series 1/2 ECU these pins are used for different sensors or not used at all
    e.g 4E, 4H = crank position sensor (if available)
    4G= not used
    4S= not used
    4Q= IAC valve
    __________________
    1997 Astina BA11P3, 5 Door Hatch, 1.8 DOHC, 5 Speed, 90,000 kms
        มาจากที่นี่...
    « แก้ไขครั้งสุดท้าย: 03 กันยายน 2561, 16:27:39 โดย Auto Man »
