ผู้เขียน หัวข้อ: HxD - Freeware Hex Editor and Disk Editor  (อ่าน 503 ครั้ง)
  • กระทู้: 46701
« เมื่อ: 18 มิถุนายน 2569, 08:29:53 »
  •    HxD - Freeware Hex Editor and Disk Editor
    HxD is a carefully designed and fast hex editor which, additionally to raw disk editing and modifying of main memory (RAM), handles files of any size.
    The easy to use interface offers features such as searching and replacing, exporting, checksums/digests, insertion of byte patterns, a file shredder, concatenation or splitting of files, statistics and much more.
    Editing works like in a text editor with a focus on a simple and task-oriented operation, as such functions were streamlined to hide differences that are purely technical.
    For example, drives and memory are presented similar to a file and are shown as a whole, in contrast to a sector/region-limited view that cuts off data which potentially belongs together. Drives and memory can be edited the same way as a regular file including support for undo. In addition memory-sections define a foldable region and inaccessible sections are hidden by default.
    Furthermore a lot of effort was put into making operations fast and efficient, instead of forcing you to use specialized functions for technical reasons or arbitrarily limiting file sizes. This includes a responsive interface and progress indicators for lengthy operations.
    Features
    Available as a portable and installable edition
    RAM-Editor
    To edit the main memory
    Memory sections are tagged with data-folds
    Disk-Editor (Hard disks, floppy disks, ZIP-disks, USB flash drives, CDs, ...)
    RAW reading and writing of disks and drives
    for Win9x, WinNT and higher
    Instant opening regardless of file-size
    Up to 8EB; opening and editing is very fast
    Liberal but safe file sharing with other programs
    Flexible and fast searching/replacing for several data types
    Data types: text (including Unicode), hex-values, integers and floats
    Search direction: Forward, Backwards, All (starting from the beginning)
    File compare (simple)
    View data in Ansi, DOS, EBCDIC and Macintosh character sets
    Checksum-Generator: Checksum, CRCs, Custom CRC, SHA-1, SHA-512, MD5, ...
    Exporting of data to several formats
    Source code (Pascal, C, Java, C#, VB.NET)
    Formatted output (plain text, HTML, Richtext, TeX)
    Hex files (Intel HEX, Motorola S-record)
    Insertion of byte patterns
    File tools
    File shredder for safe file deletion
    Splitting or concatenating of files
    Basic data analysis (statistics)
    Graphical representation of the byte/character distribution
    Helps to identify the data type of a selection
    Byte grouping
    1, 2, 4, 8 or 16 bytes packed together into one column
    "Hex only" or "text only"-modes
    Progress-window for lengthy operations
    Shows the remaining time
    Button to cancel
    Modified data is highlighted
    Unlimited undo
    "Find updates..."-function
    Easy to use and modern interface
    Goto address
    Printing
    Overwrite or insert mode
    Cut, copy, paste insert, paste write
    Clipboard support for other hex editors
    Visual Studio/Visual C++, WinHex, HexWorkshop, RegEdit, ...
    Bookmarks
    Ctrl+Shift+Number (0-9) sets a bookmark
    Ctrl+Number (0-9) goes to a bookmark
    Navigating to nibbles with Ctrl+Left or Ctrl+Right
    Flicker free display and fast drawing
        ลิ้งค์ดาวน์โลด  V. 2.5.0.0
    « แก้ไขครั้งสุดท้าย: 18 มิถุนายน 2569, 08:44:24 โดย Auto Man »
