ผู้เขียน หัวข้อ: Hino DX3 Diagnostic explorer v1.22.12 Last update 10.2022 + keygen  (อ่าน 434 ครั้ง)
  • กระทู้: 46713
« เมื่อ: 12 มิถุนายน 2569, 05:44:07 »
  • Hino DX3 Diagnostic explorer v1.22.12 Last update 10.2022 + keygen
    Description
    Update: 10.2022
    Region: All regions
    Type: diagnostic software for Hino trucks
    Language: English, Hungarian, Dutch, Danish, Spanish, Italian, Chinese, Mexican, German, Norwegian, Polish, Russian, Turkish, French, Czech, Swedish, Japanese
    OS: Win 10, Win 8, Win 7, Win XP
    Installation: 1pc ,multi pc's
    Version: v1.22.12
    High speed download link
    PRICE:
    1 PC ACTIVATION: 99$
    Multi PC'S (SOFTWARE+KG): 250$
    The HINO Diagnostic explorer DX3 is a tool equipped with all the functions needed to diagnose trouble,
     check functions, and configure the settings of the electronic systems built into HINO engines.
    This tool covers the following markets
    – US markets. USA, Japan, Russia and others.
    – RUS, DEF, JPN, USA. UU., CAN, AUS, CHN, ESP, NZL, COL, CHL, HKG, TN, GBR, IRL, SGP, THA.
    BENEFITS DXI HINO HINO Low speed DXI contact with large amounts of data, not to expand the functionality
    of the software, led to the need to develop a new diagnostic system.
    From 2015 to diagnose HINO vehicles introduced in the work of the next generation system.
    Main functions
    – Acquires and deletes trouble data.
    – Warps the trouble codes read from the ECU to workflow sequences corresponding diagnostic and directly displays
        the required data diagnosis.
    – obtains conditions when vehicle sensor problems (freeze frame function) occur.
    – Monitors the sensors and actuators equipped on the engine (monitor function data) and test the operation
       of the solenoid valves to force operating them (Active Test function).
    – Simulates diagnostic work with only a PC (Simulation function).
    – Automatically saves the data from the ECU and analyzes the problems based on the stored data even
       when you can not understand the cause of the problems.
    Full customization capability
    – Turn the system off Motor protection
    – Set the maximum vehicle speed
    – Set the maximum speed cruise control
    – Set idle speeds of fixed and variable TDF
    – Change Injector Calibration QR Code when replacing injectors
    – the supply pump relearning when replacing SCV or supply pump
    – complete test capability and regeneration of the DPF
    – Help menus built for troubleshooting specific diagnostics
    « แก้ไขครั้งสุดท้าย: 12 มิถุนายน 2569, 05:53:31 โดย Auto Man »
