ผู้เขียน หัวข้อ: โปรแกรมปิดโค้ด iDecoder 4.5  (อ่าน 658 ครั้ง)
  • กระทู้: 46567
« เมื่อ: 01 กันยายน 2569, 05:18:59 »
  • โปรแกรมปิดโค้ด iDecoder 4.5
         เป็นโปรแกรมสำหรับปิดโค๊ด DPF หรือบางรุ่นอาจมี Immo OFF สำหรับรถยุโรปเป็นหลัก
       คลิป
    « แก้ไขครั้งสุดท้าย: 01 กันยายน 2569, 05:48:44 โดย Auto Man »
    • กระทู้: 46567
    « ตอบกลับ #1 เมื่อ: 01 กันยายน 2569, 05:50:04 »
  • Decoder is an offline dump-processing utility for supported ECU, immobilizer, dashboard and body-module files. Available operations depend on the selected vehicle and module family and may include IMMO, PIN/VIN, virgin reset, CS/MAC, ISN, PCR2.1 unlock, DPF, EGR, TVA, hot-start and DTC functions.
    คำแปลไทย
    License Activation​#
    To request activation:
    1. Download and fully extract the complete iDecoder package.
    2. Launch the program only through START-iDecoder.exe.
    3. At the first launch, copy the displayed 16-character HWID.
    4. Reply to this discussion thread and post your HWID.
    5. Wait for your personal .reg license file to be issued.
    6. Close iDecoder before installing the license.
    7. Download the supplied .reg file and double-click it.
    8. Confirm that the information may be added to the Windows Registry.
    9. Launch START-iDecoder.exe again.
    A license filename may look similar to:
    CC22203D07654137.reg
    This is only an example. Every license is generated for one specific computer and will have a filename
    corresponding to the submitted HWID.
    A license issued for another computer will not work.
    If the HWID window appears again after importing the registry file, post the newly displayed HWID and attach a screenshot of the activation window.
    Installation Notes​#
    • Extract the archive into a separate folder, for example C:\iDecoder\
    • Do not run the application directly from the ZIP archive
    • Always use START-iDecoder.exe
    • Do not launch Runtime\iDecoder.exe directly
    • Do not move, rename or remove files from the Runtime folder
    • Keep the launcher and Runtime folder together
    For easier file handling, working dumps can be stored in a separate directory such as:
    C:\BIN\
    Processed files are normally created beside the selected source file.
    Technical Support and Bug Reports​#
    When reporting a problem, please include:
    • iDecoder version
    • Selected vehicle group
    • Selected ECU or module function
    • Memory type and dump size
    • Tool used to read the original file
    • Screenshot of the application
    • Exact error message or unexpected result
    • Information about whether the processed file was created
    Please do not publicly attach customer dumps containing VIN, PIN, immobilizer or other sensitive vehicle data unless specifically requested by a staff member.
    Compatibility Reports​#
    Reports for tested vehicles and control units are welcome. Please include:
    • Vehicle make, model and year
    • ECU or module type
    • Hardware and software identification
    • Memory type used
    • Selected iDecoder function
    • Whether the operation completed successfully
    Compatibility depends on the exact ECU version, software structure, memory organization and dump size.
    A listed ECU family does not guarantee support for every available variant.
    File Safety​#
    Always keep an untouched backup of the original dump and work only with a separate copy.
    Do not overwrite the only available original file. Verify the processed result and any required
    checksums before writing it back to a control unit.
    « แก้ไขครั้งสุดท้าย: 01 กันยายน 2569, 06:05:28 โดย Auto Man »
    • กระทู้: 46567
    « ตอบกลับ #2 เมื่อ: 01 กันยายน 2569, 05:57:07 »
  • - ยี่ห้อรถที่เลือกได้มีอะไรบ้าง ดูได้จากรูปด้านล่าง
    - สำหรับรถบ้านเรา ส่วนใหญ่จะเป็นค่ายรถ Ford / Mazda
       ดูมีกล่องอะไรที่เลือกได้บ้าง
    - สำหรับรถ Hyundai / Kia จะเป็นการปิด Immo
    • กระทู้: 46567
    « ตอบกลับ #3 เมื่อ: 01 กันยายน 2569, 06:08:37 »
  •    สมาชิกต้องการนำโปรแกรม iDecoder 4.5 ไปทดลอง/ทดสอบการใช้งาน
    สามารถไปลงทะเบียนได้ที่
    นี่คือลิงก์ ลงทะเบียนที่นั่น โพสต์ ID ของคุณในกระทู้ แล้วระบบจะสร้างคีย์ให้คุณเพื่อนำเข้าใน Windows
