ผู้เขียน หัวข้อ: >>> ADC116 OBD Diagnostic Port Tester  (อ่าน 4857 ครั้ง)
« เมื่อ: 23 กรกฎาคม 2560, 16:53:24 »
  •    ADC116 - OBD Tester
    The portable ADC116 OBD Diagnostic Port Tester is an easy and quick way to check that the OBD port has 12 volts and good ground connections. ADC116 can be used for all makes & models of vehicle worldwide.
     It also checks the PIN 7 line on VW / AUDI / SEAT / SKODA vehicles, to make sure that if an aftermarket radio is fitted, they have wired the system correctly, otherwise damage can be done to any diagnostic equipment that is connected to it. This makes the ADC116 an essential device for preventing your diagnostic equipment from being damaged.
    By using ADC116, this question can be quickly answered and will save you valuable time when diagnosing. If you already have AD key programming equipment - ADC116 is an essential addition for your tool kit and it will earn its keep within a few jobs.
    Functionality
    • Tests All Types of OBD Ports
    • User Friendly & Portable
    • Can be Used On All Makes Of Vehicles
    • Check Power & Ground Voltage
    • PIN 7 Check For VW / AUDI / SEAT / SKODA
    Technical Features
    • Powered By Vehicle OBD Socket
    • LED Indication Of Signal
    • LED OK / Fail Bulbs
    • Compact
     A great cost effective time saver and stops damage to diagnostic equipment.
    « แก้ไขครั้งสุดท้าย: 23 กรกฎาคม 2560, 16:56:40 โดย Auto Man »
